Question about Tag Heuer Formula 1 WAC1111.BA0850 Wrist Watch
The second hand stops for 3 seconds, then catches up.
This is the continuous movement of the second hand. It stops moving, then after 3 sec. it catches up, stops, catches up. Do you have an idea why it would be doing this? It is a Formula 1, white face.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 175 Answers
My seiko used to do the same when the battery was coming to the end of its useful life. Have you changed the battery recently?
Posted on May 25, 2010
I have Swiss legend challenger and it's new. How do you get the second hand moving.
Sorry...
New or not SWISS use the second hand as an early indicator of the battery state.
My memory is that it starts by skipping seconds...
Then the second hand stops...
Then the watch...
ELSE
The movement is bad.
If it is INDEED NEW... Take it back & get
yourself a fresh one.
Carnac the Magnificent
Mar 25, 2017 | Swiss Legend Watches
On my Luminox 3051 BO watch, the second hand (showing seconds evolution) does not match exactly with the marks all around the watch. Regards Robert
Sorry Robert but it is likely you will have to accept and get used to it. The movement's seconds hand is just not calibrated to the exactness the dial is printed in. Notice as your hand moves it sometimes lands on a marker and gradually stops lining up and then as it reaches another part of the dial it will start lining up again. However it never is consistent as to what markers it lines up with. Lots going on behind the scenes (in your movement) that is inherent in battery powered movements.
Mar 11, 2011 | Navy Seal Luminox Watch
For about a month, while the watch did keep time, the second hand only moved 4 seconds at a time. In other words, it would no move each second, just in 4 second intervals. Now it is not keeping time,...
Your watch is fitted with EOL (end of life). This does not mean end of watch life, but end of battery life. Replace battery and watch will work as it should. Rate me, please.
Feb 27, 2011 | Omega Seamaster 300M Mid-Sz 2551.80.00...
The second hand will not re-set to zero. It has stopped. The watch works perfectly during the day apart from the second hand not moving, but , the watch stops at 11.15 at night. When I get up in the...
This is a symptom of what is usually several possible issues:
1) The most common is that the battery must be changed. Insist on Energizer batteries only (as they do not leak) and visit your local Certified Master Horologist for assistance in changing the battery and resetting the watch.
2) The movement must be serviced every 3-5 years by a qualified professional. Dust and debris can cause the symptom of stopping and starting the movement. If you have owned it for less time than this, remember that the watch may have been manufactured and in the retail location longer than this period of time before it was purchased.
3) The movement is defective or damaged. If the watch is under warranty, and it was purchased through an authorized dealer, Armani will take care of this issue for you at no charge.
To properly assess this issue, I recommend taking the first step, as a CMH also has the proper tools to test the movement and battery to determine the best next course of action.
watchandpen
Feb 25, 2011 | Giorgio Armani Emporio Armani watches...
The movement on the second hand is jumping every 5 seconds instead of every second, however the time is still correct.
Many high end quartz watches have a feature called the EOL or end of life indicator. This causes the seconds hand to jump 2, 3 or 5 seconds depending on the make of watch when the battery life is low. The watch will continue to keep accurate time until the battery dies completely. So, when you see your seconds hand jumping multiple seconds it is time to get a battery.
Oct 13, 2010 | Omega Seamaster 2561.80 Wrist Watch
The second hand on my Luminox 3007 now moves in 4 sec increments
thaqt is an EOL problem...basically telling you the cell is very low
Apr 16, 2009 | Luminox 3007 Original Navy Seal Diver...
Second hand doesn't move for each second
Your TAG is fitted with EOL (end of life) feature. This is the cause of that 4 seconds interval movement of seconds hand and thus indicating the time for battery replacement. The timekeeping is not affected by this- it is just warning to replace battery a.s.a.p.
Find your nearest watchmaker and ask for battery replacement.
Do not forget to rate, please.
Mar 20, 2009 | Tag Heuer 2000 Classic WK1311 wristwatch
Casio 4305 runs 5 minutes slow.
No reason to panic as your watch hands can be advanced to desired time. Her is the link for your watch users manual download:
http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=4305&submit.x=52&submit.y=12
Save it on your PC and follow instructions how to set the time.
Don't forget to rate, please.
Jan 05, 2009 | Watches
Casio watch
Press MODE until you reach H-S (e.g. A 11:00 with seconds on top)
Press and hold ADJUST for 3 seconds until H-S blinks
Press and hold SEARCH for every movement; you may wanna press LIGHT so the hands will move freely. Press ADJUST again to when desired time was reached
Oct 21, 2008 | Casio Watches
Festina 16177 / 8- Tour de France 2005 - second hand not moving
The large sweep hand is not the second hand,it is the 1,100th sec hand on chrono.The second hand during time mode is the small dial at the bottom which should be going round
Jul 22, 2008 | Festina 16177 3 Watch
Tag Heuer Formula 1 WAC1111.BA0850 Wrist Watch Logo
223 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
