Question about Maytag Washing Machines
I have an old maytag model #LA712 top loader. Recently it has started overflowing not stopping when it's filling. This does not happen everytime and it does not leak any other times but when it does what a mess! Can anyone help? Sarah
  • 24 Answers
Usually this is caused by the water inlet valve sticking in the open position. If you can catch the washer while it's overflowing, unplug the washer. If the water stops, then the problem is most likely a pressure switch or pressure hose. If the water does not stop, it is most likely the water inlet valve.
Posted on May 25, 2010
Why won't my machine stop filling?
replace water level sensor
if less than 5 years old
should be able to get the part from a washing machine repairer
or hoover washing machine parts supplier
Apr 16, 2017 | Hoover Washing Machines
I have a ge top loader that won't stop filling with water. I have tested the water inlet valve also the magnetic lid switch, water supply hose seems fine. What else could be causing the overflow??
There has to be a sensor or float switch that lets it know when it's full.
Did something happen immediately before the problem started?
Jun 29, 2015 | GE Microwave Ovens
Why won't my Maytag Brazos top loader washer, model mvwx600xw1 agitate or spin? Also, the lid lock light blinks once in awhile. Checked lid lock, still no spinning
my first suspicion is in the door lock switch if it goes bad u have no action in wash or spin, next I would first check the water pressure switch as it is the unit that sends the signal to the machine to start wash cycle? if the diaphram does not detect the proper level of pressure due to water level. it will just keep filling and overflow and never start wash cycle. als0 check the water inlet valve, lastly a bad clutch will not allow much in the way of a spin cycle but would not effect the wash cycle? a bad motor coupler on the other hand stops both wash and spin?
Mar 23, 2015 | Maytag Washing Machines
My speedqueen top loader starts to fill up with water and every once in a while it overfills completely and overflows. It does not happen every time. Where can I check the switch /mechanism to stop...
There is a reset water level function on the front panel. To alter the water level each time you need to reset your water level . Ours used to do the same thing before my wife realized she was over filling it.
Jul 26, 2011 | Speed Queen Washing Machines
Model LA712 washing machine has a small leak how
These washers are notorious for getting an injection bladder leak. The baldder is located atop the washer in the imlet hose assembly; here is the part:
Located here on top left hand rear corner:
Remove the injector(white pointed plastic looking thingy) from inside the old bladder and shove it up into the new bladder ; reinstall it back where it came from.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 21, 2009 | Washing Machines
Water overlows from my Maytag Model LAT7304 as it
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
WATER DRAINING
Oct 10, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Top loader washer won't fill with water
Either the water level sensor is faulty or the selector switch is bad.
Servicing the Water Level Control Switch
This is another control panel switch, usually located next to the temperature switch. There is a small hose connected to this switch, and sometimes this hose becomes loose and falls off the connection. When this happens, the water in the tub usually overflows. To solve this problem, cut about 1/2 inch off the end of the hose and use a push fit to reconnect it to the switch.
The switch itself can also malfunction, resulting in tub overflow and other water-level trouble in the tub. If you suspect this switch is faulty, remove it by backing out the screws holding it in place. Take it to a professional service person for testing. If the switch is faulty, replace it with a new one of the same size and type. Connect the new switch the same way the old one was connected.
Oct 01, 2009 | Washing Machines
Ultimate Care II - water doesn't stop at the fill line, keeps filling to overflow and will not agitate
If the washer overfills, it may be something as simple as a detached or broken air hose on the pressure switch. The following link explains:
http://www.fixya.com/support/r762094-washer_overflows
The pressure switch on top loaders is located behind the load level selector knob on the operator console. The pressure switch on front loaders will be located inside the cabinet, usually mounted along the back interior wall. In the case of certain Maytag front loaders, the pressure switch is actually located under the tub. The principles of operation on all of them is the same, though. They all have an electrical connection and an air hose that detects the pressure from the tub as the water level rises.
If the pressure switch is not able to detect the water level properly, it will not shut off and the washer will never begin the wash cycle. Instead, you get a tub overflowing on your laundry room floor.
Read through the link provided and let me know if you have any questions. I hope this helps you.
NOTE: Another source of an overflow could be the water inlet valve. This is usually a slow fill fill that you find when the washer is sitting idle over night. A quick test to determine the source of the problem is to unplug the washer. If the water stops - pressure switch. If the water continues to fill - water inlet valve.
If you have questions, please let me know. I hope this helps you.
Aug 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
May 17, 2009 | Washing Machines
Washer does not stop filling and it overflows!
check the pressure switch tube connectiong to the tub for a hole or crack first
Apr 23, 2008 | Maytag Performa LAT2500A
Washing Machines Logo
149 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
