Question about Whirlpool LSR5132PQ Top Load Washer
My washer bangs very loudly on the spinning cycle
When i tipped it over and looked underneath it there is a triangular braket not connected to any thing what do i do with this bracket or is that even the problem
  • 10,319 Answers
Three springs attach to that triangular bracket which will end the banging noise if reattached to the washers inner frame work
Posted on May 26, 2010
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Jan 21, 2013 | LG Cherry Red Steamwasher Wm2487h Front...
Loud Bang at End of Spin Cycle; Leak Underneath Washer
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Check for tips on the link below to identify parts and removal:
Also check on the SEAL on the door and drum, it can also be worn out and reposition the drum to move out which can result in the noise when the spin is activated.
Jan 21, 2013 | Maytag Washing Machines
Bangs when spin cycle is going
sounds like the washer is not level, underneath the washer are 4 legs that are adjustable, you just turn them up or down. one of them may be to high.
Jan 15, 2012 | Kenmore Washing Machines
Frigidare front load washer has loud banging on spin cycle. After much work we reallized one shock was broken of which we repaced both now it still making the loud banging shaking motion. Also the washer...
Thanks for choosing FixYa and welcome. Since the suspension is ok and it is level, check your drive motor and spin bearing. Usually, these are the trouble parts when loud noises are associated with the spinning cycle. Your drive motor controls the spinning. Since the noise is during spinning, that is probably where your problem lies.
Apr 29, 2011 | Frigidaire GLTF1670A Front Load Washer
MY WHIRLPOOL GSQ9364HQ0 WASHING MACHINE IS MAKING A LOUD BANGING NOISE DURING THE SPIN CYCLE. IT HAPPENS LOADED OR UNLOADED DRIVE COUPLING IS OK BRAKE SEEMS TO STOP IT QUICKLY WHEN YOU TURN IT OFF IT...
Most likely something the suspension is out of place or missing. Triangular Part # 17 in picture should match up to the triangular opening in frame. If it is out of place, it will do as you are describing. There are also 3 plastic pads that snap into frame that this part 17 rides on. Make sure they are in place.
Sep 26, 2017 | Whirlpool Ultimate Care II GSQ9669L Top...
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Loud banging during spin cycle
please balance your washer and use smaller loads
Mar 18, 2008 | Kenmore 43052 Front Load Washer
Loud Noise on Spin Cycle
it could be 1 of 3 thing if the banging is coming from the case then your suspension legs are no good you will need to right down your model number and go on ebay or to you local appliances shop they will help you or even take a look you will save a lot of time and money if you go and see your local second hand shop that do appliances they will do the job relay cheep £25-£30 pound with the legs
Jan 07, 2008 | GE Profile Prodigy WPSE4200A
Whirlpool LSR5132PQ Top Load Washer Logo
104 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
