Question about GE 22.3 Cu. Ft. Bottom-Mount Refrigerator - White-on-White
THE REFRIDGERATOR PORTION IS NOT COOLING AS IT SHOULD
THE TOP PORTION IS VERY WARM ALTHOUGH IT IS SET TO 5 WHILE THE BOTTOM FREEEZER IS WORKING VERY WELL WHEN SET JUST AT 3
  • GE Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
RefrigeratorTHE REFRIDGERATOR PORTION IS NOT COOLING AS IT SHO - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 26, 2010
LG Fridge not cooling refrigerator (freezer is fine, fan is running)
those sensors do fail but if the freezer is not as cold as it should be .then the refrigerator part will also not get proper cooling . TEST the freezer temp .
Sep 25, 2015 | LG Refrigerators
KENMORE TRIO 2004 59675523400 REEFER/FREEZER NOT COOLING
it should not be the compressor as the bottom is only not cooling.
Jun 23, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer stays cool but bottom stays warm.
I agree with your analysis, and recommend that you replace that fan between the two sections.
May 20, 2008 | Kenmore Refrigerators
My freezer works but the refridgerator doesn't get very cold
If freezer works airflow into reefer box from the freezer box is too low, ironically enough although the thermostat saying 1-10 and OFF, controls the temperature/compressor operation setpoints desired, but the second setting saying COLDER/WARMER, when set to COLDER actually makes the freezer box colder by starving the reefer box!!! if you back of that settting to middle the reefer will get air again, A very common issue , caused by this wording, it says COLDER freeezer if you really look most just peg both and say hey the reefers warm and freezers cold??and both are set max cold, or so it seems!
Nov 01, 2010 | Frigidaire Refrigerators
Top freezer refridgerator freezer works refridgerator not cold. back coils are warm.
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
heatman101
Mar 24, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
I have ice accumulating at the bottom of my JennAir side by side refridgerator on the freeezer side. any idea why ?
First make sure the door is sealing properly.
If it is at the bootom of the freezer behind the backpanel is a drain hole this has become clogged. To unclog try some warm water and a piece of wire. Pour in about a cup of warm water to melt the ice then run a wire down the tube. This is where the water from the defrost cycle goes. There is a drain pan underneath to catch the water. for a diagram go to www.appliancehelponline.com and enter your model #.
Mar 23, 2010 | Jenn-Air JCD2389G Side by Side...
Refrigirator is not cooling. Freezer is cooling
if you have a bottom freezer, you need to defrost the unit the cool air from the freeezer is what cools the top part, but the channels are iced up
unplug the unit and let it thaw out overnight
Sep 12, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Water on the bottom shelf of the Refridgerator
Has the refrigerator got a wet inner back?
Ff this is wet, adjust it until this solid ice 'blobs', bt not encrusted, like in a freezer
The refrigerator may not be cool enough and the natural warm moisture allowed into the cool compartment when the door is open is condensing into fluid before it is cooling sufficiently to suspend the moisture as a vapour. If the cool compartment is cool enough, any warm air admitted ill be chilled before it is allowed to condense, keeping the refridgerator dry.
However, the only drawback is that you will have to monitor it to prevent the build up of excesive ice.
Also, whether the refridgerator is either empty of full willaffe the day to day operation.
Hope this helps.
Oct 20, 2008 | Whirlpool ET1FHTXM Top Freezer...
Fan keeps freezing
HI .did you pull the fridge, away from the wall, and clean out the drain tube ,at the back. if not pull fridge away from wall, find the drain tube, and clean. thanks the appliance doc
Aug 04, 2008 | GE PDS22SBRLSS Bottom Freezer Refrigerator
GE 22.3 Cu. Ft. Bottom-Mount Refrigerator - White-on-White Logo
120 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
