Question about Coldtech J4SRR-40B Commercial Refrigerator
Good afternoon everyone, i have a coldtech fridge/freezer they run seperate compressors, my problem is with the 1/5 compressor on the fridge side. The problem is when the LCD display reaches 42 degrees the compressor fan turns on, but then i hear a click (like a relay clicking in, then out) then upon the 3 rd click the compressor starts.. for starters the coils are clean. ambient temp is 85. the unit has a dedicated 20 amp circuit, with a meter i 114.8 volts, so my question is am i drawing to much? relay failing, or compressor? and ideas .. thanks in andvance
2 Suggested Answers
  • 24 Answers
SOURCE: Fridge temp is high, there'a a clicking
If the sound you are hearing is a noise like the old clickers we used to hold in our hands, it is probably the overload. If so, doubt you might get it fixed by Friday. The sound is probably the Klixon overload and it "clicks" to open the circuit because too much current is being drawn. Reasons for this:
1) Compressor is locked and is pulling LRA locked rotor current.
2) Starting mechanism is not operating correctly. (better this than locked pump)
Starting relay is probably solid state and changing this may fix the problem. But, further testing is going to be necessary.
Sorry, but it is not going to be something you can easily do.
If the clicking is something different, like the defrost timer. Easy fix.
However, I am afraid you have something more serious. Warranty should handle any of this. Compressor should have a 5 yr. warranty. But that does not help getting it going right away.
Posted on Nov 20, 2008
How does a side by side domestic fridge work
Freezer one side, refrigerator the other side. Compressor is in the bottom at the rear. Often ice and water dispensers in the door.
Jan 23, 2016 | Refrigerators
Why would a brand new fridge make strange noises already?
Good Afternoon Friend,
I understand that your Frigidaire refrigerator, model# FFSS2614QS, is making a strange humming noise. Your new, high-efficiency refrigerator may introduce unfamiliar sounds. These sounds normally indicate your refrigerator is operating correctly. Some surfaces on floors, walls, and kitchen cabinets may make these sounds more noticeable. This could possibly be the compressor that you are hearing. Modern, high-efficiency compressors run much faster than in the past. The compressor may have a high-pitched hum or pulsating sound. Hope this is helpful.
-Best Regards-
Jul 02, 2014 | Frigidaire FFSS2614QS FFSS2614QS 26 Cu....
How long can you expect a fridge to last these days??
Hi Joanne
Wow, Is that an open question.....
How long is a piece of string...
I get what you mean though...
Only your Engel Service Dept knows for sure.
They see the returns.
Does it have a compressor or is it based on Heating Elements like an RV Fridge.
If you can hear the compressor running inside, you will know. Compressors don't like being tipped on their side.
I have 1 fridge & 1 Freezer in the back storage room that have been running for thirty years. But I don't think they make em like that any more.
Look after it. Keep the vents clear & hope for the best.
May 20, 2014 | Engel Freezer 22 Qt. Fridge/Freezer
Coldtech 65slc-lh-may compressor cycling on overload. does it have internal overload?
Typically, I know all AMERICAN MADE fractional horsepower compressors do not have internal overloads.
I just was not sure if this MADE IN CHINA compressor might have a different internal winding design that included an embedded winding overload. Upon further testing, though, it seems that the start components and overload are external.
Thank you,
Jerry Bullock
Apr 05, 2009 | Coldtech 12 cu. ft. / 340 liter Commercial...
Compressor runs for 5sec.
your relay and overload on side of compressor is can replace with original parts or a 3-n-1 hard to start.
Mar 09, 2009 | Whirlpool ED5GHGXMQ Side by Side...
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
Cold tech commercial reach-in freezer
sounds like an issue witrh the microprocessor to me as well, although you tried bypassing it it still didnt work its quite possible that the fan aand compressor are runnig on different voltagfe the 110v , new energy effient compressors are starting to run w/ 220, an inverter built into the circuit board could be steppin up power,
Apr 08, 2008 | Freezers
Fridge is not 'freezing', Looks like fan stopped working
could be due to ice build up jamming the fan. take back panel off and check for ice. if ice present the defrost system has failed. also on some models, the fan stops when door is opened. check door switch is operating
Mar 22, 2007 | GE GSS25JF Side by Side Refrigerator
Coldtech J4SRR-40B Commercial Refrigerator Logo
50 people viewed this question
Top Coldtech Refrigerators Experts
Dan Webster
Dan Webster
Randy Justice
Are you a Coldtech Refrigerator Expert? Answer questions, earn points and help others
