Question about Microsoft Windows XP Professional
Problem with opening ini files...
Hi all...
I have a common problem in 4 to 5 pc's that the .ini files never opens up with the notepad when tried it flashes this message "the filename,directory name or volume label syntax is incorrect"
but i am able to open it up with word pad file wat may be the sudden cause of this ??
Thanks in advance..
Hari
  • harikreative Apr 08, 2008
    Sir,
    I had tried that too but when done ""the filename,directory name or volume label syntax is incorrect" occurs and right now I had selected wordpad as a default opener for the .ini files...
@Solution#1
We mean to say that even if we open it in notepad mode it is empty this occur "the filename,directory name or volume label syntax is incorrect" BUT in wordpad it work.
not to open in default application as notepad..
Posted on Jul 19, 2008
    Problem Solver:
  • 17 Answers
From each computer:
right click on a .ini file,
select 'open with...'
choose notepad and select the box that says 'always use the selected program to ope this kind of file'
click 'ok'
Posted on Apr 08, 2008
Could someone help me with lotus notes issue?
Hello!
First of all try these steps
1 Open the "Start" menu and click "Computer" or "My Computer" depending on your version of Windows. Navigate to the C drive.
2 Open the "Notes" folder. Double-click on the "Notes.ini" file to open it in Notepad.
3 Place a semicolon (;) in front of the following two lines to temporarily disable VirusScan: AddInsMenus=NCMenu EXTMGR_ADDINS=NCExtMgr
4 Click the "Save" option from the "File" menu. Close Notes.ini. If the steps do not help you try to use Lotus Notes Fix Toolbox https://www.fixtoolbox.com/lotusnotesfix.html
Apr 26, 2015 | IBM Lotus Notes/Domino 6.5.3 (AH0LZNA)
Battle Realms could'nt read INI file
cant save the ini file says access denied
Jun 12, 2012 | Ubi Soft Battle Realms
How do I rename the Urdrive when it shows up on My Computer?
Something to add to HoboPelican's solution, if you open the autorun.inf file with notepad or wordpad you can change the name on the last line where it says "LABEL = KINGSTON URDRIVE" then just replace KINGSTON URDRIVE with the name you would like to call the drive.
Jun 12, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
0x8ac70013 msn video call are not working
Solution A: If you using McAfee Antivirus, the following steps will configure SiteAdvisor to stop monitoring windows live messenger. Go try solution B if you are NOT using McAfee Antivirus.
1. Navigate to the following folder:
Windows XP/2000/Vista (32-bit): C:\Program Files\McAfee\SiteAdvisor
Windows Vista (64-bit): C:\Program Files (x86)\McAfee\SiteAdvisor
2. Right-click on the file sasets.ini and choose Open With, then select Notepad.
3. Locate the section titled [msnmsgr.exe].
4. Change Enabled=1 to Enabled=0.
5. Click File and select Save.
6. Close sasets.ini and restart your computer for changes to take effect.
Solution B: I am using XP with NOD32, using the latest version 2009 (Build 14.0.8117.416) and here is the solution that works for me,
1. Sign off and Exit messenger
2. Go to C:\Program Files\Windows Live\Messenger
3. Right click on file "msnmsgr.exe", select "Properties", a new window of msnmsgr.exe Properties will pop up.
4. Under "Compatibility" tab, look for "Compatibility mode", if the box "Run this program in compatibility mode for" is checked and show window 2000. Go ahead un-check it.
5. Open messenger again and try to test the video call.
Mar 18, 2011 | Home
There are two folder namely desktop.ini, desktop.ini automatically appeared in the desktop. I scan my computer using Microsoft security Analysis but these folders are not moved or deleted from the desktop....
This must be a worm that replicates files/folders. As we all know, desktop.ini is not a folder, it's a system file which can be opened with Notepad.
What antivirus were you using to scan your computer? This worm/s can be easily detected and deleted/repaired by avg free (click here to download avg free). [open the link and click green "Download" button]
Download and install the Avg Free. Run a full system scan and check the result. That will fix the issue related to your desktop.ini folder etc..etc..
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 22, 2010 | HP Computers & Internet
How to create a flashdrive baground
First of all put the iamge file ( eg. test.jpg) in the root of the Flash drive. Then create a text file there and rename it to desktop.ini to the root of the Flsh drive.. Make sure it's not a .txt file.
Then open the desktop.ini file in notepad and enter following content.
Code:
[ExtShellFolderViews]
{BE098140-A513-11D0-A3A4-00C04FD706EC}={BE098140-A513-11D0-A­3A4-00C04FD706EC}
[{BE098140-A513-11D0-A3A4-00C04FD706EC}]
>>.try it. :)
Feb 11, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Problem on 3 operating sys after reformatting
This is a common annoyance some people has encounter after reinstalling Windows.
The problem is that everytime you turn your computer ON, or restart it, you have a list of Windows you can boot from....even though you "know" there is only one.
First of all look into the BOOT.INI file, and make sure you kmow the version that is currently active.
You can safely delete the other two.
Next time you reboot, your computer should start as usual.
PS
To bring up the BOOT.INI
Go to Run, and type CMD, press Enter
at the end of the string type: cd"space".. (two dots)
Keep doing this until you get to C:/
now type BOOT.INI
A notepad document will open, and you'll see all the options you see at boot up.
Just delete the ones you know you don;t need, and save that notepad document.
Restart your pc, and that is all..!!
Please don;t forget to rate the answer if its useful
Jun 25, 2009 | Microsoft Computers & Internet
Importing Messages from LG KU990 to PC
you need to find a file called config.ini
you open this in notepad and change the KU990 to just U990 and save the file. Now when you open messages you can see email and SMS.
Feb 17, 2009 | LG KU990 Viewty
I can 't open file extension .ini in windowes xp
Here is a link to someone with the same problem and the solution: http://www.windowsbbs.com/windows-xp/70739-ini-extension-files-does-not-open-notepad.html
You can start by clicking start, then click run, and type regedit and press enter. Then expand the HKEY_Classes_Root folder and look for .ini, Click on .ini and make sure it is the following:
Default REG_SZ inifile
PerceivedType REG_SZ text
Let me know if you need more help. If this was helpful please rate, thanks!
Shawn
Jan 13, 2009 | Computers & Internet
Canit open files
Hi this is a common problem. Your .exe associations have become corrupted somehow.. the link below will help you effect a repair. http://filext.com/faq/broken_exe_association.php
Sep 15, 2007 | Microsoft Windows XP Professional for PC
Microsoft Windows XP Professional Logo
178 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
