Question about Aiwa XR-H33MD Shelf System
XR-H33MD NO POWER. FUSE ARE OK - Aiwa XR-H33MD Shelf System
    President:
  • 1,099 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} check to see if you put the correct fuse in the receiver, and if it is the correct one, you will need to check the protection circuit because with it being turned up so loud the amp was probably damaged. in most cases with protection circuits you will probably find your problem with an output transistor. than check for blown capacitor.
hope this will help...
Posted on May 26, 2010
Thank you but i do have the manual .i need the schematics for the xr 8600, or the site to download from
Internal fuse. Or fuse near the speaker connections.
Remove power. Remove back cover look for
125v clear or ceramic fuse.
125V 5x20mm Fast-Acting Glass Fuse
Dec 07, 2014 | Peavey Xr 8600 Xr8600 Powered Mixer...
Peavey xr 8600 about 6 yrs old used weekly heard a loud pop them a low emiting hum no sound comes thru .... is it time for a tech ? or dose it sound like an easy fix like fuse or something power on board...
Check the caps in the PSU, these give out over time although not normally when used regularly. You may be lucky and be able to see one or more with bulging tops. If you can replace them and all MAY be OK. Whilst in there check for any visible signs of anything burnt or blown. If it looks too bad or there is nothing obvious it's a trip to the repair shop for certain.
Oct 05, 2013 | Peavey Xr 8600 8 Channel Powered Mixer
How can you tell if a fuse is blown on a XR 8600 power amp by peavey?
The fuse is probably placed near the power cable entrance in the power amp.
Pick it up from it's placing dock and look for the wire inside. If the wire is whole, the fuze is fine, however, if the wire inside the fuze is missing or burned, the fuze needs to be replaced.
Jan 27, 2013 | Peavey Xr 8600 8 Channel Powered Mixer
My Stereo won't power on. Is there a fuse for that?
more than likely blown fuse,,,common problem..
Aug 22, 2012 | 2007 Saturn Aura XR Sedan
I have 110v XR 1220 power mixer and friend of mine plug into 240v power point, blown the two transistors ou. I do not know what short of transistors are they?
There are dozens of transistors in the unit... we can't guess which you might be refering to. The power supply of the 1200 series mixers have fuse before each part of the supply for the preamp sections.
Jul 13, 2011 | Peavey XR 1220 Powered Mixer Mixer Powered
I use my Peavey XR 8600 with an acoustic duo that I'm in. At my last show, an audience member grabbed and dropped a vocal microphone that sent a sharp sound through the Peavey and shut it down. When I...
Chances are one of the power amps has shorted. Replacing the fuse probably fried additional components. Unless you are electronically adept this is NOT a DIY repair.
Expect that this is going to be an expensive repair as often quite a few transistors and other components fry when one goes in these power amps.
Mar 09, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
My xr 10x lost power last night, stopped dead. No
make sure the lamp door is engaging the safety switch. if it is then the a/c input board is bad or the power supply.
May 15, 2010 | Office Equipment & Supplies
Xr-p21 electric failure in spite of correct electric connexion CD player doesn't work any longer, no lighting of the red led, no information on the display pannel, no totation of the CD platform ;...
the problem is supply of your player.. try to test the fuse of power supply.. if its ok., check 100 ohms resistor supply for power out put.. by jhuntech17
Oct 26, 2009 | Audio Players & Recorders
Flasing red light
The flashing red indicates that either the fileter cover or the lamp cover is not installed correctly. If both are installed properly and secured, the unit will require service.
Dan
May 09, 2008 | Sharp XR-10X Multimedia Projector
Aiwa XR-H33MD Shelf System Logo
63 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
