Question about Dishwashers
Conia dishwasher starts cycle ok but does not complete dial remains half way and machine keeps running
rickzilla
  • 706 Answers
SOURCE: dishwasher soap remains in the
Try cleaning the soap dispenser with white vinegar so that it is free of all detergent, then try using about 1/4 less detergent than you have been to see if you still have any remaining in the dispenser. Also, make sure your drain filter is free of all sediment so that the system can pump the water out freely. Lastly, if you are still getting some soap remains, then try using a sanitary setting that uses the hottest water and see if the excess soap is properly dispensed. Your water temp may not be getting hot enough so this test should help identofy the solution. Hope this helps !
Posted on Aug 20, 2008
SOURCE: problem with conia cdw1211 dishwasher
We have the same it says the heater elemet or temperature sensor is malfunctioning !
Posted on Sep 09, 2008
  • 276 Answers
SOURCE: water in the dishwasher after the the cycle is complete
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Posted on Nov 19, 2008
caroldon
  • 17129 Answers
SOURCE: My dishwasher washes and drains ok but there is
If the dish washerr is kept at a tilt, then it is possible that the pump never gets a chance to pump out. Use a good spirit level to set this right. If nott Please open your washer, open the outlet and check for any dirt accumulation, check to the pump for low action if so replace, check for the outlet for clogging, clean if the pores are dirty. I think this must solve the issue. Good day
Posted on Jul 08, 2010
rickead1
  • 1998 Answers
SOURCE: my Conia dishwashing machine didnt
can you please provide the model number of your machine? also try holding cancel for 5 seconds and if this doesnt work go to your breaker and try turning off the power for 7minutes this usually makes the control reset message me back if this doesnt work it only works on a few but its worth a try to start off if you have any further questions message me back and please remember when our chat has Fully Concluded to rank how this opinion has helped it allows me to help others with similar situations in the future Thank Rick
Posted on Feb 03, 2011
Dishwasher starts on its own (no house is not haunted). Start resume button flashes
have a service technician in as it appears to be a problem in the program board
could be moisture across the circuit board
Feb 06, 2016 | Maytag MDB7749AWQ Builtin Dishwasher
Dishwasher keeps running
That is a indication of a bad timer the timer is the nob that u turn to make it run drop door down take off the top six screws on the door from the inside then pull off the knob then there will be two screws behind nob and the time should come right out then once u get the new time pull off wires one by one to make sure u putt when in the same place
Jan 16, 2014 | GE Dishwashers
Drain pump goes ON when ON-OFF button is pressed, even if the know selector is in OFF position and the machine is dry. There is no fault codes and the dishwasher complete the washing cycle OK, but when...
Seems that the drain pump circuit in the main program controller unit power and keeps on as there is no logic feedback to cut off the power. It can be that the drain is clogged and so the water level detect keeps sensing due to a fault. check the sensors , check the drain filters , check the machine LEVEL so that the water drains clearly to the drain pump.
Aug 08, 2011 | Miele G7856 24 in Dishwasher
I have a haier dishwasher but the water wont drain out of it. the power light remains on but turning the settings dial has no effect - looks like the pump may be blocked. how can i carry out a factory...
you maybe right but before doing machine reset button, you need to clean the machine be sure there's no jam in mechanical parts. also not all machine have reset button outside, some are hide and inside the power supply module so look for it and be careful.
Feb 04, 2011 | Haier HDP18PA Stainless Steel...
CONIA DISHWASHER CDW1211 -Thelittle door that
i find it hard to get parts for these because the are imported from china.it may be better to replace the dishwasher
Jun 08, 2010 | Dishwashers
There is a smell in the dishwasher and on the dishes when clean
I suspect stagnant water is laying in the bottom areas. You will have to lay the machine on it's back to access the pump.
May 27, 2010 | KitchenAid KUDK03ITBK Built-in Dishwasher
Our Nautilus dishwasher won't turn on. I can hear a buzzing noise, but nothing is happening. Does anyone now what I should do?
The same thing happens with my dishwasher. I have made it work by doing the following. When you start up the cycle, turn the dial to just a tick before "start." If you hear the buzzing, but no water is running, unlock and then lock the dishwasher door again. This usually gets it running. If it's still not running water, unlock, advance the dial a little bit, and lock again. This should work. You need to be around for the early parts of the dishwashing cycle because this machine tends to stop up and buzz without running water until it gets past "short wash." Every time this happens, do the same thing, unlock and lock, and advance the dial a little when necessary. Once you get past "short wash," it should complete the wash without intervention.
Feb 22, 2009 | GE Nautilus 24" Built-in Dishwasher
Problem with conia cdw1211 dishwasher
Had same problem - was advised by service centre to remove secondary filter (round mesh cylinder in main filter on floor of machine) & discard it as it became coated with oil & caused the sensors to malfunction. Fixed the problem immediately.
Apr 12, 2008 | Dishwashers
NEFF S5456 DISHWASHER
Have you tried it on a different program? I have nearly always used the AUTO program - however i have used the 50 degree program 3 times now and it completes the (much longer) wash without sticking on one minute. Will try it on auto again to see what happens. I found it useful to turn the end-of-wash buzzer on (to loud) to remind me when (if) it completes the program.
Sep 30, 2007 | Neff 24 in. S5456 Built-in Dishwasher
Dishwashers Logo
50 people viewed this question
Top Dishwashers Experts
Owen Barnes
