Question about Goodman CPLE24-1 Air Conditioner
What compressor do i need - Goodman CPLE24-1 Air Conditioner
    Novelist:
  • 117 Answers
The compressors that come in units change from year to year and model to model. Depending on the age and type of unit, it could be a Copeland, Bristol....just about anything in the 2 ton range.
Best bet would be to look down and on the top or side of the compressor, you should see a series of numbers that have the model and serial numbers. The model would be the compressor you seek and the serial will help to determine the age of the compressor. Also be sure to look for a name brand such as Copeland, Bristol, Tecumseh, etc.etc..
Posted on May 26, 2010
What oil do I use for a G Force 2 HP air compressor, model 50622
  • www.air-compressor-guide.com/.../air-compressor-oil Keep your compressor in top condition by using the right air compressor oil. Make your compressor run nice and smooth. Using the right air compressor oil for your ...
  • Oil - Air Compressor Oil ' RONA www.rona.ca > ... > Parts and Accessories - Compressors Compressor oil. 473 ml. For all oil lubricated air compressors.
  • Husky 16 oz. Air Compressor Oil-HDA10700AV - The Home Depot www.homedepot.com/p/Husky-16-oz-Air-Compressor-Oil-HDA10700AV/...
    • 5/5
    • 1 REVIEW
    • $2.49
    • IN STOCK
    Air Compressor Oil from Husky is designed to reduce carbon buildup in compressor valves to ensure a longer compressor life.
  • Air Compressor Oil & Lubricant www.ecompressedair.com/compressor-oils.aspx eCompressedair is your source for Air Compressor Oil & Lubricants for major air compressors and synthetic compressor oil brands in 5 gallon air compressor oil ...
  • Oil-free air compressors - Atlas Copco Canada www.atlascopco.ca/caus/products/air-and-gas-compressors/1472896 Oil-free centrifugal compressors. Oil-free reciprocating piston compressors. Oil-free rotary tooth compressors. Oil-free screw compressors. Oil-free scroll compressors
  • Air Compressor - Oil-Free Air Compressor ' RONA www.rona.ca > ... > Products > Tools > Pneumatic Tools > Compressors Air Compressor - Oil-Free Air Compressor. Oil-free air compressor. 26 gal. Vertical, saves 50% more space. 1.7 running HP. 120 V. 15 A. Easy to operate controls with ...
  • May 17, 2016 | Air Tools & Compressors
    U-Line ice maker compressor won't run
    Dose compressor fell too hot ? There could be several things wrong. First you will need to get out your Volt meter to make all test. With unit calling for freeze cycle the condenser fan and compressor should be running. Check at the compressor to make sure your getting power to the over load switch and then through it to compressor. if not then check to see if compressor is to hot and has the switch open> If so then unplug unit to let compressor cool down so switch will close. when switch closes plug unit back up and start up unit check to see it compressor starts if so then you will need to see what is causing compressor to over heat. could be dirty condenser, low charge, fan dropping out, Bad compressor.
    Mar 07, 2014 | U-Line Icemaker
    The ac compressor is seized .I need to replace belt but I need to bypass the ac pulley.Do i need to buy a bypass pulley?
    If the pulley on the compressor will not turn freely, then yes if a bypass pulley exists you would need to use it in place of the compressor.
    If the compressor pulley turns but the compressor is locked up, just unplug the compressor clutch.
    Feb 24, 2013 | 1994 Chevrolet G20
    Is the external overload connect to the nurture line can protect the compressor?
    if your compressor is shorted to ground then you need a new compressor. if you need help finding what compressor part# you need let me know. The external overload is there to protect the compressor from overheating, but if it doesnt work there is no protection causing compressor to possibly short to ground.
    Nov 18, 2011 | True T-49 Side by Side Refrigerator...
    Charlieskidstrucking@comast.net
    Sorry but this compressor will only supply up to a maximum of 130 psi. That is all it will do, so this compressor will not suit your needs of 175 psi. There is no way to make it produce more. You simply need a larger compressor. This Northstar compressor will suit your needs. http://www.northerntool.com/shop/tools/product_290954_290954
    Apr 25, 2010 | Northstar Air Compressor Pump 326cc 105...
    AC Compressor not engaging on 2000 Chevy Impala. Fuses and AC relay okay. No power at compressor. Need wiring diagram. Also need to know if compressor requires 12v for operation. If not what should voltage...
    When your R-134a runs too low it will NOT engage the compressor. You need to refill your a/c system before the clutch will engage, I also suggest finding the leak.
    Apr 20, 2010 | 2000 Chevrolet Impala
    Ac will not cool. oil splatter inside hood . do I need another compressor?
    If the oil splatter is all around the compresser clutch and not in other places, then yes you probably need a new compressor. Usually the front seal in the compressors go out and you'll see oil and dirt buildup on the compressor clutch face.
    It is possible that the lip seal being replaced could fix the problem, but more times than not, the seal is wore out due to something wrong in the compressor. You'll probably be money ahead to replace the compressor unless you know the bearings are good and the compressor shaft has no side to side movement.
    If the oil buildup is elsewhere than the front of the compressor, it could be a bad hose or o-ring. In that case, you may not need to replace the compressor.
    Mar 30, 2010 | 1998 Buick Regal
    Compressors
    you can buy any small compressor, will do the job, it uses very low volume of air. for blowers, paintguns and drills you need high volume compressors. so if the nail gun is all you will use it for, buy an inexpensive compressor and save money. plz rate-bozcro
    Sep 10, 2009 | Air Tools & Compressors
    AC COMPRESSOR PROBLEM my ac compressor is not functioning .It stops functioning after sometime and needs to be restarted.I got it checked from authorised dealer who told me that the wires connected to the...
    if the wire is Short Circuit then you need to repair the wire only. After repairing the wire check the compressor. or try to test run the compressor.
    Jun 12, 2009 | Heating & Cooling
    Heating & Cooling Logo
    107 people viewed this question
    Top Goodman Heating & Cooling Experts
    Dan Webster
    Dan Webster
    paulcarew
    Brandon Berry
    Brandon Berry
    Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
