Question about Bosch SHU5315UC Dishwasher
The dishwasher will not drain.
The dishwasher all of a sudden stopped draining. At the completion of a cycle we opened the dishwasher to find that the waer would not drain. I checked the drain screen but nothing was blocking it.
  • 901 Answers
Check your main drain system. Remove the drain hose from that end and discharge them in a bucket. Try a new wash an if the m/c drain system is ok, it will discharge water in the bucket.
Check the house main drain for clogging at the hose connecting end.
Posted on May 26, 2010
Bosch dishwasher shx46a06uc-30
the unit will try to complete the last command it was engage in before it went in the overfill safety mode. you must perform a cancel drain cycle to reset unit to default setting. Remember the drain cycle is 2 min and must be completed to reset main control. however if it went into a overfill status you have a leak and it generally comes from the pressure chamber on the lefthand side of unit where the water enters tub
Apr 17, 2012 | Bosch 24 in. SHX46A05UC Built-In...
Whirlpool gu1200xtls2 wont drain just stopped
Hello
your Whirlpool dishwasher stopped draining mid-cycle, check your circuit breaker or fuses. The cycle won't complete if the power is interrupted. Reset the circuit breaker if tripped, or change out any blown fuses. Fully close the dishwasher door, and restart the cycle if you opened up the door. If you have not used the dishwasher in a while, the motor may be stuck. Open up the main housing, and rotate the motor until it turns freely. You must replace the motor if it's corroded or won't move since it's unlikely that you can fix it.
Pump
The pump is located underneath the lower rack and spray arm. This component is responsible for pumping water out of the dishwasher once the cycle is complete. If the pump isn't working, verify that it is not clogged with debris. Use a toothpick or plastic utensil to remove food particles from it. Check the pump impeller. If a section of it is broken, get a new pump since the impeller is difficult to fix.
Clogs
Clogs in the air gap or drainage hose prevent water from leaving the tub. Clean these components and the water inlet filters, if dirty. Examine the drainage hose, and straighten it if it's kinked. If the hose is badly crushed, you must replace it. Unscrew the drainage hose from the dishwasher to clean it, but reattach it before you restart the cycle. Run the food waste disposer if it's connected to your Whirlpool dishwasher. Remove the knockout plug from the disposer if you have just installed the disposer or dishwasher.
Drain Valve/High Drain Loop
Whirlpool dishwashers have drain valves with an internal solenoid. This valve opens and closes to drain water out of the tub. If the drain valve is stuck, lubricate the lever, and remove any debris clogging the valve. Remove any objects that are preventing the drain valve from freely opening and closing. If the valve is not working properly, you must replace it. Always install a high drain loop to prevent water from the sink entering your dishwasher. Create a loop of the drainage hose that is at least 18 inches high. Attach this hose beneath a section of cabinetry.
Sep 28, 2011 | Whirlpool Dishwashers
Washer won't drain. Water remains in bottom of washer after cycled is complete.
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn't overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn't working properly, the drain pump isn't working correctly, or possibly there is a plumbing problem in your home's drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. If you have checked the drain hose and can't locate the problem, then it is an issue with the drain pump of the dishwasher. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 06, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
My dishwasher will not drain
could be a blocked drain or faulty drain pump or faulty controller.
Do you have a model no.
Also confirm if the wash cycle did start correctly and it ran through it according to the time. Does the dishwasher stop in the middle of the cycle or it completes the cycle with lights turning off but water still inside.
Did the drain pump actually run?
Sep 06, 2010 | Frigidaire Dishwashers
Runs the cycle but doesn't drain completely
Hi
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 12, 2009 | Kenmore Dishwashers
Stopped in mid cycle, won't drain
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to some different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then you may want to consider calling a professional plumber. He may need to replace the drain valve or hose.
Thanks
Rylee
Aug 31, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Bosch dishwasher doesn't drain anymore
I would check the pump if its clear but not pumping down correctly check the drain hose if that's also not clogged then look into replacing the pump.
Jul 04, 2017 | Bosch Integra® 500 SHX46L Built-in...
Dishwasher with one inch of water in bottom when complete
undo the drain hose from your drain and put it in a 5 gallon bucket and see how it drains your sink drain maybe stopped up or if it drains into a disposal it may be stopped up
Apr 24, 2009 | GE Adora GHDA656LSS Stainless Steel...
Not all of the soap dissolving, some left in dispenser and bottom
Kitchenaid lists 130 dishwashers with this model. Need the rest of the number
KUDSO1DLxxxx
Back in the day, when I worked on K Dishwashers, the drain valve was the problem typically.
It would get a piece of glass, from broken glass or other item, or a toothpick, whatever stuck in the drain valve. It would not completely close. During the wash cycle, water would be trickling down the drain and by the time the soap dispenser opens, the water would be gone or nearly gone.
Check this. When you hear the dispenser snap open, stop the dishwasher and open the door.
If you have little or no water, you are losing the water during the wash cycle.
Let me know.
Gary
Nov 22, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
BOSH won't stop draining
take your dishwasher out and look for a water at the base of your dishwasher.
If that is a water at the botton base, just dry the water and its ok.
if you dont find water at the botton base inside replace the water level system PN= 263834 at repairclinic.com, item# 935595 for 41.00 and that part goes in the left side of your dishwasher
May 24, 2008 | Bosch 24 in. SHX46A05 Stainless Steel...
Bosch SHU5315UC Dishwasher Logo
231 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
