Question about Delta Plumbing
How do you adjust the hot water on a shower deverter
  • 34 Answers
Diverter valves don't regulate the temp at all they are used with a standard shower valve that regulates the temp and the diverter selects the shower head/body spray/Rain head or whatever configuration you have. This valve can't be used on it's own.
Posted on Jun 08, 2010
No hot water - thermostat not working
if u have a single handle shower unit remove handle and cover to access the water adjustments[scold protection] blue is cold red is hot faucets are shipped in coldest setting as a safety precaution need to adjust in the hot water
Dec 03, 2012 | Home
No hot water
need to adjust anti-scold when unit shipped is set for cold if u have install paperwork that has info on how to adjust if not remove handle and on valve stem will see blue and red plastic clips slid them forward and adjust till hot water is adjusted to liking
Jul 25, 2010 | Moen & One Handle Tub & Shower Faucet
Temperature too hot on bristan art deco mixer shower even on lowest temperature setting.
if the water is that hot then lower [adjust] the temp of your hot water heater -if need to adjust the shower you can adjust the mixing by removing the handle and on the valve stem are the adjusting clips the red [hot] and blue [cold]plastic clips can move them around to adjust the mixing of hot and cold water
Jul 23, 2010 | Home
& One Handle Tub & Shower Faucet : i have a moen shower faucet and i get not hot wate...
these valves can be adjusted by removing the handle and adjusting the white gear that regulates the hot and cold that come out, try going more to one way if it gets colder then go the other way.
May 16, 2010 | Moen & One Handle Tub & Shower Faucet
When turning on the shower faucet there is no hot water.
adjust ur anti scold the setting is set to low when single handle shower units are shipped they are set in cold mode for safety ur install/instructional paperwork explains such and also advises on how to adjust---remove handle and on shaft will see a blue and red plastic clips that are adjustable slide towards u and move red for more hot water test water continue till comfort level is reached for hot water
Mar 24, 2010 | Kohler K-T12007-4s-BV Brushed Bronze...
No hot water in bathtub
its called ur anti-scold system its installed in all single shower units to adjust remove the handle and will see usually a blue and red adjustment clips move the red so more hot water can be mixed in try the water adjust until comfort level is achieved
Mar 11, 2010 | Delta & Single Handle Shower Faucet
Hot water pipe hot going into mira shower but no hot water coming out
need to adjust the anti-scald [protection] new systems are shipped in cold position and u adjust it to ur comfort
Feb 15, 2010 | Water Pik Hand Held Shower
When I turn the water on for a bath only water
the water deverter that makes water come out the shower head is probably in need of repair. or replaced.
Dec 04, 2009 | Moen & One Handle Tub & Shower Faucet
Water is either hot or cold - no in between.
I found a way to get warm water in the shower, but I'm not sure it qualifies as a solution. After trying everything else I thought that maybe when I was feathering the faucet in the shower toward the cold side so I would get warm water that at a certain point it blocked the flow on the hot water side enough so that the sensor in the hot water heater sensed there was no demand in the line and it shut the water heater off. To test this, I went to the kitchen and turned the kitchen sink faucet all the way to the hot side and then turned it on so that I got a small flow of water. I waited for the water to get hot to be sure the hot water heater was working. Once it was hot, I left it running to keep demand in the line and then I went to the shower and turned the faucet on. When the water got hot I started feathering the control towards the cold side and soon I had warm water. So I think I'm right in that the sensor in the hot water heater was shutting the water heater off when the demand in the shower was lowered to a certain point when I was trying to adjust the water temp in the shower.
So now I can get warm water, but it means I have to leave the hot water running at another fixture in the house to create a false demand in the system so the hot water heater doesn't shut down. Is there a way to adjust the senor in the hot water heater so that it will stay on when I'm using the shower only, so I don't have to waste water by running another faucet when I want to take a shower?
Nov 28, 2008 | Water Heaters
Plumbing Logo
173 people viewed this question
Top Delta Plumbing Experts
Donni Steen
Ed Mac
john h
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
