Question about Samsung CLX-3175FN Printer
Printer not finding local pc to scan to?
I tried to set up printer wireless and installation kept stalling on the installation so I installed as a regular printer and when I try and scan to local pc it cannot connect.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 91 Answers
You need to set the ip adress in the network settings and use lan cables not usb
Posted on Jun 09, 2010
How do I change the pc name for scanning from my printer to my computer
I hope that you have the install disk because most of those need to be hooked up to the computer one time to set the printer name and other info so it can be found.
Mar 08, 2016 | Office Equipment & Supplies
I have an HP6500 all in one printer and when I try to scan it says refer to device documentation
Scan to PC is not set up on the device. For this to work you will need a piece of a software on the PC that will be waiting for scan requests, and a setting on the device to know where and how to find the PC with that software. Usually both are set up at the time of installation, when it is done with the Full Driver Package, usually provided on a CD/DVD, or you can look for it and download from hp dot com. Download the latest and the biggest one, then install it.
Sep 25, 2014 | HP Officejet 6500 Wireless All-in-One...
My Lexmark 4550 will not sacn wirelessly, how do I
Hello. Try to run the installation cd in your computer again. If you haven't tried to uninstall the software from your computer, the cd should give you three options: Install a Printer, Repair/Update and Install Additional Softwares. Choose Repair/Update and just let it run and finish the installation. Also, make sure to allow all Lexmark and printer communications in your firewall. Try to scan wirelessly again. If problem needs further troubleshooting, I advise you to call Lexmark.
Mar 31, 2010 | Lexmark X4550 InkJet Printer
Multi-function Samsung CLX-3175 doesn't scan to PC
I had the same issue with Windows 7 64 bit.I managed to solve it by doing the following
1. Locate the scan2pc.exe program in C:\Windows\twain_32\Samsung\CLX3170 2. Right-click/properties - Compatibility tab. 3.Set compatibility to win xp. Set "Run as Administrator"
I also added the scan2pc.exe to the firewall allowed programs (did that for scanmgr.exe as well, but I don't think I needed to).
Works great now!
Good luck!!
Mar 19, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
I have an Lexmark z1480 wireless printer, it is currently set up on our home network and works with my PC. We have recently purchased and iMac. I have downloaded the drivers for the printer and installed...
Can you tell the Mac to "browse for networked printers" (or something like that) ? Once it scans your local network for "shared" printers, it should find the printer.
Dec 29, 2009 | Lexmark Z1480 InkJet Printer
Can't print from my local printer with Remote Desktop
Try the following :
1. Go to Printers and Faxes
Right click on the printer u are using. Select Share this printer.
2. Set up a home or small office network with Internet connection connected, Printers on on both computers and identify both of them saperately.
For this you need to connect both computers with a cross cable.
3. after the home or small office setup is complete add a new printer from your Printer and Faxes menu. Search your printer automatically and choose it from the llist system provides and select the printer as default if needed.
4. Try taking a 'Test Printout' from the Concerned printer's properties page.
5. if this works, you have successfully installed the printer and are ready to take prints.
Mar 29, 2009 | Sharp AL-1642CS Copier
Scanning problem
This seems like you haven't installed the toolbox correct, please send more info.
Have you printer connected by usb cable or in a network(scanning doesn't work on a wireless)?
If on a network, use web browser and through EWS on printer see for network tab and SNMP enable read/write, print public in the 4 fields choose apply. Download fix scan utility from HP web and install. Restart the pc and set up the scan in toolbox and try scan again.
Sep 26, 2008 | HP LaserJet 2840 Printer
Cannot configure the wireless USB Print Server
first delte all the programs that u have installed about the print server and the printer.then connect the print server on ur laptop and run the installation .search for the wireless netwrk and connecting to it using the wpa key.After tats done connect the print server to the printer and run the printer installation ,,hope that shud resolve it,,best of luck
May 06, 2008 | Port Incorporated Wireless 11Mbps...
Fax device I/O error
installed samsung scx-4521f multi function printer. can't fax from smarThru program. get message : Fax device I/O error
Jan 11, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX-3175FN Printer Logo
248 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
