Question about Bosch 24 in. SHE43C05UC Stainless Steel Free-Standing Dishwasher
The little holes in the arms have food stuck in them and I can"t get it out. I have tried toothpicks and tweezers but it just pushes it back in. The dishes are coming out dirty. Solution ?
  • 901 Answers
Refer user manual. Remove the spray arm and clean. If you have a vaccum cleaner try sucking the particles from the main opening end. ( ie where the water flows to the arm)
Clean your drain filter and remove all the debris manually from the chamber.
Posted on May 26, 2010
Why is the upper sray arm is not working in kitchenaid model KUDR01TJ
There are 2 spray arms for the top rack. A small one on the dishwasher top and a bigger one attached to the bottom of the upper rack. Both get water feed from a flat tube that runs up the back wall of the dishwasher. Not much to the very top little arm--just check the spray holes for any food blockage and try to clean with a brush or tooth pick. The bigger arm on the bottom of the top rack gets its water feed through a hole about half way up the flat tube on the back wall. When you push the rack all the way in, it has to plug itself into that hole in the back wall. Check that plug in area and make sure nothing broke off that would keep it from making a good seal with the rack all the way in. All check all the holes in the spray arm for food blockages. On the very end of all spray arms is a main hole that is the drive hole to spin the spray arm. The water shoots out that hole and acts like a jet engine to push the arm around. Make sure those holes are clear.
Mar 24, 2015 | KitchenAid Dishwashers
Indesit di620 dishwasher not spraying water from arms
Hi, you may want to try looking at all the holes in the spray arms. If you see anything blocking a hole, use the tweezers and remove the stuff.
Remove the bottom spray arm and check for items in the water delivery hole.Check the lower spray tower that is connected to the bottom rack. Make sure all rotating parts rotate properly. Look underneath to make sure nothing is stuck in the tower. Remove any stuff stuck that is preventing rotation or clogging the tower.
Jun 26, 2011 | Dishwashers
My dishes are dirty after the wash. The glasses have small particles dried on the inside. They are upside down. How does it do that? Thanks.
Thanks for using FixYa.
An answer for your question about your dishwasher could be that your jets or spray arms are clogged.
1. Please look inside the dishwasher for obvious obstructions and turn the spray arms to make sure they move freely.
2. Now look at the bottom sprayer and at the little holes. If you see food or stuff in any of the holes, use small tweezers to remove.
3. Also look in the bottom area for items which may be blocking the water delivery hole.
4. Finally, look at the top sprayer arm. Using a flashlight, look closely for food or other particles which may be clogging the holes.
Let me know if this helps or if you have questions.
Thanks again for using FixYa,
Apr 03, 2011 | Microwave Ovens
Dishes do not get fullyl clean on top rack
Check your spray arms for pluggage. Soft food can get recirculated and plug the holes and slots up. Remove the arm, and clean it out. Back washing it with the sink faucet works pretty well, and stubborn plugs can be dislodged with a toothpick.
Best regards, --W/D--
Jan 25, 2011 | KitchenAid 24 in. KUDI02IR Built-in...
Food particles remaining on dishes after cycle is complete.
Hi
While putting dishes in the washer and obstructing the spray ams which causes food particles to stay on dishes. After loading dishwasher and pushing in baskets ,be sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
However the other causes for this problem are…
Not enough water entering dishwasher (check level after fill... Should be slightly below bottom wash arm)
Water filling but draining during wash cycle. Check toward end of wash cycle but before drain. See if water level is diminished from start of wash cycle.
New 'water saver' dishwashers are notorious for having smaller water jets, and thus easier to stop-up jets. Check the jets on all wash arms to be sure they are cleared of food particles.
Another way to check the wash arms is to manually position them at specific locations, momentarily run the dishwasher for a few seconds, then open the door to inspect the location of the wash arms. Do this three or four times to eliminate the possibility of coincidence.
If the wash arms do not move from the location that you put them, the most likely cause is food particles stopping up the water jets. These jets not only clean the dishes but also the water pressure they generate turn the arms inside the dishwasher to properly distribute water pressure on the dishes.
Sometimes you can dislodge and remove food particles stuck in one of the jets with a toothpick or other small probe. Others require that you remove the arm(s) and get a little more creative. I use compressed air to clear mine, but not everyone has access to compressed air, so use whatever you can to remove the food particles.
Simply dislodging them from the water ports is usually not effective... As soon as water pressure is applied, the particles return to the jets and stop them up again. The real fix in this instance is to completely remove the food particles from the arm if you can.
Let us know if you want to know something more else please accept the suggestion.
Thanks for contacting Fixya.com
Apr 14, 2010 | Maytag 24 in. MDB8600AW Jetclean II...
My dishes do not come out clean they have a residue of dryed food
Check the spray arms to make sure there is not food buildup in them. You can clean the holes with a toothpick. Make sure arms are getting water so they can spin easily
Oct 22, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwasher repair - Bosch
Can you remove the upper spray arm (is yours under the upper rack?)-mine unscrews and then you have to wiggle it off. Run faucet water into the arm; sometimes little bits of crud get stuck in the holes that spray the water out, and this prevents a complete rinse. I just had to clear these holes myself due to same problem (I might have a different machine, though). You can do the same for the lower arm.
Jan 25, 2009 | Dishwashers
Danby Countertop Dishwasher Spray Arm not turning
now ya need to find out how the food got by the screen and into the pump motor to get shot into the spray arm
Dec 29, 2007 | Danby 22 in. DDW396 Free-standing...
The tilt button is not working
Okay, we just figured this out ourselves.
There is a little hole on the neck of the mixer, where the mixer motor meets the neck. While pushing the tilt release button, stick a small screwdriver into the hole (it will not go far) and pry the latch upward. While holding the latch up and the tilt button, have someone pull up on the motor while holding down the base. It might take a little muscle, but after that, the motor will be able to tilt back and forth like it did before it got stuck. If you are the one holding the tilt button and latch, please wach your finger so they don't get pinched when the motor swings up.
Dec 17, 2007 | Sunbeam 2350 Heritage Series Mixer
Bosch 24 in. SHE43C05UC Stainless Steel Free-Standing Dishwasher Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
