Question about Hobart Welders IronMan 210 MIG 500304A Welder
I have an ironman 210, lightly used, has power and feed works but wire is dead. tried bypass of breakers,new tip and ground clamp connection. any thoughts?
4 Suggested Answers
  • 225 Answers
SOURCE: i have a hobart ironman 210 that lost all power
take side panel off where power goes into unit,check for voltage ,if not go to where plug is plugged into check for power if there is power check the crows foot to make sure all three wires are tightly screwed to terminals
Posted on Mar 07, 2010
Weldinstruct
  • 17 Answers
SOURCE: Weld arc not stable. Wire feeds, good ground,
Arc blow could be the cause! Put your ground on the work piece and weld away from it. If you weld toward a ground clamp the magnetic forces will blow your arc around sometime. When taking a cert this simple mistake can make or break ya on your cap or reinforcement beads.
Posted on May 30, 2010
Weldinstruct
  • 17 Answers
SOURCE: will not arc
Check ground connection at welder along with your ground clamp. Bad connection could be the issue. Also check settings on your welder.
I have a120 MW snap-on welder that the wire feed works i accidentally touched to ground clamp sparked, and know nothing. is there a fuse or breaker??? the wire feed works still
Replace your contact tip on the end of the mig gun
Sounds like youve arced it out and the wire is stuck in the end of the contact tip but steel feeding possibly spitting wire out of the drive roll like we like to say birds nest
Dec 06, 2015 | Snap-On Welding Tools
I have power to the feed the wire is working i did hit by accident the ground clamp and wire feeder together it sparked and after that nothing can you help me
From your description I gather there is power to the tip of the torch and the wire feed is working? If this is so and the ground wire and clamp are ok the welder should be working.
The fact the welder is not working means one of those things is not ok?
In the case of an accidental short circuit I suggest you check power in and out of the transformer and any chokes. It is unlikely these will fail but there are various levels of protection including fuses, thermal fuses and thermal breakers and it is possible one or more of these has failed.
Electromagnetic contactors give little trouble but they need an output from the electronics in order for it to work. Solid state contactors are much more complex.
If the contactor is not closing but the wire is feeding it is likely at least part of the electronics have failed.
Dec 06, 2015 | Welding Tools
Our 7788F keeps going into a ground fault condition. Need help troubleshooting. John
Ground Fault ???
Troubleshooting Ground Fault
Troubleshooting a ground fault circuit interrupt, or GFI, breaker is pretty straightforward. Troubleshooting the circuit itself can be quite time-consuming.
The GFI breaker is designed with a test button incorporated into the breaker itself.
Pushing the test button should trip the breaker.
On GFI-style breakers the neutral wire going into the house's outlets is connected to the breaker's neutral connector, the white neutral that comes out of the breaker is connected to the neutral bus in the panel, isolating the neutral bus from the neutral wire going into the house.
The test button actually shorts the neutral wire feeding the circuit to the neutral bus in the electrical panel creating a ground fault that should trip the breaker.
It is considered a ground fault because the neutral bus in the main electrical panel is actually connected to the ground bus through the panel's metal casing. What to do if the test button isn't tripping the breaker
Push the test button on the GFI breaker.
The breaker should trip.
If the breaker does not trip, then it may be that the breaker has already tripped and just looks like it's on.
The position of the switch may only move slightly from the on position towards the off position when tripped.
Push the switch on the GFI breaker all of the way toward the off position.
It may take some force to get the breaker to reset.
Turn the breaker back to the on position.
When the breaker has been reset properly you should feel some resistance when pushing the switch back on.
3 Push the test button again and the breaker should trip.
If the breaker still doesn't trip then you should test for power at the screw connections inside of the electrical panel.
Remove the screw that holds the dead front covering the breaker's connections.
Remove the dead front cover.
Test for power with your voltmeter set on AC volts on the highest scale.
For a single pole GFI breaker, touch the black lead from the tester to the silver screw on the GFI breaker and touch the red lead from the tester to the brass screw on the GFI breaker.
You should see 110 volts on the tester. If voltage is seen but the test button won't trip the breaker, then the breaker is bad and should be replaced.
