Question about Philips Magnavox 27MS343S 27" TV
White lines when I turn the tv on I can hear the station clear the picture is a bright white with a faint picture of the station overlayed with white lines space approximately 1 inch from top to bottom. Please help
    Genius:
  • Philips Master
  • 1,689 Answers
These are retrace lines. This may be a fault in the blanking circuits. On some occasions a weak CRT can also cause blanking lines to show.
This is something you would not be able to service yourself. I would suggest to have an estimate done on the TV set for you to decide if it should be serviced or not.
Jerry G.
Posted on Apr 16, 2008
Vertical lines through Polaroid z2300 printed pictures
i have the same issue, my best guess is that because there equally spaced there is something wrong with a cog, i can hear a faint click that is in sync with the lines. i'm going to investagate more so will hopefully i'll have a definative answer soon
Apr 15, 2013 | Polaroid Z2300 Instant Print 10mp Digital...
T.V. comes on show blue then goes out after 3 second and only hear sound
When it comes on with a blue screen is it rather bright and or has curved faint trace lines in the picture?
Dec 12, 2012 | Sony KP-65WV600 65" Rear Projection...
My LTV-32w6 westinghouse powers on & has sound but displays black screen with very faint colored vertical lines. It shows like this for about 1min before it goes into standby mode & the blue power...
Depends on what is causing it...
Vertical bands of faint black are generally caused by filtering capacitors and can be found in the power supply or the 5 volt supply or even the Video processing circuit...it is not an easy task to identify the source of Video hum bars.....we also call them Jailbars.
Another problem seen is faint black lines caused by the TV set being in 4:3 mode all the time....right at the edge of where the picture ends and the black pillars begin, we see a faint black line that never goes away and is normally seen with a full screen....
That is actually image retention, but it's caused by the crystals that create the picture becoming polarized or ionized over a very long period of time....and it's not easy to DE-Polarize them !
But there are some theories out on how to do that....
Certain people suggest running the TV overnight with an ALL-WHITE picture and some suggest an ALL BLACK PICTURE...and some suggest alternating between both !!
Now, a black picture is easy to make, you just deactivate the Video Mute (blue screen) and set it to an unused Video INPUT overnight....
About the only way to make a white screen is to use the USB port for pictures and take a very bright outdoor shot of a piece of white paper that hopefully is out of focus too....That would create an all-white picture that you can plug into your TV set overnight....
Now if you decide to try this, deactivate any displays on your TV set...all you do is press the display button until the Video and/or USB input numbers disappear....
Next day , set it back to normal TV and see if it's gone or if it's REDUCED....try it again if needed, or try the exact opposite if you see NO RESULTS....
Sep 20, 2012 | Westinghouse Televison & Video
LG flatron plasma rz42px10 snow screen with sound
Check and replace its tuner. If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 11, 2017 | Televison & Video
Sony KP-57WV700
Hi. It seems that the g2 voltage of the picture tube is too high, resulting in a white screen, often with white horizontal lines. The g2 (= second grid) voltage is derived from the flyback high voltage. The voltage divider is mostly integrated in the flyback trafo housing.(including the adjustment knobs). A failure in this divider may lead to this defect. The static you hear may come from sparking in the divider. The flyback trafo is soldered onto the main printed cirrcuit board. Sometimes, one of the pins sits loose in the soldering pads.
Turn on the set and observe for any sparking around the entire flyback circuitry, and, or the flyback trafo itself
The screen turns black after a while, as a too high beamcurrent is detected. The set disables the flyback. Stand-by blinks meaning that there is a fault condition.
Be carefull with the high voltages. The flyback voltage is very high (20-30 Kilovolts !) and may be lethal !!
Jul 02, 2012 | Sony KP-57WV600 57" Rear Projection...
Gray screen with horizontal lines accross it
sounds like you may have a bad ic it probley is a surface mount on the bottom of the board it could couse this problem would need to take to a shop to repair. The ic probley is numbered ic101 on board.
Mar 01, 2009 | Sanyo DS32224 TV
White lines in tv whats the problem??????????????
Check the cable that you are using. If it's a "single" shielded cable, it maybe letting in "air" frequencies, like you have an antenea hooked to your TV. Especially if you live in a city that has several Tv stations near you. The cable could be to old and has breaks in it, or not grounded properly.
Dec 22, 2007 | Apex Digital AT2702 27" TV
Green television screen on a princess tlevision
can you clarify that are you seeing white bright lines on screen & is there faint picture with green color?
Sep 16, 2007 | Televison & Video
Horizontal bands
you may have a problem with the vertical output IC.
May 26, 2007 | RCA F27442 27" TV
Tv showing blue screen with flyback lines sound ok
Flyback lines? Is the picture all white with no brightness control with faint horizontal faint lines? If this is what you are saying, the screen voltage could be bad, and if thats the case, the picture tube or the flyback itself could be bad. You could also have a bad connection on the crt socket
Dec 27, 2006 | Philips Magnavox 20MT133S 20" TV
Philips Magnavox 27MS343S 27" TV Logo
62 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
