Question about Microsoft MN-700 Wireless Router
Connectivity issues, modem light off and strange behavior.
I've had my Microsoft MN-700 Wireless router for awhile now, and have had no problems. Recently, internet access has been cut off from my labtop, xbox360 and one of my desktop computers, yet my other desktop is still connected. Upon investigating I found that the computer that has the connection has been assigned a new IP address and default gateway. I also cannot log into the router to check the settings. All attempts fail, using the old gateway/ip and the newly assigned one. I've tried hard resets, and power cycling but that appears to do absolutely nothing. I then went to check the router itself got any disconnected wires and such, but it they are all plugged in. The modem light on the Router has stopped lighting up, so I'm gussing the problem is rooted there. Any advice would be appreciated.
Thanks in advance, Brandon.
  • BrandonK Jun 16, 2010
    Hey Terry,
    Sorry it's been awhile since I checked in, but I appreciate the help. The computer that had the internet access went down for a while but once again is back up and running. The first thing I checked when I noticed that the desktop was not working was the connection. And indeed, I am still connected to my internet connection rather than a neighbor's. All of my computers are wireless, and none are wired directly to the router so I'll have to wait until tomorrow before I can hook one up to try logging into the router itself. I'll give you an update as soon as I can.
    Also I don't know if it's relevant but a few days before the problem I removed my WEP key because one of my out of state relatives could not log in to do their work. It worked immediately after but a day or so later is when the problem began.
    Anyway thanks again,
    Brandon.
    Problem Solver:
  • 6 Answers
Hello Brandon, well what I'm thinking here is that, the reason that this one PC is Still Connected with a new IP address, is that it is Prob Connecting to some other Connection outside your Home, maybe some other open wireless Connection, in your Neighborhood, you might want to check on that if you don't know how let me know and I will instruct you how)
next first of all make sure that you are getting power to the router, and if you are, then on a PC that is wired Directly to the Router, follow these directions;
1. depending on what windows operating system your using go to your control panel
2. find an icon called network connections and click on it so it opens
3.when it opens find an item that says LAN OR HIGH SPEED INTERNET, under that will be a icon listed that will indicate local or lan connection-right click on it and you will get a drop down menu, on that menu right click on properties.
4.under where it states; THE CONNECTION USES THE FOLLOWING ITEMS, find an item that says '''INTERNET PROTOCOL'"' AND LEFT CLICK ON IT ONCE just to highlight it. then find the button that says PROPERTIES and click on it.
5. you will get another box that pops up, in this box is where we are going to enter all your ROUTER INFORMATION,
6.IN THE BOX CLICK ON USE THE FOLLOWING IP ADDRESS. then in the IP address field put in this address; 192.168.1.55 the above address will be your PC address.
IN THE SUBNET MASK FIELD PUT IN; 255.255.255.0
IN THE DEFAULT GATEWAY FIELD ENTER IN; 192.168.1.1
now under that you will find an item called; USE THE FOLLOWING DNS SERVER ADDRESS; and the next item under that is; PREFERRED DNS SERVER; in this field enter in; 192.168.1.1
and under that you will find an item called; ALTERNET DNS SERVER; and in that field enter in 192.168.1.2 after your done with that on the bottom of this box and the bottom of the box thats under the one that your on click on OK, AN THEN CLICK ON OK AGAIN, this will close both boxes.
7. now X out of everything that you have open till you see just your desktop.
8.open up internet explorer, and in the address field, type in 192.168.1.1 and click on enter, now this should bring up your router's page, and from there you should be able to configure every item an PC that is connected to your router,
I hope this information helps, you may want to print this out and follow it step by step, so it will make it easy on you.
Terry
Posted on May 28, 2010
I cant connect to friends on xbox live i have a microsoft mn-700 router
XBOX
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then contact the Router manufacturer and Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And Also Make sure that UPnP is Enabled
Dec 24, 2010 | Microsoft MN-700 Wireless Router
All lights indicate unit is operating, but lack connectivity to internet. Hard connection to modem works just fine.
Try unplugging the router for 1-2 minutes, then plugging it back in. This will allow your router a chance to reset its connections and should improve its performance.
Please let me know how you make out.
Nov 12, 2010 | Microsoft MN-700 Wireless Router (p5308j)
Can't connect through microsoft mn-700 router when hooking up trough cable modem
From your very brief explanation, my first thought is that you may not have the wireless settings set up properly in the wireless router.
You will need to connect first with a lan cat5e or similar type cable to first connect with the router.
If you have already done this, then the problem may be with your network adapter in your computer.
unless I knew more specifics, your problem is to vague to help further.
Nov 27, 2009 | Microsoft MN-700 Wireless Router
MN-700 needs constant re-setting
probably overheating u may need to get a new one. :(
May 24, 2009 | Microsoft Broadband Networking MN-700...
The driver of Microsoft MN-700 router
There is no driver required. Configuration of the router is done through your web browser. The address is 192.168.2.1. It would be best to do this via a cable connection as the wireless mode may or may not be enabled. If you do not have the users manual, here is a link to download it: http://download.microsoft.com/downlo...tion_guide.pdf
Good luck
Apr 17, 2009 | Microsoft MN-700 Wireless Router
Cannot get hardwired computer to connect through modem
Is your laptop setup with dynamic IP or static IP? Could it be that the IP scope doesn't match now on it? You could also try running ipconfig /flushdns to make sure there aren't stale entries.
Does the link on the back of your laptop light up green when connected to the router and does the proper green light show up on the router too?
Mar 31, 2009 | Microsoft MN-700 Wireless Router (p5308j)
Connection to iMac not working
the easiest way is hard wire a windows laptop and use the CD that came with the router.
Oct 13, 2008 | Microsoft Broadband Networking MN-500...
Getting dropped by the MN-700
try latest firmware update ok see if that fixes the issue microsoft.com site or custum windows update then re do settings u dont relly need 256 bit man ok 1268 fine with reg password
Mar 13, 2008 | Microsoft MN-700 Wireless Router (p5308j)
Ms700 router
Your laptop must be plugged into port 4, correct? Try this (assuming Windows XP): Click Start, then Run. In the box type CMD and click OK. In the black window that comes up type (without the quotes) "IPCONFIG /RELEASE" . Wait for the prompt to come back up then type "IPCONFIG /RENEW". Wait a few seconds. Type "EXIT". Try your Internet again.
Hope this helps!
Dec 26, 2007 | Microsoft MN-700 Wireless Router (p5308j)
No connection...lights not flashing
check CPE. ensure cables are good, confirm LAN and NIC is enabled. confirm that nic settings correct ie linkspeed and duplex settings, uninstall and reinstall if necessary
Dec 05, 2007 | Microsoft MN-700 Wireless Router (p5308j)
Open Questions:
See all Microsoft MN-700 Wireless Router Questions
Microsoft MN-700 Wireless Router Logo
199 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
