Question about Canon CLC 1120 Color Copier
I have a paper jam on a CLC 1120 and there is no paper jam I've check the machine 10 times
    Problem Solver:
  • 5 Answers
You didn't state where the jam is indicated. If it's indicating a paper pickup jam there are levers toward the back of the cassette that could get hung up.If it's a fuser jam the outlet lever on the fuser unit.If it's indicated in the transfer drum area a bad transfer sheet can give a false jam indication sensing paper on the drum.
Posted on Jun 11, 2010
I have this error codecode e000 and 0105 under when i turn on my Canon CLC 1180. where was the fuser user in the CLC? How can i check it?
I think the 1180 is close to the 1120 copier I know. The error code is indicating an upper heater open circuit. The fuser is the very left item when the main drawer is pulled opened to remove a paper jam. There are two handle grips front and rear to remove the assembly. You have to check continuity of the heat lamp, fuses, etc.
Jun 13, 2011 | Canon CLC 1180 Copier
Cano CLC 1120 error E004 0203 E072 0203 the machine turns on and off the merger does not light not heat MOTHERBOARD TESTED OK, FUSION SYSTEM TESTED OK, TRANSFER SYSTEM TESTED OK, WHAT SHOULD SPARE CHANGE...
Hi
This error is caused due to faulty thermister however; you can check the fuser unit for any jammed paper around the upper fixing roller and try to clean that area. After this is done try to clear the error by entering the service mode, to enter press Additional functions, #. Then go to #7 Printer and press OK, then go to #4 printer reset and press OK, yes= *. If the issue returns then replace the thermistor. Hope this helps...please post back for further assistance.
Daniel
Mar 03, 2011 | Canon CLC 1120 Color Copier
Paper jams
first try to clean paper feed rollers in cass.
Jul 27, 2010 | Canon CLC 1120 Color Copier
Paper jam and no paper to be found in the copier
Possible misfeed, first replace or clean feed tires. The machine is not picking the paper up in time ,hence no paper in machine.
May 25, 2010 | Canon CLC 1120 Color Copier
Paper feeder not pulling paper from drawers, it does pul from the drawer but then when the second stage is supposed to pick up it does not and indicates a jam.
Have you replaced the paper pick up & paper feed & paper sep. rollers? If not try to clean the rollers with Wd-40 or simple green. If the copier works better, you will need to replace the rollers. Good Luck
May 17, 2009 | Canon CLC 1120 Color Copier
CLC 1110 E71?0007, E071?0002, E072 error codes.
On my CLC 1150 copier machine, I have an error code E071 – 0002.
Sir plz send soluation this error
Dec 12, 2008 | Canon CLC 1110 Copier
Paper Jammed
your sensor is detach or bad where it says paper jam
Oct 08, 2008 | Canon CLC 1120 Color Copier
CLC 1120 code e071, sub code 001
there maybe a piece of paper or some dust in one of the transfer drum drawer connectors, also in the transfer drum home position sensors ther may be toner or paper dust.
May 20, 2008 | Canon CLC 1120 Color Copier
E072 - 0002
most of the time if you replace the transport cleaning unit it fixes the fault. on one machine i had a break in the wire lume that caused the problem. also make sure you don't have a piece of paper jammed in the unit.
Apr 09, 2008 | Canon CLC 1120 Color Copier
Canon CLC 1120 Color Copier Logo
194 people viewed this question
old marine
old marine
