Question about GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
No water will come out of the door
The ice will come come out of the door but no water will come out. I'm not sure if this is the exact fridge because I don't have any papers on it
  • GE Master
  • 1,606 Answers
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . GE has a dispensor heater pt. # WR41X10173 to stop this freezing and it comes with instructions .
Posted on May 26, 2010
Testimonial: "Thank you so much !!!! Hopefully it will thaw now and thats all it is. "
  • Mike Smith
    Mike Smith May 26, 2010
    Turning on the dispensor light for several hours has also helped thaw the line .
  • 24 Answers
There are several possible problems. It could be a bad water valve, a bad switch in your dispenser area, a frozen water line, or a bad control board. Water valves are almost always located on the back of the refrigerator in the bottom right or bottom left corner. Usually it helps if you remove the lower panel first. Always unplug your refrigerator before attempting to service it. You should see 2 tubes coming out of the water valve. One will go to the ice maker and one will go to the water dispenser. You can try disconnecting and blowing through both tubes to check for a frozen line. A bad water valve is the most likely cause.
Posted on May 25, 2010
3 Suggested Answers
aasc
  • 1606 Answers
SOURCE: Hotpoint fridge dispenser works on water but not ice
If the little green lites show up , you do not need a circuit board . If you get a hum or buzzing noise when pushing for CRUSHED ice , then the auger motor is frozen up . Remove the ice bin and use a hair dryer directly on the forks which turn the dispensor . The heat will transfer into the motor , defrosting the armature . Try closing the freezer door ocassionally and pushing the arm to test if forks turn .
Posted on Aug 09, 2009
2coolrick
  • 560 Answers
SOURCE: Fridge is making Ice and
. Check your water filter first . On some models , only the drinking water is filtered . I don't know which model you have therefore you'll have to check and see if your ice maker water supply is filtered or not . If it is not , that is probably a bad water filter you have . However , if it is , I would check the supply line from the chiller located in the refrigerator compartment usually on the lower right hand side at the back of the compartment . The problem could be a plugged supply line from the chiller to the water valve on the door .
Posted on Mar 10, 2011
Replaced water filter, dispensing valve on frigidaire gallery side by side still no ice or water
It may very well be frozen. Some of those fridges have problems with the line freezing because of the way the line runs. The one way to tell would be to empty fridge, unplug, and let sit to thaw. Opening freezer/fridge doors will shorten the process. You can Google your exact model number also, and find out how your lines run and use a hair dryer on that location.
Mar 07, 2016 | Frigidaire Refrigerators
We replaced the ice maker in our Samsung refrigerator and now we cannot get the water to dispense once we cut the water back on. What do we need to check?
By your question, you are saying you are not receiving water from the water dispenser. Make sure the electrical connector you disconnected when making the ice maker repair is securely re-seated. If you removed the door to make this repair, there is also a connector at the top of the door make sure it is also seated. The only other connection for water or ice delivery is at the water inlet at bottom rear of fridge. There are two relays at the water inlet, one for water, one for ice. If these were disturbed recheck that they were reconnected. Of course these checks should be performed with the power cord disconnected to prevent shock. Once all is checked, plug fridge back in. When dispensing water you should hear a solid clunk as the relay engages. As for the ice dispenser you will only hear the clunk as it requires water to fill the tray. Just remember to allow for two complete cycles (fill - freeze - dump) before receiving full cubes. Oh, by all means don't forget to make sure the Ice bucket full lever (Usually a thick wire) running the length of the bucket Is in the down (empty) position. If it is up, this turns off the ice maker indicating the bucket is full. New ice maker units usually come packaged with the (bailer wire) in the up (off) position.
Hope this info helps!
Dec 28, 2014 | Samsung RS2630SH Side by Side Refrigerator
When i close the door on the freezer side the water trickles down the front panel
This could be a leaking water valve. First thing I would suggest is to turn the water supply off under the sink or behind fridge wherever its located and see if the leaking stops.If so then you'll need to replace the water valve on fridge. If this doesn't work look up inside the ice chute on front of door and make sure the flapper is closing all the way when you get ice. Warm air coming up into freezer because the flapper is not sealing tight can cause water to run down front of fridge.If this is the case there is usually frost buildup on the ice chute on the inside of door.
Oct 25, 2013 | Refrigerators
Do i have to hook up my refrigerater to the sink to get water an ice
Yes you have to connect the water pipe from sink to refrigerator back.hen turn ON the water valve o run the water from fridge to freezer section.Form freezer section to water inlet valve at the back of ice maker.Then only ice maker and water dispenser will function.Other wise only freezer and fridge will work.-------------- If you dont have water tube and water valve then You can get required parts from www.repairclinic.com or from online sears part site. If you are not aware of how exactly to set and connect water valve and water tube then local plumber or fridge repair technician can do it for you.Its not at all hard job and can be easily done.It will take near to 15 minutes to connect all parts.------------- Thank you.
Jan 31, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Leaking water from the actually fridge over the floor.
manually fully defrost unit,clean all vents /drain pipes
make sure door seals touch all round(no air gaps)
use bicarb to freshen interior and dry as best you can
then switch on and hopefully,if unit is working normally,enjoy...only place cold food in fridge to minimise ice build up.(some fridges have a drain vent in the centre bottom of door to allow water to drain when defrosting
Feb 14, 2010 | Refrigerators
Ice maker does not make enough ice - it doesn't fill up the bin
check for water in ice maker with finger and if no water check water connection and water valve in back of fridg on bottom . you need to pull panel and check valve and water make sure it is on and not leaking...
Aug 12, 2009 | General Electric GFSS6KKXSS Stainless...
No water at door (or ice!)
first off manke sure t hat yo keep the paddle depress fpr a few mins, it will need to fill a resevoir inside the regfrig sect, may take am in beofre the water flows freely
Mar 08, 2009 | Frigidaire Refrigerators
Amana Side-by-Side Fridge Model SBD21VPSE Problem started when water stopped flowing from in-door dispenser and ice maker stopped making ice. I emptied fridge and freezer, left unit off for several...
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Nov 29, 2008 | Refrigerators
No water to door
Did you change any settings resently or move the fridge? Water line could be kinked. Could be a frozen water line. If the ice maker is set on rapid ice, turn it off. You could turn the temp setting down for a day to see if that helps. Do you have any leaks behind or under the fridge? Check the filter again, make sure you pulled the shipping tag off and that it is seated properly. Freezer temp could be set too cold. Make sure the freezer door closes properly and that there isn't anything hendering it.
Jul 07, 2007 | Kenmore 56722 / 56724 / 56726 / 56729
GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
467 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
