Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
My magnavox MODEL # TS2760 C203 (MFD IN 1995) HAS developed a snapping sound while playing; sometimes it's repetitive and sometimes just one snap. It happens very often. Can you kindly advise as to the problem?
HOW CAN I OPEN UP A REMOTE CONTROL UNIT / MAGNAVOX - NC003UD TO CLEAN IT
Check inside the battery compartment and feel over any labels, there may be screws there that need to be removed before it will come apart. If no screws then there will be snap clips around the outer edges of the case, but inside so you don't know exactly where they are located. To get it apart use something like a credit card push it in between the 2 halves of the housing and slowly work it around, in and out until you find where the snaps are located, then use the card to carefully slide the snaps apart. Good luck...the snaps do tend to breal easily.
Aug 13, 2014 | Magnavox NC003 Remote Control NC003UD
Ihave a philips dvd/tv remote, but i can't get it to operate my magnavox tv except on/off and volume, can you help?
There are a number of different codes for each TV, pick the one that works best for example these are for magnavox, but since I don't know the model no of your remote they might not be correct for yours! 0441, 0442, 0447, 0599, 0799, 0699, 0247, 0193, 0093, 0598
Jul 21, 2014 | Philips Televison & Video
Model HO-0250H, heater makes a pair of snapping noises one after the other, perhaps from expansion/contraction. Heater is two months old.
The unit uses oil to create residual heat. The oil can contain small amounts of moisture and when the unit heats that moisture turns to steam, Steam has a great expansion ratio. When the steam condenses back to moisture it can conglomerate into large water droplets instead of being dispersed. This means that when it heats back up the steam expansion is more radical and makes noise. Unless the unit starts leaking oil, it is fine to continue using it.
Feb 20, 2014 | Pelonis Heating & Cooling
How to change developer beads
I have the complete 9 page instructions with images if you want I can e-mail them to you. Here is a snippet explaining just the portion of the beads. (email me at itsallnoise2me@gmail.com for complete instructions). Also, if you purchase the developer beads from iteminc.com they will include the instructions " 1. Place the developer housing assembly (new or used) to be recharged on a drop cloth. Caution During this procedure, the developer housing assembly must be kept level at all times. To prevent toner spillage, it is recommended that the developer housing assembly be fully supported level by laying it on something like a large piece of cloth, paper towels or styrofoam hollowed out for the developer housing assembly to lie on. If new, remove the protective cover over the magnetic roller. Do not touch the magnetic roller. Note The wires are routed under and behind the right snap tab. 2. Release the snap tabs at each end of the developer housing assembly and remove the assembly cover. 3. Agitate the package of developer mix and then cut it open. Carefully pour the entire contents of developer mix as evenly as possible over the two augers. Do not let the developer mix accumulate heavily on the roller. Keep the developer housing assembly level. 4. Reinstall the cover making sure that the rear tabs are all engaged in their respective slots while positioning the wire harness under the snap tab. Press firmly until you hear a positive "snap" sound for each tab indicating each snap tab is securely fastened. 5. Tear off the ATC sensor perforated tag. Do NOT remove the ATC sensor label from the developer housing.Peel off the protective backing, and adhere the label to the appropriate or corresponding Imaging Unit Plate. Make sure the ATC sensor tag label can be located if needed later. 6. Record the number for entering into NVRAM in the next step. 7. Perform the ATC Sensor Setup procedure."
Sep 13, 2011 | Xerox Phaser 7750DN Laser Printer
Lost instructions for Snap card game.
Snap is an easy-to-learn card game for two or more players. Players must race to be the first to yell "Snap!" after noticing a match on the table. If you are the first player to yell then you win more cards to add to your pile. The first player to collect the entire deck is deemed the winner.
Setup
Shuffle a standard deck of 52 playing cards then deal them one by one to each player. It does not matter if some players start with more cards than others. Each player should keep their cards face down in front of them.
Gameplay
Starting with the player to the left of the dealer, each player flips the top card from their pile and starts a second, face-up pile next to their face-down pile. This process continues one by one for each player going around the table clockwise.
Snap
All players race to yell "Snap!" when any player turns up a card that matches a card that is already face up on another player's pile. The first person to yell "Snap!" gets to add the two piles under the matching cards (including the matching cards) to the bottom of her face-down pile.
Snap Pot
If multiple players yell "Snap!" at the same time, the two matching piles are combined and put face-up in the center of the table creating a "Snap Pot" and play continues as normal. If a card matching the top card of the snap pot is played then players must race to yell "Snap Pot!" The first to yell "Snap Pot!" gets to add the snap pot and the matching pile to the bottom of their face-down pile.
False Snap
If a player ever yells "Snap!" or "Snap Pot!" when no matches are played that person must give their top card to the last person to play a card.
Objective
The player to collect all of the cards is the winner.
Jul 20, 2011 | Cycling
1995 Eagle Summit AWD cranks but won't start...battery, fuel pump, spark plugs replaced ...why? Is the problem the multiport fuel injector relay? Where is this relay located?
Sounds like a timing belt has snapped. If it is an interference engine, the engine could be ruined (pistons hit the valves and bend them). Check gates belts to see if it is an interference engine. Belts normally snap at 80,000 to 120,000 miles.
Jan 21, 2011 | 1995 Eagle Summit
Magnavox projection TV - Sound cuts off when changing channels.
Yea. Your model FP5210 is much older than one with digital SSB board. Still would think that the mute is being activated; probably by the ucontroller/cpu IC.
Apr 14, 2010 | Televison & Video
How to remove the back cover on Magnavox 32MD251D/37
These are snapped on tight so if you take a screw driver and go around the lid gently to snap off the seal you should be great.
Apr 23, 2009 | Philips Magnavox 42MF521D/37 Television
Magnavox t.v. Model # TS2760 C101 with black box on screen
To fix this problem you need to go to the text probably in
the closed caption or thereabouts. Go to the text highlight it and cut the text OFF
It is very simple to cut the text off...a little practice and persistance and you
will find it.
Mar 09, 2009 | Televison & Video
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
41 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
