Question about Microwave Ovens
The turn table doesn't move. I tried pushing the turn table button, but doesn't seem to make a difference. Is there something else I should do?
    Brigadier General:
  • 3,917 Answers
Hi
Yes there is couple of things to verify. First thing I would check is the coupler (#37 on the break down diagram). Remove the glass tray and pull the coupler up. Check it for any cracks. If the coupler is fine then the turntable motor has to be replaced. It can be easy replaced after the bottom panel removed - just two screws and the wire plug. - The part number for the coupler is AP2016754
the part number for the turntable motor is AP2024962
Let us know if you want to know something else accept the suggestion.
Thanks for contacting fixya.com
Posted on May 25, 2010
GE microwave light turns on when START buton is pushed and all the push buttons work but no heat, no sound and turn table does not turn. Any suggestions?
You might have a bad door switch, open thermal protector, or the latch mechanism is not activating the switches properly.
Dec 03, 2016 | GE Microwave Ovens
Why is my turntable not turning in my microwave oven?
Is your microwave clean under the table? No stuck on food or anything? Does the the oven work without the table?
Does the little prop in the centre that turns the table move when there is no table on it? Try to carefully clean it and see if that helps.
Feb 17, 2015 | In Microwave Ovens
If you try to heat something for a minute , the microwave will turn on for about 15 seconds then shut off . It doesn't even seem to warm the food.
It may need a reset. You can do that by unplugging the power for a minute or two, then plugging it back in and setting the clock.
If it still fails, you may have a failing cooling fan or a problem on the control circuit board.
Apr 14, 2013 | Thermador MCES Stainless Steel 1000 Watts...
My Kenmore Built-in microwave doesn't heat and the turn table doesn't turn. Model 911-47812200
It is good that the microwave does not work all together. It might be an interlock button or even a relay connection burn on the main mother circuit board.
Need a qualified technician. The service manual will be like $20-50.
e
Nov 22, 2011 | Microwave Ovens
Galanz Microwave Model WP1000AL30 doesn't go on when the item buttons are pushed?
Does microvave button makes sound and when you start push button does the turn table moves.If yes for sound ,and no for turn table then you might have door switch which is either doesent latching or might broke.
open oven (be sure to discharge capacitors).
check its closing properly(the switch)
and use DMM to check resistance that it doesn't show OL
thanks
please rate my work
Sep 20, 2011 | Microwave Ovens
Microwave is less than a year old. It looks like everything is working, timer, light, air, turntable, etc., but it doesn't cook.
HI..there is a heating filament of an oven MAGNETRON..it s responsible of producing heat to the oven..possibly this is defective ..this filament must be replaced by a new one..theres no problem with the motor cos it runs the table power and light button seems working..HOPE THIS HELPS
Jul 06, 2011 | Oster Microwave Ovens
The microwave just stopped working in the middle of heating
Always have something in the microwave before turning on. A glass of water is OK. It's needed to absorbed the energy.
All microwaves will stop if the door is opened. This a safety feature. Never operate with the door opened.
The button below the plug outlet is a test button for the GFI (Ground Fault Interrupter). This is a safety feature of the electrical wiring for your home. Make sure it's turned on.
Since this is a new unit, you may want to take it back to the store you bought from for an exchange/refund.
WARRANTY Parts Warranty Limited 1-year entire appliance Labor Warranty Limited 1-year entire appliance Warranty Notes For models produced on or after January 1, 2006
See written warranty for full details
Mar 30, 2009 | General Electric JES0736SMSS 700 Watts...
Microwave Ovens Logo
15 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
