Question about 3Com SuperStack 3 RAS 1500 Base Unit (3C421600A) Remote Access Server
My netgear modem router DG834G
I have done all the connection to set up,but the wirless is not connect to the computer. is there also a gaget system that go into the back of my home computer that anable to function. please can you help
Delta4
**** on it
Posted on Jun 19, 2008
    Novelist:
  • 144 Answers
Hello!
-- do you have other wireless computer on the network?
-- what is the model number of the wireless adapter that you are using?
-- have you check if the wireless settings on your router are still configured correctly?
-- can you get online if you are directly connected to the router?
Posted on May 07, 2008
SOURCE:
Netgear DG834G wireless router wth built-in modem doesn't connect
Check if you have types all the configurations properly, namely Encapsulation / user name n password.
Jun 21, 2010 | NetGear DG834G 54 Mbps 802.11g Wireless...
I have received a netgear Dg834g v5 with no instructions, so I am trying to download a instruction manual any advice would be helpful
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Mar 20, 2010 | NetGear DG834G Router
Internet light on wireless modem is red and wont connect to internet. DSL, Wireless and Ethernet port 4 are all connected with green lights. Wont properly connect the modem.
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 04, 2009 | NetGear DG834G Router
WEP key fro netgear DG834G v3 WIRELESS ROUTER/MODEM
Okay, first you will need to access your router (usually 192.168.0.1 or something like that) you will be asked for a user name and password. (admin password respectively if you never set these up previously)
From there you would click on Wireless Settings and scroll down to WEP Key. Whatever is typed in Key 1 is your WEP key. Write that down. Plug in those numbers for your printer and you should be go to go.
Mar 21, 2009 | NetGear DG834G 802.11G Wireless ADSL...
Setting up a lan and internet thru MTNL triband
I suggests you to go for Linksys. It's a good product when it comes to wireless internet. Linksys router must be plugged in to the modem. On the back of the router, you can plug the vista on port number 1 then your win XP machine can go wireless at the same time.
Sep 16, 2008 | NetGear DG834G Router
Connecting another router
i would'nt recommend it, theres no need for two unless you have mote than 4 hardwired pc's and 8 wireless, especially if they are both modem/routers, you cannot use two, only one modem/router and one router
Sep 15, 2008 | NetGear DG834G Router
Netgear DG834G v3 Installation
connect the yellow (or blue?) ethernet cable to your computer, this should connect to the router (router should be ON)
Now, in internet explorer type 192.168.0.1 (this should be the defualt gateway for the router on default settings.
Now you're into the router, there should be a setup wizard button in there.
See if you can set it up using that
Regards
Tony
Feb 28, 2008 | NetGear DG834G Router
First use the Netgear setup wizard:-
Open Internet Explorer
Enter http://routeraddress e.g http://192.168.0.1
Click Setup Wizard (top left)
Then for With AOL make sure you have set these values in the Netgear
ADSL settings as PPPOa
VC 0,38
MTU setting to 1400
If you still have problems
Start -> Control Panel -> Add/Remove Programs -> select AOL Connectivity
click Add/Remove -> use the repair option
Follow instructions to repair.
Once complete make sure modem is configured and switched on and
try restarting AOL.
It should search for your connection, find it and allow you to log on.
Feb 06, 2008 | NetGear DG834G 54 Mbps 802.11g Wireless...
Open Questions:
PANDA TEch suPPoRt pHone @~18OO\\8O31O69}+ nUmBer rddfgt Usa PANDA USA phone number is ranked #2 out of 2 because 7,728 PANDA USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach t he PANDA USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, PANDA USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. PANDA USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact PANDA USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling PANDA USA Calling PANDA USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from PANDA USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with PANDA USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare PANDA USA's phone numbers against each other. Contacting PANDA USA in General While I8OO8O31O69 is PANDA USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach PANDA USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact PANDA USA.
Oct 21, 2019 | Panda Computers & Internet
D link router CUSTOMER service pHoNe:~{-l84433O2330}-}nUmBeR USA USAiary D link router CUSTOMER service Number +l84433O2330}}USALogin Repair service center to resolve all D link router tEcH SupPoRt pHoNe nUmBeR products. D link router ROUTER is an American multinational company which was founded by Michael D link router ROUTER using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, D link router ROUTER support number, and selling of computer-related services and products. D link router ROUTER Tech Support Phone Number Recently, D link router ROUTER has been named the number D link router ROUTER technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, D link router ROUTER customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a D link router ROUTER Service Tag or a D link router ROUTER Get D link router ROUTER Technical Support Phone Number and Customer Services. D link router ROUTER is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. Basically, the company offers computer related products and services.
Oct 21, 2019 | The Computers & Internet
See all 3Com SuperStack 3 RAS 1500 Base Unit (3C421600A) Questions
3Com SuperStack 3 RAS 1500 Base Unit (3C421600A) Remote Access Server Logo
105 people viewed this question
Top 3Com Computers & Internet Experts
john smith
didi2005
Håkan Sterner
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
