Question about Maytag UMV1152BAS Microwave Oven
We have a model # mmv1153bas over the range microwave. When heating or cooking items longer than a couple minutes the unit shuts off and remains off for at least 1 hour. It is not the breaker or the plug and the unit does not appear or feel hot. It is less than 2 years old - why is this occuring and what can be done about it.
  • Maytag Master
  • 9,085 Answers
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
An overheating magnetron can be due to:
  • operating oven without cover(s) in place
  • wrong magnetron installed in oven
  • an old or otherwise failing magnetron
  • cracked magnetron magnet
  • improper power line voltage (should be 110-125VAC)
  • foods low in moisture (popcorn & bacon, e.g. - add 1/2 cup of water in rear oven)
  • failed or inoperable cooling fan or hood vent exhaust fan
  • deteriorating foam weatherstripping seals in air ducts or on outside cover
  • blocked air vents (dust, animal nest debris, insufficient free air space behind & around oven, etc.)
  • clogged or greasy charcoal filter or grease filter
  • blocked duct in hood vent exhaust
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
It is vital that the cooling fan runs, or the magnetron will be destroyed. Repeated shutdowns like this are endangering the magnetron, assuming it's not bad already.
Your owner's manual will cover checking the filters and will cover warranty terms. The magnetron may still be covered.
If for some reason you don't have your manual, you can download it here.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 28, 2010
Our microwave, a (built in cabinet with venting), will tend to shut itself down if we cook something longer than, say, 8 minutes straight. No power, lights on panel out. Then a few minutes later i
Not enough venting. Imagine putting your hair dryer on full and putting it that cabinet. Would your venting keep it cool? Your microwave oven uses about the same current
Dec 20, 2014 | In Microwave Ovens
Our microwave, a Summit OTR 24 (built in cabinet with venting), will tend to shut itself down if we cook something longer than, say, 8 minutes straight. No power, lights on panel out. Then a few...
Sounds like the electronics overheated. You'd have to pull it and examine the insides to see what has gone bad. It could be pretty much anything.
Food in microwave is burning on edge and cold in the center
you may find the old unit was lower watts so took longer & cooked/heated better all the way through. a way to fix this is lower temp settings or pause and stir the food to help heat it up more even.
Dec 29, 2013 | KitchenAid KHMS2040BSS Stainless Steel...
Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
Shuts itself off mid cooking cycle -- as if unplugged; then after 5 minutes or so turns itself back on as if it was just plugged in (forgetting all previous settings)
If you just put the fan blade back on, it will almost certainly fall off again.
The best bet is to slightly rough up the contact area of the shaft with sandpaper and use a little super glue to hold the blade assembly on the shaft, and let it set a few minutes before using it.
I always recommend that you use the hood vent exhaust fan when cooking on the stove top to keep heat, steam, and grease out of the controls.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
May 20, 2009 | GE Profile Spacemaker Over-the-Range...
Quit heating
This is a sure sign that the Magnatron has burnt out and needs replaced ( This is what cooks the food!) Replace magnatron in oven unit and all should work well!
Please rate my response!
THANK YOU!
Jan 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM240 microwave - shut door, fan runs,can't set timer or cook
The "main" relay on the control circuit board is stuck (shorted) and needs to be replaced.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Dec 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Over the range microwave
I would return the unit and get a different model or brand if possible.
Jul 07, 2008 | Microwave Ovens
After heating beverage, turned off microwave before the three minute cooking cycle was up. Closed door and did not push any button. Shorlty after, the air smeleed of burning rubber and sensor error went...
Please reply back with your brand and model number so we can help you.
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Jun 05, 2008 | GE Microwave Ovens
Maytag UMV1152BAS Microwave Oven Logo
183 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
