Question about Amana AAC051FRB Air Conditioner
E1 error code on amana a/c 220 volt window unit
mattozan
  • 555 Answers
SOURCE: E1 error code
You can contact Haier Technical Support here to open a support case for this error.
Posted on Jun 05, 2008
  • 330 Answers
SOURCE: Error code
Do you still the warranty for this unit? maybe you should contact the company which you bought the unit.
Posted on Jul 03, 2008
SOURCE: amana wall ac unit
I had the same problem, during a storm, the A/c stopped working, though the electricity did not go out, and I unplugged my A/C over night, and it worked again the next afternoon. I let it sit for almost 24 hours, unplugged. Now it works
Posted on Sep 07, 2008
SOURCE: Wiring for an Amana PTL
I have an 2003 Amana ptac unit. The control board burnt out. I had the board replaced, the old board was analog the new one is digital. Since changing the board i set the temperature at 72. I have a thermometer in the room and the temp. won't go below 80 degrees. I never had this problem before the board was changed. Can you help me with this concern. Thanks
Posted on Jun 09, 2009
  • 11 Answers
SOURCE: samsung AQV12m e1 error code
Check the wiring. If it's okay, reset by switching the power from the outside unit off for approx. 1 minute.
Posted on Sep 13, 2009
Haier service manual
This is what you error code means.
E1 = Room temperature sensor fault
Haier Air Conditioner Fault Codes
AC Repair Tamarac
Aug 25, 2014 | Haier Esax3186 Energy Star 17,000 Btu...
What wrong my comfortstar mini **** outside unit not coming on and I am getting e1 error code
I am somehow listed as someone who "solved" a Comfortstar mini problem - but I have not. And the company that installed it cannot. I am really fed up with the stupid thing.
Jun 17, 2014 | Ingram's Water and Air ComfortStar Mini...
How do i fix E1 error
  • Press the "Power" button to turn off your unit and then remove the filter from the filter panel on the side or front of your air conditioner. Refer to your manual if you are unsure where the filter on your unit is located.
  • 2 Inspect the filter. If it is dirty, brush off dirt, debris and lint. If it is really dirty, wash it with mild soap and water and allow it to dry completely. Reinsert it into its compartment. If your filter is worn out or damaged, purchase a replacement filter from an appliance or hardware store and replace the old one.Turn on the air conditioner. Move to the next step if the LCD continues to display the E1 error code.
  • 3 Check for a reset button on your air conditioner and press it to reset your unit. Some of the newer air conditioners have reset buttons to restore the default factory settings. Press the "Power" button on the front panel of your air conditioner to power down your unit if it does not have a reset button. Unplug the unit from the electrical outlet. Leave the air conditioner off for several hours to see if it will reset.
  • 4 Plug your air conditioner back into the electrical outlet and turn it on. If your air conditioner is still displaying the E1 error code, turn it off and contact a qualified technician because the room thermistor responsible for detecting room temperature may be defective.
  • Jun 10, 2014 | Amana Acd12ke-e Window Air Conditioner
    Error code F8 E1
    My Maytag MVWX700XW1 washer does not spin, the lid lock light is flashing red and when I run the diagnostics, and check the Fault Error code I get F7 E1.
    I would alos like to find the list of Fault Error codes.
    Thank you for your help.
    John
    Jan 10, 2014 | Amana Washing Machines
    Getting an E1 error message..wont start
    1. Unplug unit. 2. Hold down power button while plugging in unit. It will do a short self-test and then beep. leaving unit off. 3. Release power button and unplug. 4. Plug in again and turn on normally. This should last for about 720 hours, at which point the E1 error will come back and you need to follow the procedure again. (You might as well clean the air filter at this point just in case it really needed it...)
    Let me know,if needed further assistance.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
    Sep 03, 2011 | Amana ACD106R Wall/Window Air Conditioner
    AMANA ACB087R, reading E1 on display and none of the buttons work at this time. Someone please help me solve this problem. Thanks.
    Here is a tip that gives a further explanation of that E-1 code. The causes of the E-1 code can be varied depending or the brand of your air conditioner.
    Read through this tip... it will help you understand what is happening with your window air conditioning unit and give you some things to try to help you get your problem resolved.
    E-1 Code on Window Air Conditioning Units
    heatman101
    Sep 06, 2010 | Amana Heating & Cooling
    E1 error code
    Replace indoor room temp sensor.
    Jul 31, 2010 | Haier 539490003 Air Conditioner
    I get a E1 error code on my window ac unit. What
    Indoor room temp sensor defective. Replace it.
    May 26, 2010 | Haier hwr10xc6 Air Conditioner
    Amana AAC051FRB Air Conditioner Logo
    210 people viewed this question
    Top Amana Heating & Cooling Experts
    Dan Webster
    Dan Webster
    Donni Steen
    Bill Long
    Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
