Question about Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor
Its an automatic transmission and it stopped moving. I cant move forward or move backward.
  • 420 Answers
Make sure the neutral rod is pushed all the way in. the rod is in the back of the tractor.
Posted on May 27, 2010
Transmission not move forward backward
Probably. There may be a solenoid not working which is keeping the transmission from engaging the forward gear train but for it not to work at all is unusual.
May 12, 2013 | Plymouth Grand Voyager Cars & Trucks
2003 gmc envoy - will not move when i put in reverse
Sounds like the pump is going bad inside the transmission.
You could also have a leaking seal when the transmission heats up enough to expand and leak. That or if the electronics controlling the transmission are getting excessive resistance do to a short, that could also cause the problems you are describing.
Nov 24, 2017 | 2003 GMC Envoy
Can anyone help? My Cub Cadet LT1045 won't move (foward/backward).
Hi, check that the drive belt, pulleys and shafts are all ok and that they are actually driving the transmission, hopefully you will see the problem. If the transmission is driving ok and the fwd and reverse lever is functioning as you said, the transmission may have failed. Also check the hydro release lever is functioning. Regards Phil.
Jun 25, 2012 | Cub Cadet Garden
1994 Buick Regal Custom 3.8L the automatic transmission will go in reverse it move backward and in drive move forward then on highway atleast 5 miles automatic transmission quit. What cause this stop
it sounds like you have to much trany fluid in the trany.check the fluid level .if fluid is to much it bubbles at high speeds and if to low it can slip
Apr 25, 2012 | Buick Regal Cars & Trucks
Transmission locked up - could not move in any gear, neutral only allows to roll backward not forward - what could it be? 200 land rover discovery with 182k miles
Is it a manual trans and when you say "could not move in any gear", does the engine stall when you try to move it? When it moves backward is that with the engine moving? If you answered yes to both questions then the trans is stuck in reverse. You may still be able to move the shifter but something has failed internally. If it has an automatic trans then you may have a simple linkage problem, or it may require a more in-depth inspection.
May 23, 2011 | Land Rover Discovery Cars & Trucks
Car will start but will not move forward or backwards can u help?
Mke sure that the transmission is working. you can tell if the engine rpm changes when you put it gear (forward or reverse) if it does not then you need to check the level of the transmission fluid for an automatic or you may have clutch problems if it is a manual transmission. if you have more details on the transmission type (auto or manual) and if it is doing anything when you try to get it to move that would be helpful.
Nov 20, 2010 | 1991 Nissan Maxima
Car cannot move forward while engine running
check transmission fluid first.if its low add to get correct level.if transmission fluid look dark smells burnt replace fluid and filter.if car still dont move forward.looks like you have bad worn out forward clutch plates and seals.also bad transmission oil pump.you need a overhaul or new transmission.
Jan 01, 2010 | 1995 Toyota Corolla
Car stops moving in reverse gear
Sounds like the car is just slipping out of gear. Keep your hand on the shifter when you back up next time. See if you can feel the shifter move when the car comes out of gear. If the shifter moves up when it happens keep pressure on the shifter holding it back like you dont want it to move forward. And of course if the shifter moves back when it comes out of gear, put forward pressure on the shifter so it doesnt slip out. This might work for now but but i know i wouldnt want to spen 700 for that ****. Let me know how it goes.
Nov 20, 2008 | 1999 Honda Accord
Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor Logo
426 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
