Question about Zanussi F1045W Front Load Washer
Zanussi wj1054 front load
My Zanussi wj1054 Jetstream is 4 years old and has been used on average twice a week. I get a buzz when the on button is pressed then before any programme is selected the water starts coming in and is pumped straight. When a programme is selected the start/pause flashes continuously and the machine carries on filling and emptying as before.
Sometimes the door lock operates when the on button is pressed and sometimes it doesnt.
A new pump has been fitted and a new door lock fitted.
The oultet hose is at the same level as it always has been.
I have tried advancing the programme to spin but still nothing else happens. Can you help is the machine beyond economical repair. The brushes have been checked and still have about two thirds of the original length left.
  • Zanussi Master
  • 3,463 Answers
Check the water level pressure chamber for a partial blockage, this can cause all sorts of problems.
Posted on Dec 10, 2008
Spin only on Zanussi Jetstream 1400
no agitation check timer and control board. but more likely culprit is the water pressure switch. Which determines water level and when machine goes into agitation mode?
Sep 26, 2014 | Zanussi Washing Machines
My Zanussi washing machine is smelling
I have this problem with my Siemens machine, it is due to mainly running low temp washes and bateria building up in the hoses etc. (more prevalent if the machine is connected directly to the sink and not on a stand pipe). I run a 90 degree cycle every 4 weeks with the machine empty except for two capfuls of baby sterilisng fluid (approx half a mug) I buy stores own as it is cheaper than miltons. The first time I did mine I ran the cycle twice to be sure it was cleared out. My machine is six years old and the first smelly signs were when it was about a year old, I run the maintenance wash religiously ever 4 weeks and run a machine descaler such as oust thru every 4-6 months. Hope this helps. Roni. (ps don't be tempted to use bleach as it foams up and can cause more problems!!)
May 23, 2010 | Zanussi ZWF10070W Front Load Washer
Error 10 message
E10 means there is no water getting in to machine.
check water supply if ok then fault will be fill valve.
Mar 07, 2009 | Zanussi ZWF1430W Front Load Washer
The motherboard is blown the part is covered under warranty which will take 4-5 days to come in and I have to pay for the labour.
Jan 22, 2009 | Zanussi ZWF1430W Front Load Washer
Burning smell and loose drum
If it is really noisey when it spins then this can only mean one thing.... the drum bearing are shot, its a complete strip down job, not an easy job for a beginer. Sorry
Dec 23, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Noisy during some parts of the cycle
it could be the concrete ring situated at the front of the machine. i had the same problem with mine 2 years ago.
Jul 29, 2008 | Zanussi FJD1266W Front Load Washer
Opening the door
Have you tried to disconnect it from power mains for a few minutes to see if that will reset the security timer?
Dec 05, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi error code 30(model zws 1640s)jetstream time line.
Does the machine drain out water in the beginning of the process ? In case it drains out water: -Check first the filters on the inlet water line. - If problem still exist,test for 115/220V on solenoid tags. Good luck !
Aug 06, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi F1045W Front Load Washer Logo
122 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
