Question about Dryers
How do you change the belt on the dryer?
My dryer is squeeking when it's drying. Could that be the dryer belt? If so, how do you change the belt on a Maytag dryer?
  • Dryers Master
  • 7,482 Answers
Your problem sounds like drum rollers are in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.Also remove the screws holding the lint filter in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please do not forget to rate me,
Thank You
Posted on May 26, 2010
Very squeeky dryer, starts out quiet then intensifies through the cycle untill it can be heard from outside; has a rhythmic squeek.
The belt is probably rubbed smooth. Since you already sprayed it, after the spray dried out, it starting squeaking again. I suggest examining the belt and replacing it if necessary.
Mar 22, 2016 | Dryers
Aerosmart dg62t27dw2 belt squeeking and making clothes stink
Your belt is not on the pulley correctly. You will likely need to purchase a new belt as the damage has likely been done. Remove back cover and then remove casing (video on youtube) Replace belt. You may be able to fix quicker by flipping dryer on side and replacing the belt from the bottom, but it is a tight fit.
Jan 12, 2014 | Fisher Paykel Fisher & Paykel AeroSmart...
Belt squeeking
Dirt builds up in a dryer over time, belts wear and wheels that the drum rolls on can be worn. Once found a pager in a dryer. There is loose change and pencils and... taking the dryer apart, cleaning and lubricating and replacing the belt are maintenance items that are often ignored. Inconvenient, yes. Dirt is the enemy of mechanical equipment and dryers collect dirt and paper and anything left in pockets of clothes. A vacuuming and general clean and lube helps. Check for free rotation of the drum before and after and make not of the level of resistance with the dryer empty. Some other parts such as the drum wheels may have worn spots. Do it as soon as possible. DIY or a pro. If they let you watch, then you may be able to do some of the lighter work for yourself the next time. Or check out a DIY appliance repair book.
Loud squeeking noise when dryer starts and continues while it is drying
Greetings,
the belt pulley needs some lubricating..they squeek and the rollers thump...of coarse, its possible a stuck roller can squeek...The front needs to be removed..UNPLUG machine and if you have a removable lower access panel..this can be removed and lube the belt pulley.
if no bottom front., remove filter screws and raise top. there are two screws inside of front.Remove the front and you can lube or change parts as needed...
Jan 25, 2011 | Kenmore 66832 Dryer
Squeeky dryer
belt is stretched from a worn bearing in the belts idler pulley
Replace the belt along with the pulley sold at most Sears stores
Jun 20, 2010 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
My GE gas dryer makes a loud squeeking noise running
WE 3X 75 is the part number you need. Take a look at these repair pix
Sep 09, 2009 | GE Dryers
Squeeking while dryer is drying
i would suggest calling the repiar. The longer you wait the more expensive this will be. One of two things is happening. One, bearing is going out, or most likely the belt is slipping on the drum and needs replacement. Good luck
Jul 09, 2009 | Dryers
Maytag gas dryer makes squeeking noise
it is more likely one of the drum rollers
Dec 20, 2008 | Maytag Dryers
Squeeking in lower dryer
remove the rear panel. unplug dryer before doing anything
Oct 24, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
118 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
