Question about Emerson THREADED SHAFT UP RATED - 1.00 HP - EB228
Which way do I turn the screw to open up so I can replace the gasket?
  • Emerson Master
  • 1,368 Answers
LOOKING AT THE SHAFT OFF TO THE LEFT AND ON TO THE RIGHT. MAKE SURE IT DON'T HAVE A SCREW IN THE CENTER OF THE IMPELLER IF IT DOES IT TURNS ON TO THE LEFT AND OFF TO THE RIGHT (CLOCKWISE) .. INSTALL A NEW SHAFT SEAL ! .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
Posted on May 26, 2010
I need to know how to change he door seal(gasket)
  1. Buy a gasket that fits your door exactly.
  2. Soak the new gasket in hot water in the sink to make it pliable.
  3. Make sure the refrigerator is level.
  4. Find a nut driver that will fit the screws holding the old gasket in place and lay out your tools where you'll be able to reach them.
  5. Start at the top outside corner of the door and fold the old gasket back as you partly loosen the screws along half of the top and side. Don't loosen them all the way.
  6. Pull the old gasket out.
  7. Attach the new gasket by pushing it beneath the metal retainer and tightening the screws as you go.
  8. Replace each section the same way.
  9. Shut the door and check for gaps. The seal should lie straight and smooth all the way around the door.
  10. Notice if there are gaps between the gasket and the frame - this may indicate that the door has warped. (Fix it by loosening the screws and twisting the door a little. You may have to do this a few times before you get the door straight.)
  11. Put a flashlight in the freezer pointed toward the opening and shut the door. Turn off the lights. You shouldn't see any light leaking through.
Regards....
Oct 29, 2010 | Refrigerators
How do you change out the door gasket?
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Step 9
Step 10
Step 11
Hope this helpout .......
Aug 13, 2010 | True TUC-27F-ADA Undercounter Freezer,...
How do I install gasket on doors - top and bottom on Amana Model DRT1802B
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Step 9
Step 10
Step 11
Good luck and hope this helps............
Jul 29, 2010 | Amana Refrigerators
GE #WHDVH626 Front Loading Machine - Door gasket Leaks, Need to replace gasket, HOW?
Remove the top panel, the control panel, the toe panel, and the front panel to replace the door gasket. Disconnect power to the washer before servicing to avoid electric shock.
Remove the top panel by removing the top cover and the three 7-mm hex-head screws that attach the rear of the top panel to the cabinet. Remove the top cover by removing the three Phillips-head screws that hold it in place then insert a putty knife blade or similar tool along the top seam between the cover and the control panel. Lightly tap the cover off rearward; slide the top panel rearward then lift it off the cabinet.
Pull the dispenser drawer out until it stops; push down the locking tab, and then pull the dispenser drawer all the way out. Once the drawer is out, remove the Phillips-head screw from the recess of the drawer opening.
Remove the four Phillips-head screws that attach the control panel to the control panel cover. Release the tab on the right side of the control panel from the bracket inside the cabinet.
Lift the top edge of the control panel to release the three tabs that hold its top in place. Push the control panel towards the left, then release the side tab.
Label the wires and mark the connectors matching the wires before disconnecting the wires from the control panel.
Remove the three Phillips-head screws at the bottom of the toe panel holding it to the cabinet, then pull the toe panel down and off the cabinet.
Open the washer door, then remove the three Phillips-head screws holding the door switch and lock assembly to the front panel.
The door gasket is held to the lip of the door opening by a wire and a spring hidden in the fold of gasket. Grasp the wire at the spring location using a pair of needle-nose pliers and stretch the spring to clear the gasket, and then remove the wire and spring assembly. Peel off the door gasket from the lip of the door opening into the drum.
Remove the four Phillips-head screws that secure the front panel on its four corners to the cabinet. Lift up the front panel then remove it from the two hooks and all the way off the cabinet.
Pull down the top of the gasket, and then remove the nozzle from the gasket. Remove the gasket from the water inlet pipe, and then loosen the 7-mm bolt that tightens the wire holding the gasket to the outer tub lip. Take note of the position of the gasket, and then remove it and the wire from the lip of the outer tub.
Install the new gasket into the lip of the outer tub aligning the notch in the gasket with the arrow located on the top of the lip of the outer tub, and then secure it with the wire and the bolt. Do not over tighten the wire with the bolt. Allow a gap of about 1.25 inches between the ends of the wire. Over tightening the wire may tear the gasket.
Insert the nozzle into the gasket ensuring that the washer is placed on the outside and that the nozzle is aligned with the dent on the inside of the gasket. Insert the water inlet pipe into the gasket, and then put the gasket inside the drum.
Reinstall the front panel back into position on the hooks then secure it to the cabinet with the four Phillips-head screws.
Slide the toe panel up into the cabinet then secure it with the three Phillips-head screws.
Reconnect the wires to the control panel. Snap the control panel back into the cabinet, and then secure it with the screw at the recess of the drawer opening.
Slide the top panel back in place then secure its rear with the three 7mm hex-head screws to the cabinet. Reinstall the top cover and secure it the three Phillips-head screws.
Mar 12, 2010 | GE WSXH208A Front Load Washer
Leak around bottom door gasket
No, you don't need to remove the door to replace the gasket. It is usually a pressure fit and will just push into the alloted space. Take notice of where the originial one begins and ends before removing it.
