Question about Garden
Need a replacement part for PRESSURE WASHER model CJC-1007. Part--> Water Cleaning Hose (15 MPa / 2200psi lopesflhs@yahoo.com Please give instruction on how I can order on line or any other method of getting said hose.
  • 10,865 Answers
Hello. Look in the local yellow pages under power washers as you may have a shop in the area that has or can get all parts. If not go on the computer to SearsDirect.com. This site is excellent and has most parts. J.
Posted on May 25, 2010
Craftsman 2200PSI pressure washer, part #580.752700 dies when trigger off.
NEVER start an engine on a power washer with pump attached. You will damage pump and get no or very little pressure. Replacing pump only fix. Pump for this washer about $49. Check spring on carb for throttle open/close
Jun 10, 2016 | Craftsman Garden
Hose on cjc-1001 pressure washer is leaking. Need to buy new one but cant find a distributor
http://www.watercannon.com/c-11-hoses-pressure-washer.aspx here a link to a site that sells high-pressure hoses. almost all hoses are similar when it comes to pressure washers, just by the right attachments and you'll be good to go.
Apr 05, 2011 | Garden
I bought a honda pressure washer power boss 3000. I load the gasoline, start the machine, but pressure water is not coming out from the trigger. i tried so many things , but can t get started.
If you are using a water tank for water supply, remove the water supply line from the pressure washer and connect a water hose from a faucet. Turn the water on, then crank the engine. Pull the trigger of the spray gun until water comes out. When then water starts to spray properly the release the trigger, shut engine down with pressure on the line then reconnect the water supply from the tank to the pressure washer. If this fixes the problem then the problem was "air-locked"! Happens alot with new pressure washers that have never been run. If you need any other help, please email me @ davidandlisacampbell@yahoo.com
Feb 18, 2011 | Honda Pressure Washer PSI 3000
My Karcher 2400 Pressure Washer will not syphon cleaning fluid. I have a reconditioned machine and the syphon for cleaning fluid has not worked for a while.Everything looks clean but still does not work'...
The black tip nozzle puts the right amount of pressure on the line to draw up the cleaning solution.
If your power washer is like mine, the cleaning fluid adapter is a 'T shaped' brass valve that fits in-line along the hose line.
There is a brass stem sticking out.
The stem has a tiny ball valve on the end.
A plastic hose fits onto the stem, and the plastic hose goes into bucket of cleaner.
As water travels through power washer hose, it creates suction that draws cleaning solution through the tiny ball valve.
The brass ball valve gets clogged or wears out ... we used to replace the stem every so often.
Sherwin Williams used to carry a replacement stem ... but they may not sell little parts any more.
It's been 14 years since I used the suction device.
I got fed up with the thing not working.
We changed over to a pump-up hand-held sprayer for applying cleaning chemical.
The pump-up puts more chemical on the spots where you need it.
So one guy puts chemical on, and second guy comes behind with power washer ... no more replacement parts, and one tip stays in the gun so we never lose a tip.
A pump-up sprayer is half the cost of replacing the T-shaped valve.
Duh-simple is the business model.
Nov 17, 2010 | Karcher Garden
Tub over flowed. Never went into the wash cycle!
This problem is commonly attributed to a malfunction with the Pressure Switch (also known as a Water Level Switch). The pressure switch is located behind the load size selector knob on the operator console. Before assuming the switch to be bad, however, you need to check the small plastic air hose that attaches to the switch inside the console to make sure it is still connected and does not have any cracks or leaks. The following link explains:
http://www.fixya.com/support/r3575901-washer_overflows
The small air hose needs be attached to the pressure switch and have no holes or cracks. Without the air hose attached, the pressure switch will not detect the pressure differential from the wash tub as the washer fills. This is the most common cause of washer overflow problems. It is recommended that you check the entire length of the hose to be sure. If you need to access the interior washer cabinet components, this model washer is designed so that the exterior case comes off. The following link explains how:
http://www.fixya.com/support/r3631789-washer_case_removal_whirlpool_top
If the air hose is intact, then it is recommended that you replace the pressure switch. Replacement parts may be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites on the list also include exploded view parts illustrations to assist you with locating and properly identifying any parts you may need. If the model number is correct, the part numbers you may need are as follows:
Pressure Switch - W10335056
Pressure Hose - 353244
If you have any questions, please post back and let me know. I hope you find this information helpful.
Oct 18, 2010 | Roper RAS8445KQ Top Load Washer
I have a Premium Pressure Washer CJC-1001 2.3 GPM. I do not have a hose and wonder how this is attached to the engine. Is there instructions I can obtain for this? Thanks
Hello sir, my pr. washer is runing but with high quantity of dark fumes from the exahaust and high temprature in the engine.
Apr 21, 2010 | Garden
My kenmore top load washer will not stop filling with water i have replaced the inlet valve and checked the drain any other suggestions
Hi, there is a hose that conects the water level switch to the rear of the tub. Sometimes the the hose gets plugged with lint or old soap nd will not give the level switch a proper reading. The cup on the tub that the hose attaches to might need cleaned out as well. If there is nothing plugging the cup or hose, you might need a new water level switch. I hope this helps you. Please let me know if you need more assistance in this matter.
Thanks
Vic
Feb 12, 2010 | Washing Machines
Won't fillCalypso whirlpool washer model#GVW9959KQ1 LD on display
LD is long drain error, the machine does not fill because it is in fault mode, but error is on drain system.
If there is a drain problem, the parts that must be checked are drain hose, pressure switch, drain pump assembly, timer control.
Check if the drain hose at the back is kinked or blocked.
Test the pressure switch, blow into the small hose, and use a multimeter to check if switch has continuity.
Remove access panel and get to the drain pump hose to check for ablockage. You will need to disconnect the hose and collect the water.
Keep a container ready to collect water when you undo pump hose.
Ifall the rest is OK, test and eventually replace timer board.Problemwith water pump are far more commonly causing this problemsthenfaulty timer board.
Parts and diagrams available here.
Oct 13, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore 70 series washer model 82870120 will not stop filling
you need to replace the water valve. This is a common problem and a very easy fix. You can order the part at sears.com via model number and also see a breakdown of the machine and how to put it in.
Mar 03, 2009 | Kenmore 23822 Top Load Washer
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
