Question about Briggs & Stratton Garden
B&s 3.5 while im mowing and at a ideal it revs up and down
    President:
  • Briggs & Str... Master
  • 1,545 Answers
This condition occurs sometimes in engines that are experiencing a "lean" fuel condition. The remedy is to thoroughly clean the carburetor.
Posted on Jun 13, 2010
When i start mower it will rev up then down die or rev back up while blowing white smoke.last time i mowed 2 weeks ago it was fine?
The white smoke can indicate oil consumption. Was there a mixture in the gasoline? If not tthe piston rings may be affected. Also avoid gas-Ethanol mix which attracts humidity, turning into water.
Jul 11, 2015 | Garden
Got 87 Chevy 4x4 350 TBI at ideal it rev up and down when driving down road its like you turn key off but picks back up for a second then stalls again the motor has 3,200 miles replaced dang near...
Sounds like multiple problems. rev up and down at idle sounds like vacuum leak. shutting down while driving sounds like loose wire in the ignition system or possibly in the fuel pump.
Jan 30, 2015 | Cars & Trucks
Car jumping during gear change
Several possible causes.
1.Erattic or high line pressure
2.Electrical fault at solenoids (EV5 on 01N, 01M and01P boxes)
3.Hydraulic malfunction with same solenoid
Nov 30, 2012 | Cars & Trucks
5 ' brush hog boggs down when attempting to mow & one blade hits underdeck in one place
sounds like that blade is bent also if they are dull it will bog down more
Jul 05, 2012 | Garden
17.5hp OHV Briggs & Stratton w/ Nikki Carb sputters & backfires thru carb & muffler
Hi, run a number drill through the main jet. Even though you have carby cleaned it a thin layer of residue will remain on the walls of the jet. The problem you have is a lean misfire. Regards Phil.
Jun 11, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have low exceleration when i take off
Only recently has my 97 Honda Passport been acting like the transmission slips...I'll be in Drive and the revs jump from 2 to 5 or 6; I'll drop it to 3, and it settles down. Last week, I was in Drive, then went to 3...then back to Drive and it jumped...and the Check Trans light came on.
Jul 17, 2010 | 1997 Honda Passport
19.5 Briggs & Stratton dies while mowing
the engine is getting to hot or the oil level is to low check to make sure the engine is getting the air that it needs while running they have air vents in hood as well as on sides of most of those tractors or i would mow for a while & put in a cool place to cool down if i can further help e-mail me wade at wadembly@aol.com
Jun 28, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Mower bogs down in medium high gras
what is happening is there is tomuch grass in deck & not discharging as fast as it cuts it if deck is ajustable put it on high setting then try if it works then got back over it with a lower setting this is most likely the case to much grass in deck while mowing blade gets cought up alot with alot of grass in deck
Jun 05, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
87 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
