Question about Kenmore Elite HE4 Electric Dryer
How do I reset lockout feature?
The lock out feature got enabled some how on my HE3 Washer.
    Top Expert:
  • Kenmore Master
  • 76,164 Answers
The only reset there is is to disconnect the power for 5 minutes, if that doesn't correct it then the machine is defective
Posted on May 25, 2010
Oven door locked
Many Kenmore ovens have a control lock that keeps the oven door locked even when the self-clean cycle has not been in use. This feature is meant to prevent children from opening the door or using the controls on the oven. To cancel the oven lockout, push and hold "Stop" for three seconds. Wait 15 seconds for the oven door to unlock automatically.
Reset
After verifying that the oven lockout feature has been released and waiting at least an hour after a self-clean cycle, if the oven door remains locked, try to reset the oven. Disconnect power to the range, and wait 30 seconds. Restore power and try again. If the door remains locked, disconnect the power and try to reset the circuit breaker or fuse. Contact Kenmore if the door remains locked after both attempts at a power reset at 800-827-6655.
Feb 26, 2014 | Kitchen Ranges
Kenmore dryer he3 lockout wil not let it start
On most models of Kenmore HE3 dryers, you will need to press and hold the AUTO DRY LEVEL button for 3 deliberate seconds or until the lock is disabled. Some models have different controls. The directions for this control lock are normally printed on the console under the button that is used to enable and disable the control lock. If holding this button does not work, then you could have a failed user interface control or a bad control board.
Nov 05, 2012 | Dryers
WE moved to a different location and our washer door is locked with the manuals inside. Silly right. Safe keeping. It is a kenmore he3 elite 2003 Characters@yahoo.com
press and hold the DRAIN & SPIN button down for at least 3 seconds to disable the control lock feature.It should however open after being disconnected for a time.
Mar 07, 2011 | Kenmore Washing Machines
The control lock light is on. How do I turn it off?
The Control Lock is actually a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. This can usually be reset and does not require a technician.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
If this is a Whirlpool manufactured front loader (such as Kenmore Elite), the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control button issue (such as an operator console problem or main control board issue).
Apr 21, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Mcahinw will not start.
Hi, Press and hold the DRAIN/SPIN button for 3 seconds. If the Control Lock feature will not lock or unlock the appliance,unplug the unit for AT LEAST 30 minutes in order to reset the main control board.
Apr 12, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Controls locked light
The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
Check below link for detailed explanations
Courtesy JSROCK
Mar 31, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Wont scan.the only channel's it will get is 11,21,41,61. when you hold the button down to talk it make's a squealing sound.it acts like it is locked.when you put it on the [set] switch it makes the noise...
Do you have a "lockout" feature in the radio?
Maybe try resetting the scanner and start over from the beginning. Usually by resetting, will disable any extra features (such as the lockout)
Sep 10, 2008 | Uniden SMS825TS 2-Way Radio
Control lock light
someone has enable the child lock feature. One of the buttons should say hold 3 secs for control lock under its normal function description. Hope this helps
Jan 01, 2008 | Washing Machines
Control Panel
check your owners manuel should tell you how to un lock controls wont be an obvious button as its a safety feature
Dec 31, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Control Panel
I believe the DRAIN/SPIN button on the Kenmore Elite HE3 will clear a locked control panel if you hold the button in for 3 seconds. This is actually a safety feature to keep small children from playing with the buttons and allows the consumer to lock the control panel. I hope that's all the problem you have and that it is not a control panel failure. Let me know if this helps. PS The matching Kenmore Elite Dryer uses the AUTO DRY LEVEL button for the same feature.
Jul 19, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4 Electric Dryer Logo
73 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
