Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Leaking from the front
Dripping from the front edge when running.
took off front cover nothing appears to be leaking underneath.
looks like maybe the door seal that wraps around the edges.
How hard is it to change?
I had same problem but different model #.
The part under the spray arm came lose and the gasket was hanging out. Causing it to squirt water right at the bottom of the door and leaking out. I took it apart put the gasket back in the groove, screwed it back down and is working great.
Posted on May 28, 2010
I have a leak from the bottom of my freezer. IT seems to be coming from the front left edge corner. Dripping down the adjustment screw leg. I just cleared drain line so its not that again. This is ano
That's where the drip pan is for the underside models, other than that it's likely a leaky door seal on that side or the case heater went out letting it sweat.
Apr 01, 2014 | Admiral 26 cu. ft. Side-By-Side...
Anti-freeze leaking from the drivers side
bad hose or freeze plug it could be a lot of things. The coolant runs all through the engine.Maybe water pump gasket.
Jun 06, 2013 | 1996 Jeep Grand Cherokee
Water leaking underneath the motor
A little leakage is normal. Also the A/C will drip water, but that comes down from the firewall area.
From the motor, it may indicate a leaky water pump. This will drip from the front of the engine which is the right side as the driver looks. The pump is located under the timing belt cover.
Also check all your large hoses to see if a leak has developed at any joint.
The V6 engine often develops a water leak under the intake manifold which is hard to see. The water appears on top of the transmission. Camrys will often also get a split in the plastic radiator top tank, so look there.
If you are not losing large amounts of water, you have a while to track it down at leisure !
Feb 07, 2012 | 1994 Toyota Camry
How to repair oil leak for 1995 C200 Mercedes Benz? Looks like the leak is dripping down from underneath the engine onto the oil drip pan.
OIL LEAK COULD BE COMING FROM OIL FILTER SEAL. OIL LEAK FROM THE REAR OF ENGINE COULD BE REAR MAIN OIL SEAL.LEAK IN THE FRONT OF THE ENGINE COULD BE FRONT CRANKSHAFT TIMING COVER SEAL LEAKING OIL.
May 30, 2011 | 1995 Mercedes-Benz C-Class
I have a 96 plymouth neon and it is leaking tranny fluid where could it be leaking at
Look at the front and rear seals and the drain pan gasket. Maybe put a drip pan or large piece of cardboard underneath car after running it until it is warmed up.
Jan 25, 2011 | 1996 Plymouth Neon
Washer appears to be leaking towards the top back right..
sounds like your main tub seal is leaking, also check the hose running to your water level switch,,and your outter plastic tub could have a crack in it
Feb 15, 2010 | GE WBSR3140DW Top Load Washer
WHY WOULD RAIN LEAK IN NEAR FRONT DOOR? ALL SEALS
Some leaks actually are from the windshield and it is contained by the trim so you can't see where it is leaking from. If it is the door seal look at the striker bolt to see if there is any abnormal wear. Make sure the striker bolt is aligned with the door striker. If you don't know how to check this run by your local body shop and ask them to check it for you. Sometimes if the keys have ever been locked in the vehicle people use door shims to hold the door open as to pick the lock. This is bad because it knocks the door out of alignment with the seals. Hope this helps.
Feb 06, 2010 | 2006 Jeep Liberty
I have a 2001 Isuzu Rodeo 4x4 with 3.2 dohc. Transmission is leaking, I brought a oem gasket for the front and back replace the filter. The front pan is still leaking. Try different silicone base gasket...
Yours is leaking from the round side servo cover. A quick fix for someone that knows the correct way to put them in. It is held in by a snap ring and a big spring is underneath it pushing it out. So it must be pressed down to remove and replace the snap ring. A common problem for these vehicles. They will drip on the edge of the pan and make it look like it is leaking.
Oct 07, 2009 | 2001 Isuzu Rodeo
Drips from center of front cover when filling at 3-4 inches
after carefully reading this, the leak is at the machines water valves, or from them to hose to tub.
Sep 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
199 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
