Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
Led light stays on, can't get VM
Tried to push HS for 5 seconds and got paging on all five of our phones
    President:
  • 1,561 Answers
If you have a cell phone try calling yourself, and see if the phone rings or if you get a busy signal, or an operator message that can confirm if the phone company disconnected your phone service. If you get a message your phone has been disconnected, call your phone company.
Unplug your phones for at least 15 minutes, all phones in your house and all lines just from the wall jack and power from the cordless phones.
After 15 minutes plug your phones back in the jack one at a time, pick it up and see if there is dial tone. If not the phone might be defective, check the other phones.
If still no dialtone bring a phone to your NID, this is a gray box located on the phone pole (in real rural places) or a gray box that reads "Network Interface", open the box with a flat head screw driver.
Once opened you will see some test jacks.
Disconnect the plug from test jack. If you have more than one line, select the test jack for the line that is causing the problem. This disconnects your inside wiring from phone company's line.
Plug in your preferred non cordless phone into the jack. This plugs you directly into the phone company line.
Pick up the phone check for dialtone and try making a call. If unsuccessful call your phone company and provide them with this information.
Take care.
Posted on May 25, 2010
How to connect an HS 950 headset to Uniden DECT 9135
(I presume you have checked the headset is fully charged and powered on.)
Together with pressing "Find Headset" on the phone, you also have to press and hold "VOLUME +/-" for 5 seconds on the headset.
When the connection is made the headset LED will flash blue every 10 seconds.
I hope this helps.
May 11, 2014 | Uniden DECT 6.0 Cordless Phone ID
My Panasonic Phone KX-T7630 rings seventeen (17) times before going to voice-mail. Desired amount of rings before going to voice-mail is four (4) to five (5).
This is just for your phone ringing when it's dialed, not for outside lines ringing on your phone.
From your intercom, dial *7104 (CF No Ans) 500 (if that's your VM extension) # That will flash your FWD/DND light to tell you it's forwarded on No Ans. Now on the intercom, dial *71324 The 713 part tells your phone to forward after xx seconds. 24 is about 4 rings. You can adjust the timing using 6 seconds as a ring cycle.
Carl
Jun 28, 2011 | Panasonic KX-T7630 Corded Phone
Pushing on power button three green lights come on for one secone
click here you would find the details for led codes. you may select any laptop. codes remain the same.
Sep 24, 2009 | Dell Latitude D600 Notebook
GE WCVH6260 stops unexpectantly
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped.
Check your drain with a good pour of water from a bucket, it must clear fast. It it doesn't snake it out; the prob lies there 99%. And don't push your exit hose too deep into the standpipe, 4 to 5 inches & not air tight.
Nov 20, 2008 | GE Energy Star WCVH6260F Front Load Washer
Fixing my computer
This is the manual for the ASUS P5PE-VM motherboard.
Click here
If you go to page 1-30 in you manual (Page 42 in the PDF), you will find how to hook up these LEDs and push buttons.
Let me know how is goes!
Sep 19, 2008 | ASUS P5PE-VM Motherboard
Blinking Voicemail Light but no Messages
hold you finger for 5 seconds on the page (or find hs) button, that usually clears the blinking beep/light!!!
also make sure no old messages are in the VM inbox!
This worked for my phone!
Sep 12, 2008 | Uniden Cordless Phone
Uniden cordless phone
I found that if I hold the "find hs" button on the BASE unit (right above the red charging light) for a few seconds, it works!! Thank goodness there is a solution! Thanks for the help.
Feb 07, 2008 | Uniden Cordless Phone
To reset the indicator(Red light flashing on handset), press and hold the find handset key for 5 seconds or until the light flashing stops(10 sec).
Feb 04, 2008 | Uniden Cordless Phone
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
56 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
