Question about Intel Xircom CreditCard Performance Series (PS-CE2-10) Network Adapter
What does RBOUT of balance mean when you are settling charges
What does must settle TSYS MEAN WONT TAKE CARD
This means that the batch file needs to be settled before more transactions can be made. Do a batch download and this should solve your problem. If you need more help call. Frank (775)338-6634
Sep 19, 2014 | VeriFone VX510
How do you calculate and charge interest on outstanding accounts
That question is much more complicated than you think - are you charging interest percentage daily? Weekly? Monthly? Anually? Once you have the period figured, you begin at some start point of your choosing. Exactly one "period" later, you multiply the basis (the outstanding balance) by the percentage rate (5%, for example, would mean you multiply by 0.05), then add that number to the basis - that's your new basis, your new outstanding balance.
But... if you charge an annual interest rate, and you compound daily or weekly or monthly, you have to take payments into account and adjust for them - it's fair to charge interest up to the moment of payment, but not beyond that moment; you can rightly only charge interest on the remaining unpaid balance beyond that date.
If you charge an annual interest rate but compound monthly, then every month you'd charge 1/12 of your annual interest rate. If weekly, 1/52. If daily, 1/365. The smaller the compounding period, the easier it is to calculate interest around payments, but the more paperwork is involved.
Jul 14, 2014 | Office Equipment & Supplies
Washer is always of balance
Is the machine level? Does it rock if you push down on any corner? The machine must be level with all 4 feet firmly settled on floor. If you are satisfied level is good then open the loading door and move the tub back and forth (kind of vigorously, but no need to get carried away.) You should hear sloshing sound from the balance ring. If no slosh balance ring will need replaced.
Dec 29, 2012 | Whirlpool WTW6400SW Cabrio Washer
CANNOT SETTLE PARTIAL PAYMENT ORDER
Please contact the vendor or company you are transacting with as for sure they have problems on their website.
Jun 30, 2012 | Computers & Internet
Hypercom t7p RBOUT OF BALANCE error
What that means is that there was some sort of communication error in the machine. In my case, a credit card payment went through to the merchant services but not through my machine. The balances did not match. Call the customer service number on your machine and they will fix it within a minute!
May 10, 2012 | VeriFone (M19755014US1) Magnetic Card...
HOW DOES 0% APR MEAN WHEN CREDIT CARD IS OFFERING A BALANCE TRANSFER?
Your posting in the wrong thread but APR means "annual percentage rate" means you get no interested charged to the balance you are transferring from your old card company.....
Aug 23, 2011 | Computers & Internet
Please settle a dispute with my husband. my washer has an off balance load. do I have to remove things, or will adjusting the load eventually work to even it out?
the off balance sensor won't adjust the load,, it will notify you if the load is so far out of balance that it needs to be re adjusted . I hope this reply doesn't effect the rating I will receive :)
Jul 19, 2011 | Maytag PAV2300 Top Load Washer
Hi I have a Maytag Neptune model MAH5500BWW Serial B4585662GA. When I turn the drum, I can still hear water inside/behind the drum. Thank you
This is normal. There is a balance ring filled with water attached to the inner drum. The balance ring is sealed and is not supposed to be empty. When you turn the inner drum by hand, you're hearing the water settling down from the now upper chambers of the balance ring.
Oct 14, 2010 | Maytag Neptune MAH5500B Front Load Washer
Nurit 2085
This is most likely cause by a crupt transaction or a transaction that is not aloud stuck inside the terminal. Once you batch out contact your processing comapnyask them if they see you current batch you jut settled. If so they will need to clear the the terminal and up the batch number. Just make sure all of your sale are settled with your processign comapny before you go ahead and clear the terminal.
May 14, 2008 | VeriFone (M19755014US1) Magnetic Card...
Intel Xircom CreditCard Performance Series (PS-CE2-10) Network Adapter Logo
1,724 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
