Question about Eagle Air Tools & Compressors
What is the head bolt torque specs on a eagle air compressor model # C5160V1
  • 32 Answers
20 ft/lbs re-tighten after a week, check monthly.
Posted on Dec 19, 2013
  • 19 Answers
SOURCE: head bolt torque spec for this compressor
220-300 in lbs work from center out
Posted on Feb 01, 2009
  • 19 Answers
220-300 inch lbs work from center out
  • 98 Answers
SOURCE: I need the head bolts torque specs for an
With Graphite gaskets the torque is 34 lbs.
Posted on Jul 21, 2009
dmftrucker
  • 1922 Answers
SOURCE: air leaks between head and cylinder
either the head gasket is gone or the rings are shot
Posted on Oct 06, 2009
  • 84 Answers
SOURCE: need to know torque specs for rod and head bolts
25-35 ft. lbs. Never saw any air compressor head bolts any other torque range If that number is a little squishy for you, call Quincy up tomorrow at
212-222-7700
Posted on Nov 27, 2009
Head bolt torque for ir. ss5 air compressor?
It's not that critical, use a torque wrench and make sure they are all evenly tightened like you would do with the head of a car engine. Use basic torque specs for the size bolt. That can be googled. Start with a lower setting on the torque wrench. Tighten the bolts in a pattern, then increase the torque setting and torque the bolts again.
May 20, 2016 | Ingersoll Rand Air Tools & Compressors
Husky model VT631502AJ head torque specs
I am certain there are torque specifications but I don't know what they are. You might be able to get them from the manufacturer. Lacking that, determine what the bolt strength (usually indicated by marks on the bolt head) and with the bolt strength and size you can determine what the appropriate torque would be for that size bolt. Too little torque and the head will leak. Too much and you will strip out the threads or twist off the bolt head. A 13mm head is nominally a 1/2", which is not a very large bolt head thus the bolt shank is not going to be particularly large, probably somewhere in the 7 to 9 mm range. Check online for torque specs. If you can't identify the specific bolt strength I would assume it is the lowest normal value for that size bolt. There shouldn't be any particular reason for using high-strength bolts in this type of application.
Aug 03, 2012 | Air Tools & Compressors
Motor heats up
It could have a bad motor start relay.
Jul 27, 2012 | Eagle C5160v1 - Single Stage - 5hp 60...
Locate pressure relief valve on c5160v1 eagle compressor
it is located on the 4 port manifold on the bottom of the pressure switch
Jul 05, 2012 | Eagle C5160v1 - Single Stage - 5hp 60...
What are are the tork spec on the clyinder head bolts
Torque setting for that cylinder head would be around 20 ft/lb and about 30% less if the bolt threads are lubricated before insertion.
Jun 22, 2011 | Craftsman 3 gal. Air Compressor, 1 hp,...
Torque specs for the head bolts on a GMC compressor
There are surely specs, but you should be able to feel the right tightness for these bolts. It's when the threads just begin to bend-- if you don't know this feeling, and can't find the torque specs, use 15- 20 ft. lbs.
Nov 23, 2009 | Ingersoll Rand SS3F2 Gm Ir Portable...
Need to know torque specs for rod and head bolts on a quincy model 350-11 air compresser
212-222-7700
Aug 21, 2009 | Air Tools & Compressors
Head bolt torque spec
Jan 15, 2009 | Coleman 6.5hp - 80 Gallon Vertical ASME...
Air Tools & Compressors Logo
455 people viewed this question
Top Eagle Air Tools & Compressors Experts
John Trevino
Bill Boyd
Steve Pack
Steve Pack
Are you an Eagle Air Tool and Compressor Expert? Answer questions, earn points and help others
