Question about RCA D52W19 52" Rear Projection Television
Tv does not start properly
Tv tries to start three times and shuts off. if i try enough times it finely comes on
  • RCA Master
  • 8,617 Answers
The repair kit called CP150, CP120 and CP114 available from www.tvrepairworld.com the kit also contains the instructions.
Posted on May 25, 2010
My RCA model # HD52W59, power on and shuts down without coming on. Green come on then shuts down. No picture or sound.
The set is in shutdown because of a problem inside, this model has the three strikes and your out, it will try three times to come on and then latch down. It likely needs a shop repair of some kind.
Aug 27, 2012 | Televison & Video
Power botton flashes but will not come on
my rca 52 projection tv started to shut off on its own
after some research I pulled the main board and replaced
three capacetors that looked suspect replaced board and tv
worked fine for 3 days and went out again any suggestion.
Aug 20, 2012 | RCA D52W135D 52 in. TV/DVD Combo
Samsung DLP 72" HL72A650C1F keeps turning off amd on
Did you buy the original lamp?
If the problem is related to the lamp door switch, you will get a different error instead of lamp LED.
Do you hear the color wheel spinning?
Again, if it's a color wheel problem the error will be different!
My good guess is the lamp but, it could be the ballast or both.
Best of luck
www.aaatvservice.com
May 08, 2012 | Samsung SELECT HL72A650C1F Rear Projection...
I have a ge hdtv monitor. when I shut it off I have to keep turning the power button on several times to get it to come on. the power light comes on then goes off three times. then i have to wait and try...
there is a leakage in current supply.please be sure that your plug is pluggged in properly,and try to start it again. if problem appears again chang the wire of your monitor.
Nov 22, 2010 | GE Televison & Video
LCD TV HAS THE PROBLEM, THE PICTURES ARE FAINT AND THE COLOURS UNCLEAR, SO PLEASE HELP ME TO SOLVE THE PROBLEM
you might have some dust inside the light engine you should dust out your TV set and if you clean the TV and still have the same problem then I would say you have a problem with your optical block
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!!
Oct 11, 2010 | Sony KDF-E50A12U 50" LCD HDTV
I have 50" lg Plasma tv. When I start it first thing during the day the power comes on then shuts off. I have to repeat three or four times befor it comes on. I have checked the power source and the cord...
The UF capacitors on your PSB-power supply board are blown. Your tv is putting itself in fault protection mode to keep it from damaging more components internally. Soon enough the TV won't come on at and you'll be left with a blinking fault LED.
Jun 30, 2010 | LG 50PX4DR 50 in. Plasma TV
Laptop won't startup properly
Friend that problem if cause of not shutting down properly.just select start safe mode as it recovers it will restore late back to the proper one
Jun 05, 2009 | Tablets & eReaders
Loud Fan, Three Beeps, Black Monitor and No Keyboard response
I have the same model after youlet it sit for a long enough period to cool down it will come back on and work normal, it is a cooling problem called gateway and they confirmed this theproblem I ran in to was what fan this computer has 3. temp fix I used was to remove the tower cover to allow better air flow try this till you can figure out what fan is messing up
Jun 02, 2008 | Gateway GT5404 PC Desktop
Blank screen, no sound
If ti blinks three times, then it may be an issue with the flyback transformer. It's called "three strikes"...it tries three times to come on, and after that enters a safety shutdown mode to protect the TV. Might need to have a professional shop take a look at it.
May 02, 2007 | Durabrand DWT1905 TV
RCA D52W19 52" Rear Projection Television Logo
71 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
