Question about Kenmore 24872 Top Load Washer
No hot water going in
I all the sudden can not get hot water to run in on any cycle
  • 166 Answers
Your water inlet valve is probably bad or stopped up with debris. some valves have screens that can be cleaned. you can swap the cold line and the hot line and check it that way. (you should get hot water when set on cold this way and cold for hot) be sure to turn the water off before swapping the hoses or you may get a little wet.
if the valve needs replacing you will need to remove the cabinet from the machine.
Posted on May 25, 2010
My whirlpool gold series dishwasher will not stop running through cycles unless i open the door. It will just continue to run for hours. Any relatively easy fixes before i call backup?
Some dishwashers can run for 4 hours or more normally depending on the options you choose. What do you mean by it runs through cycles is it always changing cycles by itself or is it just the cycle you pick just keeps on going, have you tried a quick wash or 1 hour wash does it do it then? is you hot water hot enough? if not it makes the unit run longer because it has to heat the water up. always run the hot water at the sink to bring hot water up from the water heater to the sing so the dishwasher fills with hot water and not cold.
Dec 28, 2016 | Whirlpool Dishwashers
My dishwasher suddenly won't wash hot on either the normal auto setting nor the eco one.
Do you find water left in the dishwasher bottom at cycle end???? It sound like your drain line is partially or completely blocked or possibly a bad drain pump depending on model. If it can't drain completely it can't refill with hot water. That will also explain an increase in the cycle time. Some dishwasher add time because it is trying to heat the water up. Its a loosing battle if the water isn't partially hot to begin with.
Apr 03, 2015 | Dishwashers
No hot water
The replacement valves could be defective or installed incorrectly.
Nov 15, 2013 | Maytag Neptune MAH5500B Front Load Washer
Washer temp setting changes by itself
I also have a Whirlpool washer/dryer for my condo, although I don't know the model number of mine. I had the same problem -- after it was precisely a year old, suddenly one day the hot and cold started coming out reversed. I was able to fix mine by more or less temporarily fiddling with the water pressure. What I did was one time, when the rinse cycle was running and the washer was filling up with hot water (grrrr...), I completely shut off the valve supplying hot water. So at that point the water stopped filling into the washer, and then I started tinkering with the cold water, twisting the valve off and on a few times. Then BINGO, suddenly the cold water "kicked in" and for the remainder of the rinse cycle, it filled the washer with cold water. I then turned the hot water valve back on, and since then it has been running correctly.
Jun 05, 2010 | Whirlpool Washing Machines
Hot water wont run out on hot water cycle
You mean Run IN dont you?
Water valve faulty.....replace.
Oct 24, 2009 | Washing Machines
Slow cold water fill, now no rinse/spray cycle
There is a filter screen inside the cold water valve.
Remove the hose, then take the filter screen out and clean it.
Replace it in the valve.
Problem solved until it stops up again.
Mar 12, 2009 | Washing Machines
Very long cycle as before
If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Yourdishwasher may pre-heat the water. If so, and if the water entering thedishwasher is cool, the heater may take up to half an hour to heat thewater.
To avoid the wait, increase the incoming watertemperature before turning on the dishwasher. Do that by running thekitchen sink faucet until the water runs hot. Or increase thetemperature of the hot water to the entire house at the hot waterheater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
May 10, 2008 | Kenmore 24 in. 16532 - Multiple Color...
Kenmore 24872 Top Load Washer Logo
37 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
