Question about Polaroid Televison & Video
My polaroid LCD has four lines going half way accoss the screen, from left to right and it is giving it a double vision look
  • mikburk May 31, 2010
    I am not sure what I am going to do, I might just get anohter tv.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To check what has gone bad you’ll have to open the back of the unit and check the backlight inverter board. The inverter is the power supply source for the backlights. If that’s the issue then it’s always better to replace the inverter board completely just to avoid any future issues. If not then check the power supply board however, it seems to be the inverter board as the sound is still working fine.Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 31, 2010
  • 2 more comments
    Which one is the backlight inverter board and how much will a new one cost?
  • Rylee Smith
    Rylee Smith May 31, 2010
    Please check the below picture as inverter board looks like this, and is normally supplied by a dedicated voltage from the power supply (24vdc):
    Replacing the inverter board will cost you around $250 including labor and you can buy the parts from this link. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    is this something I can do myself or do I need to take it to a repair person?
  • Rylee Smith
    All
    this is only recommended if you have electrical expertise and know how to
    solder/re-solder components. Please note that the TV components consists high
    voltages even when in off position.
    Thanks
    Rylee
Sony kdl52xbr4 tv has double vision on right side of screen perfect picture on left side is this a timing control board issue?
Fault with its T'Con board itself. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 14, 2015 | Sony Televison & Video
Double vision screen
This is most certainly a display problem, as in, a problem with the LCD panel. I used to fix 4 or 5 LCD's a day and had a few with the same problem. It can be fixed by being replaced.
Jan 06, 2014 | Computers & Internet
Have a 42in polaroid hdtv... half the screen is colored lines butb the other hjalf is fine with good sound & pic
Usually a board---different names for each brand: Sustain, Y, Z etc.
Some sets (sound like yours) use one to drive right side of picture and another for left side.
The only bad news is Polaroid parts may be difficult if not impossible to find.
Mar 14, 2012 | Polaroid 4241-TLXB 42 in. LCD Television
I have a Polaroid 40" TLX-04011C. The screen resolution is fine except for about a 4" area along the right side from top to bottom. This area is lighter than the rest of the screen. The picture is still...
I have not repaired this particular model. But I have repaired another polaroid flat screen TV. I can tell you for sure, the biggest problem here are bad capacitors in the signal board. You may find 15 or 20 bad caps. On the power supply there may be a two or three caps that need replaced as they will be weak but not real bad. Yes,the majority of the caps will be found in the signal board. You will need a good capacitor checker to locate these. It will require patience and skill to remove and replace these caps. I cannot say enough of bad capacitors in this TV. Find a TV tech to help you! Thanks for asking, show me a few hands of appreciation. This answer is your best effort for repair!
Sep 19, 2010 | Polaroid TLA-04011C 40 in. LCD TV
LCD displays 4 white lines and has double vision
I saw your tv pictures at above mentioned website link.
It is LCD Panel (screen) problem, call Sony and ask for warranty cover to replace lcd panel.
Thanks.
Jul 18, 2010 | Sony KDL40EX400 40 in. HD-Ready TV
Double vision my NEC MT1055 lcd projector has double vision on the menus - looks like the menu was burned in a half in to the left
looks like one of your lcd panels is ghosting. If remember correctly your going to be asked to replace the whole prism.
Aug 28, 2009 | NEC MultiSync MT1055 Multimedia Projector
I Think NO expert can help this problem because it free answer
I think I may finally have the answer for the "black screen of death" for the 42" Polaroid LCD televisions. I was having the same issue with the screen going black after a couple minutes of being on. I would shut it down then turn it back on and it would work again for 5-10 minutes. On the "power board" which is the board on top, there is a little red light that turns on when the screen would go black. above that there are 4 little switches, the lower on says BURN. I simply switched that over and the television has been working for 2 days for 8 hours + each day. Hope this help. Let me know
Mar 20, 2009 | Polaroid FLM-3225 32 in. LCD Television
LCD HDTV WITH VERTICAL RAINBOW LINES
Polaroids are known for bad capacitors in their units
pull the back off look at the circuit board check for bulging or leaking capacitors.
Jan 24, 2009 | Polaroid FLM-2634B 26 in. LCD Television
42" LCD tv shows picture on only half of the screen,other half dark!
The T-Con board (otherwise known as LVDS) connects to two seperste parts of the LCD panel. If you do have half a picture (left or right) replacing the T-Con board should resolve this issue. Open your TV, find the part number and search on eBay or at sites like www.flattvparts.co.uk where you can search by TV model number.
Oct 27, 2008 | RCA L26WD26D 26 in. LCD TV
Televison & Video Logo
47 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
