Question about Whirlpool Duet GHW9150P Front Load Washer
Washing machine making vey load something is wrong noise. Called repair man, he states too young (2yrs) to be a drum problem and okay to use just do smaller loads. On 2nd load found metal shavings..have not used since but repairman whom thought it was the shocks has not been able to make it out. What would metal shavings mean?
  • th4201 May 26, 2010
    It's not too young to be a drum problem. Where did you find the metal shavings? Are you sure they're not dark plastic shavings? Plastic shavings near the front lower portion of the inner tub would be more likely, which would be caused by a rear drum bearing problem. More information would be helpful, like, does it make any noise when it's washing? Spinning? etc.
  • jshoffman67 May 26, 2010
    Yes it makes more noise than usual but mostly when it is spinning. We did find the shavings in between the inner tub and seal and just checked and they do actually appear to be plastic vs metal...So this could possible be rear drum bearing problem? Any cost estimation? Thanks for your help
  • 24 Answers
The rear half of the outer tub that contains the rear metal bearing has loosened so much that the inner drum has sagged and is rubbing on the front half of the outer tub. You need to see if this is under warranty. There is usually a 5 year warranty on the outer tub and a 10 year or a lifetime warranty on the inner tub. When I do this repair, I replace the rear half of the outer tub and the inner drum since it's under warranty anyway. The repair is the most difficult and time consuming repair possible on that type of washer. It needs to be done by an expert, not just your average washer repair guy. It's not rocket science, but you have to take EVERYTHING apart and it takes a long time and you've gotta know a few things about the machine in the first place. It's not fun. If it's under warranty for parts, expect to pay between $75 and $200 for labor. If the parts are not under warranty, then throw it away. They're $500+ for the parts.
Posted on May 26, 2010
Hello, I have a front load LG TROMM WM2277HB and yesterday it wouldn't spin anymoreand there was a noise coming from inside like 2 metal cylinders were rubbing on each other. I called SEARS Serv
if the machine fails to spin and makes noise there are thee things to check .if it fails to drain the water check if something is stuck on the drain pump no 2 turn the drum with your hand and check if the drum is moving freely if not something is stuck between the drum and the housing if the bearings are faulty the machine spins but makes alot of noise towards the end of the cycle i hope this will help you.
Jan 21, 2013 | LG 4775er2002a Door Hinges for Wm2277hb...
I HAVE SOMETHING STUCK BEHIND DRUM IN HOOVER 200M WASHING MACHINE HOW DO I FIX
Hi, I am having the same problem atm and was wondering if you fixed it?
Where there any damages to the machine and how much did it cost to repair if you called a repair man?
Thank you
Claire
Nov 20, 2010 | Hoover Washing Machines
Kenmore washer started making banging noise in last spain cycle. Now unable to spinn drum by hand.
Having same problem with my Kenmore 500. Tomorrow will be the second time a repair man has visited the house. Washer on 5 weeks old. Drum bangs every other load. Load not unbalanced. Avoid this washer, it is a POS.
Mar 20, 2010 | Kenmore 24902 Top Load Washer
I have a Bosch classixx 1200 express front loading washing machine. This morning I loaded 3 towels and put onto a hot wash - when I came home from work and opened the machine (thinking the washing had...
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer ID doesn't mean
much to me. It's been about 55 years since I had
experience with front load washers. However I can
suggest you go to www.applianceaid.com where
they have very good trouble shooting and repair
information on front loaders. I think you'll find what
you need there. Good luck with it.
Nov 27, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Machine won't spin
When washing does the unit rotate in both directions ? If NO, the problem (likely) is the motor/brushes. If YES, insure you're not overloading or using non-HE detergent or more commonly refered to as "regular" detergent/soap. (soap is a very bad thing for these front load units).
Sep 20, 2009 | Bosch Axxis WFL 2060 Front Load Washer
RATTLING & DRUM NOT SPINNING EVENLY, ALTHOUGH CHANGED BEARINGS TW
Check the belt. it may be broken or, it may have slipped of the pulley or drive motor. if the belt is fine, replace the motor.
Jul 11, 2009 | Kenmore 98702 Stacked Washer/Dryer
Noise while spinning.
It is rare that a noise is related to something sticking in the drum on those machines. The most likely cause of the noise is bearing failure on the main drum spider assembly.
Oct 23, 2017 | Hotpoint WMM75 Front Load Washer
Washer makes loud knocking noise
I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. You can also move the inner drum up and down to see if there is something wrong with it..
Sep 28, 2008 | Roper RAS6233KQ Top Load Washer
Samsung J1045 Front Loading Washing Machine Loud Banging Noise
Throw it off a cliff. I have the same model and have had so many problems. Don't even bother calling customer service, they won't help. Cut your losses and buy a new machine
Mar 06, 2008 | Washing Machines
Clinking noise
after the load is done look in the unit it and hand spin the drum slowly It sounds like you have a coin or something stuck in the baffles rotate untill you can pin point it..
Jan 27, 2008 | Indesit W 123 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
284 people viewed this question
Dan Webster
Dan Webster
Sal De
