Question about American Range AF40 Deep Fryer
Connecting the LP Fryer to the propane tank
I have purchased this fryer but am unsure wether I require a regulator for the propane tank, or if the gas valve of the fryer is a regulator, Also how large or small of a tank is best and how long will it last for cooking
  • 77 Answers
The gas valve has a regulator on it....but there must be a regulator at the tank that steps it down from tank pressure to operating pressure. Operating pressure for LP is less than 1/2 psi. If you are using this for a trailer....a 40 lb tank would be best.
Tom
Posted on Aug 17, 2010
Flames cominhg out of flue
Hi I use to repair every kind of restaurant equipment under the sun..maybe I can help...Is this a new install of the fryer and it never did this before, or did this just start do this..If a new install, the first thing I would check is the gas regulator and see if it is for Nat gas or Lp gas, and find that out..cause it has to match what you have, comming into the building..usuall the gas valve has a sticker on it that says what the water columbs are like for Nat it is like 3-6, and for Lp(propane) it is like 5-12. Ive seen customers buy a used fryer, and install a LP fryer in a Natural gas build, and the valve lets too much gas to the burners, and it will shoot flames out the top..then you would have to buy and convert a gas valve, or use parts to convert it..let me know further..
Apr 20, 2014 | Pitco Frialator SG14 Deep Fryer
I have a Vulcan deep fryer. Converting from gas to LP. Changed out the orifices. Bought high pressure propane regulator. No smell of propane into fryer. Plug unit in and no power to electric...
Hi There. You have not mentioned that you also replaced the spring inside the gas valve suited for propane, please check. I strongly advise not to modify the unit's ignition system nor bypass safety device, this is for your own good. Check the gas valve spring first.
Nov 14, 2013 | Kitchen Appliances - Others
Does the Elite EFS-40 have a built in regulator?
Thanks for the Question! If you are referring to a internal Gas regulator this model comes with a option for Natural Gas or Propane.
So you will need to make sure that you have to correct gas connection for the Fryer. If you look at the Gas valave it will state whether it's NG (natural gas or LP liquified petroleum).
So if a NG valve it must be connected to Natural Gas. and Vise versa.
Installing a NG Fryer to propane will result in a dangerous situation because of the pressure difference.
If you are requesting information for a different type of regulator please let me know and I can give you the information you need.
Thanks for using Fixya.com I hope this answers you question.
Oct 14, 2013 | Imperial Kitchen Appliances - Others
I have a small counter top fryer set up for lp gas how do i change to nat
check the supplier for the conversion kit.the kit contains burner orifice, pilot orifice and gas valve spring which are commonly needed for conversion from propane to natural gas or from natural gas to propane.
****natural gas orifice has larger bore than propane, gas valve spring for propane is thicker than for natural gas.
Mar 29, 2011 | Cecilware FMS-40 Deep Fryer
Hi, i am trying to convert my cecilware fryer "FMS 403 HP" to bottled propane, i have been advised i may need a valve.??? can you help?
you will be needing a gas regulator (available at local hardware)when connecting the unit to a bottled propane.you will also need a conversion kit if your unit is designed for natural gas consumption.contact the manufacturer if ever you need a conversion kit.
Mar 13, 2011 | Cecilware FMS-403-HP ''Economy'' Deep...
Flame not going into heat tubes
Make sure the regulator assembly on the gas valve is for propane. Sounds like the gas pressure is too low and the flames aren't going into the burner tubes. Make sure they didn't install an appliance regulator on the back of the fryer. This is not needed as the fryer has a regulator on the gas valve. You can unscrew the cap on the regulator assembly and turn the plastic screw inside all the way in. DO not turn with alot of force. Easy does it.
Tom
Jul 23, 2010 | Imperial IFS40 Deep Fryer
Change from natural gas to propane
1.You will need to change the pilot orifice and the burner orifices
2. You may need to change the gas control valve. Some gas control valves are made for natural gas and some are made for LP. They have regulators built-in, that deliver the correct pressure respectively. Natural gas is 3.5 inches of water column, LP is 10 inches of water column.
Some manufacturers sell kits to change the spring in the regulator from Nat to LP
You would need a parts breakdown on the specific model number of your fryer to find the parts you need. Hope this helps.
Apr 07, 2009 | Imperial IFS40 Deep Fryer
Blew out the gas valve because they sold me the wrong regulator
Goto 3wire.com,type your model in.Before you try to fire it up i strongly suggest you check the gas pressure on the gas line or you will blow the valve again.
Apr 02, 2009 | Imperial IFS40 Deep Fryer
I have already installed the conversion kits for the frialators and changed all the orafices. Do I now need a regulator or can i just run a line from the outlet on then fryer to the propane termination on...
i am converting a frymaster sr-14 fryer, conversion kit says to install new spring in regulator then put new adjustment screw in flush, then turn clockwise 11 complete turns I only get 9 1/2 turns. is this normal or what .It is being converted to L.P. gas. what do I do. (manometer)
Mar 19, 2009 | Pitco Frialator SG14 Deep Fryer
My Cecilware GF-10 LP deep fryer the pilot will not light.
on that cecilware fryer there is a regulator to the right of the pilot light unsrew the aluminum cap and take off cap then you will see a white plastic screw turn that screw clockwise until it stops this will give the fryer more gas this could be your problem the regulator is silver and inline with the gas pipe comming from the back
Nov 21, 2008 | Cecilware GF-10 Deep Fryer
American Range AF40 Deep Fryer Logo
402 people viewed this question
Top American Range Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Mike
Are you an American Range Kitchen Appliances - Other Expert? Answer questions, earn points and help others