Nov 18, 2009 | Frigidaire Dishwashers
How do I replace the door gasket on a Westinghouse front loading washing machine? Have taken off the front steel ring that holds the gasket in place, but looks like I need to take the front panel off the...
The step by step procedure to replace the head gasket are:
  1. Open door and pull on inside of gasket to expose screws or 1/4 nuts.
  2. Loosen[do NOT remove] all screws and pull old gasket out.
  3. Place new gasket in sink of hot water to soften it and put back around door.
  4. Snug up a couple of screws on each side and test seal by shutting door.
  5. You may need to adjust inner panel until just right..then tighten all screws
Sep 23, 2009 | Westinghouse Washing Machines
I needs to replace my refrigator door gasket. I need a manual with pictorial diagram and with details on how to remove and install the gasket.
open door and pull on inside of gasket to expose screws or 1/4 nuts.. loosen[do NOT remove] all screws and pull old gasket out. place new gasket in sink of hot water to soften it and put back around door. snug up a couple of screws on each side and test seal by shutting door..you may need to adjust inner panel until just right..then tighten all screws
Sep 05, 2009 | Refrigerators
Replace rubber gasket
Replace the machine with a top loader and you'll never have a leaking gasket again! Worked at National Linen for a while and the floors had drains in them and were always wet! Needless to say the pros have the same problem you do! ;)
Apr 22, 2009 | GE WBVH6240F Front Load Washer
Kenmore 596.50692000 refrigerator. Every time I shut the refrigerator door, the freezer door pop open. What can I do? Do I need to replace the magnetic strip around the door? Who can give me instructions?...
Replace a door gasket on a refrigerator....
Replace a door gasket on a refrigerator: The first thing to do when changing a door gasket is to check and see if you have the proper part before taking the old gasket off. Hold the new gasket up to the fridge door to make sure the gasket is the same size as the old one. Next step is to remove the wrinkles in the gasket caused by folding for shipping. Instructions with the gaskets say to soak the gasket in hot water. Another way is to use a hair dryer to heat the gasket and remove the wrinkles. Be careful not to burn the gasket with the hair dryer. Almost all gaskets in use today are magnetic. I am placing instructions here for the most common one. They have strips of magnetized material inside the gasket material to adhere to the cabinet when the door is closed. Therefore there is sometimes no up or down on the gasket. Some fridge's have magnets on only 3 sides and the side without a magnet is the hinge side gasket. But to be safe, check this before installing. You will certainly want to check for this on older refrigerators that have magnetic door latches. Some of these have no magnets on the latch side of the gasket. There are about three different ways of attaching gaskets. All will be addressed on this page. Remove the food from the shelves on the door. Loosen the screws that hold the metal strips that keep gasket in place on the top half of the door. Back the screws out about 1/4 inch. The gasket has a lip on it that seats in a groove under the top part of the metal strip. Pull the old gasket off. Work the groove on back side of the new gasket under the cutout in the metal strips that holds it on the door liner. Straighten and get good install before tightening screws. Run screws back up against the metal holding strip snugly, not fully tight. Go to the bottom and do the bottom half. By doing the top half first and tightening, then doing the bottom half, you will minimize any warping of the door. If there is warping of the door, we have not yet fully tightened the screws. so you can realign the door easily and then tighten the screws. Check the alignment of the door and be sure the gasket is sealing properly before fully tightening the screws. If the door is warped, (see picture) simply warp it back to a sealing position, then tighten the screws. There are instances where the gasket is too tight on the hinge side, and you may have to shim the door hinges out from the cabinet to keep the gasket from scrubbing when closing. .also use a little petroleum jelly on the gasket on the hinge side will allow the gasket to "settle" better. The hinge side must slide along the cabinet edge while the other 3 sides just close up against the cabinet. The jelly will allow the gasket to rub smoothly and also prevent squeaking noises. Maintenance of the gasket is important also. It should be cleaned on a regular basis. Clean the gasket and the mating cabinet surface with warm soapy water, rinse clean and dry it good. Putting a little baby powder on the sides (except the hinge side because we put the jelly there) will prevent the gasket from sticking and tearing. The heaters in the refrigerator used to keep moisture from forming on the cabinet attracts airborne materials and make the gasket sealing surfaces sticky. The powder will help stop this. Probably 75% of the fridge's made a few years ago use this edge under the metal track....some American made fridge's use the U shaped metal strip and the gasket pushes into the metal strip, (see a picture) the screws that hold this metal strip do not have to be removed or loosened. A lot of fridge's also use the metal strips with out the edge. Some Maytag's and Woods come to mind. The screws go through the metal strip and the gasket as well. The screws have to be removed completely to replace the gasket.
Gasket sheet to assist you in replacing a common door gasket.
Freezer door pops open when I shut the fresh food door:
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
Let me know if this helps, Thanks, Sea Breeze
Mar 25, 2009 | Kenmore Refrigerators
How do i adjust doors so that they close on their own?????????????
Below is instructions on how to make sure doors open and close properly. Ignore the popping open part if this is not happening for you.
Mar 20, 2009 | GE Refrigerators
Emerson THREADED SHAFT UP RATED - 1.00 HP - EB228 Logo
210 people viewed this question
Top Emerson Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Ian Kime
Ian Kime
Are you an Emerson Pool and Spa Expert? Answer questions, earn points and help others
