Question about Yamaha YST-SW150 Speaker
I have a Yamaha sub woofer model NX-SW150 that was part of a package home theater system. The original DVD receiver was a DVR-S150 which had a system control cable that plugged into the subwoofer as well as the typical RCA input plug. I would like to use this sub with my new amp (old Yamaha reciever is toast) a JVC unit that only has the typical single RCA subwoofer output. The sub does not appear to work without the system control cable being connected. Is there a way to allow this sub to work like a normal sub without this system control cable input. Can this active servo system be bypassed so it works with any amps single subwoofers output conector??
The system connector jack needs a 12V DC signal to turn on. If you don't have a suitable Yamaha receiver with this connection, use any 12 V DC adapter with a 1/8 in mono plug (the tip should be positive)."
Posted on May 17, 2015
Where does the 1/8 3.5mm mono jack get plugged into on the receiver? The RCA subwoofer output is already taken.
Posted on Dec 15, 2012
What does that solution mean?
I am wanting to know the answer to the exact same question. did you ever find the answer?
Posted on Aug 07, 2010
  • infotegrity Oct 06, 2010
    I have this sub. The system connector jack needs a 12V DC signal to turn on. If you don't have a suitable Yamaha receiver with this connection, use any 12 V DC adapter with a 1/8 in mono plug (the tip should be positive).
RCA RT2770 Sub-woofer sound doesn't come
The sub should generally have its own power supply, is it plugged in ???
Feb 16, 2016 | RCA RT2770 Theater System
How can i enable surround speaker and how can i connect speaker
Muhammad, you need to go to the function that provides surround sound, have a dvd that was recorded in 5.1, have all the speakers and the sub-woofer connected.
May 30, 2013 | Yamaha DVR-S150 DVD Player
I have a yamaha nx sw150 subwoofer that i want to connect to a pioneer receiver vsx 1020 that has no system connector that the original yamaha receiver had,is it possible to connect the subwwofer to this...
Parts from all-in-one packages like this aren't inended to be pieced out to other applications. Proprietary connections are a huge clue and disincentive.
http://www2.yamaha.co.jp/manual/pdf/av/english/sys/NX-P150_e.pdf
A look at other Fixya queries gives this answer:
http://www.fixya.com/support/t4959365-yamaha_sub_woofer_model_nx_sw150
"I have this sub. The system connector jack needs a 12V DC signal to turn on. If you don't have a suitable Yamaha receiver with this connection, use any 12 V DC adapter with a 1/8 in mono plug (the tip should be positive)."
I imagine the subwoofer could be opened up and whatever circuitry is enabled by the Control signal could simply be jumpered "true" so it is always ON. That would mean the amp would be drawing power at all times, though.
Jul 31, 2011 | Yamaha Audio Players & Recorders
Where can i find a dvd/reciver for the nx-sw300 home theater system/
Here's one with a subwoofer only for $120 delivered Buy It Now. You'd have an extra sub.
http://cgi.ebay.com/Yamaha-DVX-C310SW-5-CD-DVD-Changer-Subwoofer-ONLY-/170602173289?pt=Home_Theater_in_a_Box&hash=item27b8ae9369
Other possible model numbers to search for that may eventually appear ...
DVX-C310
DVR-C310
Mar 06, 2011 | Yamaha YST-SW160 Subwoofer
I have connected all speakers but not getting anything coming through the subwoofer? I have connected all of my existing Sony suround system speakers 4 corner and one middle and the sub woofer to the...
You need to use an amplified sub. The Yamaha receiver is only sending "Pre-Amp Signal" not amplified audio like the rest of your speakers. If your sub has a crossover built in, connect it's speaker level (wires) to the "B" side of the receiver which will send audio to your sub and it will cross it over internally. Not the best sounding, but it works. Amplified subs range in price from 200 and up. Hope this helps
Jun 14, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
Leads
Most of all electronics accessory or parts you can buy it in electronics shop.The leads you said is the RCA cord,input in dvd player output to home theater subwoofer.Tell the shop that you need RCA cord from dvd player to home theater sub woofer.Or you can order it in the site just type googles and search for electronics accessories.That's all jon-jon txt me what the result.
Jun 14, 2008 | JVC TH-M505 System
Dvr-s150 to dvd player
video cable has to goto the tv
audio can go to the receiver i have mine set the same way
May 27, 2008 | Yamaha DVR-S150 DVD Player
Yamaha NX-SW300 sub woofer
Yes, that type of connector is often used for a VGA signal for a computer monitor. But in this case it is an all-in-one connector Yamaha used in order to simplify the hookup of this home theatre system. Unfortunately, the subwoofer is only usable with the DVR-S300 receiver/DVD player.
Apr 03, 2008 | Yamaha YST-SW160 Subwoofer
Sound problems through subwoofer
check all speakers wires andcheck test mode. every thing ok, may be input wiring problem ,check every thing after that internalcircuit may be problem..
Oct 08, 2007 | Audio Players & Recorders
Yamaha YST-SW150 Speaker Logo
1,569 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
