Question about Wordlock CL-400-BK 4-Letter Combination 6-Foot Cable Bike Lock, Black
Forgot combination to bike lock - Wordlock CL-400-BK 4-Letter Combination 6-Foot Cable Bike Lock, Black
How do I reset the word lock bike lock when I forgot the word I used last.
You can't reset it if it is currently locked together. You have to try to "crack" the combination.
184 WordLock Combination AVOID THIS LOCK
Wordlock pick
Apr 14, 2017 | Cycling
Sunlite bike cable lock. I opened the lock and now cant put the male end back into the lock because I forgot the combination
Well, the lock is not any good if you don't know the combination, but for a barrel-type combo lock, if you accidentally turned the numbers while open just push the male end in and turn the 1st ring until it goes in slightly. Then turn the next ring and so forth until it's all the way in. Now you can see the combination.
Apr 14, 2017 | Sunlite Cycling
How to unlock Schwinn Caribiner 3 digit Bike Lock. I forgot combination.
If it is open like that, possibly, if it is locked, no, garbage.
Oct 31, 2015 | Schwinn Cycling
How do I open a lock that I forgot the password
You have to try all the combinations. Start with 1111, then 1112,1113,and so on.
Sep 27, 2014 | Wordlock CL-454 4-Foot x 6mm Word Combo...
Forgot my Presto Lock combination!
You cannot reset the lock unless you know the combination. You would need someone to pick the lock, like a locksmith and then once it's open you can reset the lock with a new combination.
Jan 25, 2013 | Locks & Locksmithing
I forgot the combo for my Kryptonite bike lock US PAT 593412/6422051, can you please help? Thank you
Another way is to pull apart the ends till you have tension on the tumblers. As you place tension try to turn the tumblers. As you feel each loose or tight tumbler is how you can find your combination. I open this type of combination lock like this all the time. First look for the tightest tumbler, turn it until it feels looser and next look or feel for the next tight tumbler. All the tumblers do not block the release at once. You are looking for the first tumbler to adjust, the tightest one, then the next, continuing until you find you have released all the tumblers. This has worked for me with any brand of inline tumbler release system out there. Good luck, usually takes me about 10-15 minutes to find the code. This method can be used on regular locks with a changeable combination as well. It will just take a little time to get to know how much tension to use as you go through each tumbler. Similar as to how you pick a regular lock system. Good luck, definitely doable.
Jan 24, 2013 | Kryptonite Cycling
I have a master lock bike lock and I forgot my bike lock combination and its locked
You can pick the lock by slipping a pic down the locking side of the "U" bar. if you have a pic designed for it. ( located here http://www.i-hacked.com/index.php?option=content&task=view&id=189 )you can make then your self.
Mar 23, 2011 | Cycling
I forgot my combination on my kryptonite bike lock
Thanks Chris Wheeler, I tried unlocking my kryptonite kryptolok and with your suggestions i did unlock it in a minute...its 0005
Aug 15, 2010 | Kryptonite Kryptoflex 1218 Combo Cable...
I forgot my code
I have the same issue. I just bought a bike and dug out my old bike lock from college. Obviously the codes I'd being using now are not what I programmed my bike lock originally with. Any suggestions??
I've been trying to listen to the lock when I rotate the numbers and crack the code. Not a fun task.
Sep 29, 2009 | Kryptonite Kryptoflex 1218 Combo Cable...
Resetting combination bike lock
Try rotating locking device 180 degrees and hold it down and set combo to 0000, then let up on locking bar. That should clear the old combo. To reset, rotate the device 180 degrees and hold down while inserting your new 4 digit code and then release it.
Jan 31, 2009 | Mongoose Toys
Wordlock CL-400-BK 4-Letter Combination 6-Foot Cable Bike Lock, Black Logo
48 people viewed this question
Top Wordlock Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Wordlock Lock and Locksmithing Expert? Answer questions, earn points and help others
