Mobo only one ide connection socket for HDD & CD-Rom
I have just renewed my Motherboard to a Gigabyte s-series and find it only has one ide cable socket whereas my old motherboard had 2 sockets one for my hard disk and one for the CD-Rom.
Is there any way I can connect both items to the one socket.
Appreciate any help with this problem
Thanks.
  • Anonymous May 11, 2008
    i will connect cd-rom with with my pc intel r dot station
  • dellseys Jan 06, 2009
    i upgraded my desktop with a new motherboard i used to use p 3 board and case so i had to change th case as well. all done, i had this ide cable 3 in one . i tried connecting one to the CD one to the hard disk and the last one to the motherboard.
    when i boot the machine it those not want to read a bootable windows CD even though the cdrom is set to first in priority. the hdd also has windows already installed on it when it gets there it wants to boot the windows when it attempts to do so the systems reboots. i made the hdd master and cd-rom slave wat can i do
  • 655 Answers
Yes you can add both your HDD and CD-ROM Drive with the same IDE, get a IDE data interface cable (BUS) atleast three connection point. Add 1 to mobo, second to HDD and top 1 one to CD-ROM drive. Just connect and dun wrry m sure it will work....so............:))
If any problem just Ask me
Thanks
Iqbal
Posted on Apr 07, 2008
Power not up
1) Please make sure that the HDD IDE cable is plugged in properly on both ends. It is a 40 pin female cord which should be seated on IDE channel 1 on the motherboard.
2) Make sure that all the CD/DVD drives are on IDE 2 or on SATA
3) Make sure taht the Jumper setting on the back of the HDD is set to MASTER
4) Login to bios and make see if you can find the HDD from the IDE drives menu. I am sure you will. From Boot menu select the NATIVE mode that will activate both the SATA and the IDE channels. Select HDD as second boot device.
Feb 01, 2012 | Intel Gigabyte GA-8I845PE-RZ 845PE chipset...
Can 500gd hard disk be connected to gigabyte 945gcm-s2l?
Yes you can, there won't be any problem install 500GB hard disk on your motherboard. It is recommended to use SATA type Hard Disk Drive instead of the old IDE/ATA.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Sep 07, 2011 | Gigabyte GA-945GCM-s2C socket LGA775...
What kind of RAM memory uses this motherboard
Gigabyte GA-5SMM - motherboard - micro ATX - Socket 7 - SiS530 specifications
  • General
  • Product Type Motherboard - Micro ATX
  • Cache Memory L2 cache - 512.0 KB
  • Chipset Type SiS530/5595
  • Max Bus Speed 100.0 MHz
  • Processor Socket Socket 7
  • Compatible Processors 6X86 , Cyrix MII , WinChip 2 , WinChip C6 , K6-III
  • Memory
  • Max Supported Memory 256.0 MB
  • Supported RAM Technology SDRAM
  • Supported RAM Integrity Check ECC
  • Expansion / Connectivity
  • Expansion Slot(s) 1.0 x PCI - Socket 7 , 3.0 x Processor - DIMM 168-pin , 3.0 x ISA , 2.0 x Memory
  • Storage Interfaces ATA-66 - connector(s): 2 x 40pin IDC
  • hope this helps
Aug 13, 2011 | Gigabyte GA-5SMM Motherboard
DOES GA-945GCM-S2C SOCKET LGA775 SUPPORTS 500GB HARD DISK AND DOES IT SUPPORTS 2GB DDR2 RAM
GA-945GCM-S2C
Memory Support:
__2x1.8V DDR2 DIMM sockets supporting up to 4 Gb of system memory.
Note:Due to Windows Vista/XP 32-bit operating system limitation, when more than 4 GB of physical
memory is installed, the actual memory size displayed will be less than 4 GB.
__Support for DDR2 667/533/400 Mhz memory modules.
Note:Use of a 1066/800 MHz FSB CPU is required if you wish to install DDR2 667 MHz memory!
Storage:
South Bridge:
- 1 x IDE connector supporting ATA-100/66/33 and up to 2 IDE devices
- 4 x SATA 3Gb/s connectors supporting up to 4 SATA 3Gb/s devices
iTE IT8718 chip:
- 1 x floppy disk drive connector supporting up to 1 floppy disk drive
Dec 03, 2010 | Gigabyte GA-945GCM-s2C socket LGA775...
Gygabyte ga-7n400 pro 2 wont start
How many beeps do you hear and what are the durations? (short, long..) On the surface, make sure the memory speed and configuration match your motherboard.
Good Luck
C2Solutions
Aug 07, 2009 | Gigabyte GA-7N400 Pro 2 : ATX Socket A...
Mortherboard
CPU:
Supports Intel Pentium 4 Socket 478 processors with 800/533/400 MHz FSB
Supports Intel Hyper-Threading Technology Chipset: Intel 865PE / ICH5-R
Supports Dual Channel DDR 400 Memory
Supports Advanced Configuration and Power Management Interface (ACPI) Memory: Six 184-pin DIMM sockets
Supports Single/Dual Channel DDR 400 memory (Max. 4GB). Audio: High quality 6-channel AC'97 audio with S/P-DIF function with JAck Sensing IDE/SCSI: Dual Ultra DMA 66/100 IDE controllers integrated in ICH5R- up to four Ultra ATA drives
Serial ATA/150 controller integrated in ICH5R- Up to 150MB/sec transfer speeds
2 channels Serial ATA 150MB/s data transfer rate via Silicon Image PCI controller
GigaRAID IDE RAID Controller I/O Connectors: PS/2 Keyboard and mouse, 1 x Parallel, 2 x Serial, 4+4 x USB2.0, 1 x RJ45, 1 x Audio Expansion Slots: 1 x AGP (3.0) , 5 x PCI (2.3), 1 x DPS Additional Features: GIGABYTE Patented Technology Dual Power System 2 (DPS 2)
GIGABYTE Xpress3 Series Software
from the above configuration for the board you can see that it supports up to 4GB ddr max
hope this helps pls appreciate by rating as fixyaa
Oct 05, 2008 | Intel Motherboard
Need to find the right graphic driver for motherboard
There are 2 basic versions of the Gigabyte GA-8I865GVMK motherboard; Socket 775 & 478. The socket 775 has 2 versions (Rev. 1.0 & Rev. 1.1) Please be reminded that drivers are very OS specific and must conform to the model/version and revision of the particular motherboard.
Drivers are:
Socket 775
GA-8I865GVMK-775 (Rev 1.0)
GA-8I865GVMK-775 (Rev 1.1)
Socket 478
GA-8I865GVMK
Hope this be of some help/idea. Post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 07, 2007 | Gigabyte GA-8I865GVMK Motherboard
Computers & Internet Logo
304 people viewed this question
David Payne
David Payne