5
Test for power on a two pole breaker by touching the red voltmeter lead to one of screws with a black or red wire connected to it.
Touch the black lead to the other screw with a black or red wire connected to it.
You should read 220 volts or close to it on your voltmeter.
If you read voltage and the test button won't trip, the breaker is bad and needs to be replaced.
What to do if the breaker won't reset and keeps tripping when turned on
6
Unplug everything that is plugged into any of the outlets on the circuit in question.
Try resetting the breaker again by pushing the switch all the way to the off position and then turning it back to the on position.
If it won't reset and trips when the breaker's switch hits the on position, it could be a bad breaker or a problem in the circuit itself.
7
Use your straight-tipped screwdriver to loosen the brass connection screw or screws on the GFI breaker.
Pull the black hot wire, or wires, out of the breaker's connectors.
Loosen the silver screw the white wire is connected to and remove it from the GFI breaker.
8
Push the switch all the way to the off position.
Turn the switch back to the on position.
If the breaker still won't reset, then the problem is the breaker itself and it should be replaced with a new one of the same size, brand and model.
If the breaker resets normally and the test button trips the breaker when pushed, the problem is in the circuit itself and an electrician should be called to find your ground fault.
9
Reconnect the black wire, or wires, to the brass screws on the GFI breaker.
Reconnect the white wire to the silver screw on the GFI breaker.
10
Replace the dead front cover into the breaker panel.
Install the screw or screws that hold the dead front in place.
http://www.hilo-electric.com/blank?pageid=63
Aug 14, 2013 | Computers & Internet
Car won't start. Parked car, two hours later, got in turned key, all went dark. No dash lights. Did not even try to turn over. Battery was caroded, cleaned posts, no change. Fuses under hood all okay. ...
Check that battery connection again real real good. If your batter was just "a little low" then there is plenty of juice to at least run your lights. For every single thing to be dead with 0 response you have a failed power feed. Check all them big power wires and their corresponding grounds. This is your problem. But just to double check the battery charger you used you may try another batter if you have one and see if the response is different. Also make sure that cable that was corroded is not corroded where it is clamps onto the power wire. Cut that clamp off and install a new cable clamp as needed.
Regards, Tony
Apr 25, 2011 | 2001 Ford Mustang
Will feed wire but will not start an ark to weld
Make sure that the ground clamp is securely fastened to the workpiece.
Ensure that the power pin is fully seated into the housing where it receives the current.
Ensure that voltage and amperage settings are correct.
May 04, 2010 | Hobart 500526 Handler 210 Professional...
Will not arc
Apr 23, 2010 | Hobart Welders IronMan 210 MIG 500304A...
Hobart 210 makes an arc but the wire feed motor won't turn. used very little ,has voltage at motor,worked fine the last time i used it
hi,
maybe you haven't got the wire speed control turned up probly not the answer but sometimes its the simply things.
Mar 02, 2010 | Hobart Welders IronMan 210 MIG 500304A...
I have a hobart ironman 210 that lost all power but no circuit breakers blew switch is working but no power output to cooling fan or gun
Feb 02, 2010 | Hobart Welders IronMan 210 MIG 500304A...
Welder not welding
The contact tip is the main source of power, if the tip is bigger than the wire then you will not get a proper conection, the earth clamp is a essential part of the system make sure you have a good earth and all the conections are tight
Jan 14, 2009 | Clarke Power Products Clarke 130EN Mig 110...
Millermatic 200 will not weld
1 - Check the ground connection to the work, including the actual cable to clamp connection.
2 - Make sure that the wire feed rollers are nice and clean. The wire needs to be clean too.
3 - Check that the polarity changing wire connections are nice and tight, clean, etc.
4 - change and or service the contact tip at the end of the gun.
as always, gently clean out the loose junk inside the case. A clean welder is a happy welder. :-)
Nov 16, 2008 | Welding Tools
Hobart Welders  IronMan 210 MIG 500304A Welder Logo
74 people viewed this question
Top Hobart Welding Tools Experts
Matt Olenzek
Matt Olenzek
oneStan
oneStan
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
