Question about Sony Xplod CD Player w/MP3 Playback CDX-GT50W
How do i change timing in Car tape cy530 - Sony Xplod CD Player w/MP3 Playback CDX-GT50W
E 10 tape deck error/ tapes keep spitting out
The radio checks to make sure the drive capstan is turning - if not, gives the E10 error. Either the drive belt in the radio is slipping or the drive wheel in the adapter is sticking. If it does it with a real cassette, then it's probably the drive belt. If not, you can try to figure out why the wheel in the adapter is not turning freely.
Jun 21, 2017 | 2001 Oldsmobile Intrigue
Which wires to use as positive &negative in sony xr-4807 car tape
The red wire is for ignition switch power, the yellow is for constant battery, (station and other settings memory). The black is for ground. I got a power converter, 120v ac to 12v dc, from Radio Shack, but I'm not sure they still sell them.
May 15, 2010 | Car Audio & Video
How do i remove the Tape deck in a 1992 triton/mighty max
Most radio's you have to have a remover kit and for the door's some body might of changed the lock before and lost the key are at one time the whole door might have been replaced do a car fax and see if the truck was ever wrecked
Mar 05, 2010 | 1992 Mitsubishi Mighty Max
Changed car battery now radio won't work-tape won't eject?
You have to go to car radio repair shop for the radio you have . the battery don't have a problem with the newly charge battery . The car radio has a problem with its push botton ejector . As well as the tape , the tape should be check and be repair.
Aug 16, 2009 | 1993 Mercury Grand Marquis
My 1995 bmw 318i won't eject a tape and the tape keeps changing from side 1 to side 2 and won't stop. I don't have any music in my car now since the only way to change it to radio is to eject the tape
Just a thought. try pushing the eject button holding it down & with a small pair of pliers carefully lift the tape & pull it out. Tape player heads could be dirty, eject button sticking or faulty or the player is done its time. Good luck
Jul 12, 2009 | 1996 BMW 318
Jammed cassette tape in car stereo
your cassette seems to be jammed, try removing the player open it which should reveal the trapped cassette then try to carefully remove the tape as it may have got stuck around the capstans(rubber bits) sometimes when tapes haveen't been played for a long time they tend to become loose, try to ensure that the tape is tight by using a pencil inserted into the spool and turn it until the tape tightens please take care not to over tighten. good luk
Apr 28, 2009 | Car Audio & Video
Tape deck spitting tape out
Time for a new car stereo. I recommend something that you can plug a flash drive into that will provide hours of listening pleasure. Repairing the factory tape deck is not going to be economical. Since the stereo has to be removed to diagnose it, much less repair it, just fill the hole with something else. If you absolutely love the factory deck, salvage yards everywhere have them available for less than the cost of a repair.
Jul 06, 2017 | Car Audio & Video
Tape deck won't open
If this is a deck where the tape slides in horizontally, like most car stereo tape players, you may have a broken or slipping belt. The fact that you "haven't used it in a long time" suggests a worn-out belt.
In my car stereo, the belt slips when it's cold and won't play or eject the tape. After a few minutes, the unit "warms up" and the belt starts turning. Then everything is fine.
I think we both need to replace our belts.
Nov 17, 2007 | Audio Players & Recorders
Vcr tape problem
It sounds like the tracking information is being lost for brief periods of time. Tracking is recorded at the lower edge of the tape, and if the tape is wrinkled or otherwise damaged in this area, playback will go out to lunch. A visual check of the tape would be in order. Have the heads been cleaned in these machines? This would be another area to check.... Also, there could be small differences in the tape path alignments, perhaps the control/audio head alignment is slightly different between the 2 machines.
Apr 28, 2007 | Panasonic AG-1980 S-VHS VCR
JVC GR-DVL520 Problems
try tapping it on the side.
-only, only, only use the more expensive JVC tapes. They keep their tension far better than cheaper brands. Also, they won't rub off their oxide coatings on the heads as easily, avoiding the 'clogging' of the heads (which thereby requires constant cleaning-further damaging the heads).
-when and if you do get E- errors do a complete rewind or fast forward to the end of the tape in order to pull out tape slack. Then remove battery and tape for a while. If still screwed, then yes, sharply tap (not hard!) on the closed tape door. That may reposition those tiny switches that I mentioned earlier and get you going again.
-NEVER, EVER, EVER, leave tapes in the machine when not in use....it creates problems for the heads and the mechanisms.
-Don't leave the battery on the camera when not in use for extended periods of time. It can create problems with respect to resetting the computer controlled logic.
-there are little switches and interlocks that provide electrical feedback about the mechanical status of things to the main processor of the camera (ie. tape/no tape in camera, door open/closed etc). Over time, the mechanics get out of adjustment because of usage, humidity and certainly rough handling. So: treat the mechanisms very, very, very delicately. Don't use/store the camera in humid conditions, hot conditions or very cold conditions. Certainly don't leave it in your car---ever!
-get the camera "cleaned and ajusted" regularly to avoid these problems. (I know...more $$$$)
-I keep bags of dessicant in an insulated camera bag with the camera to maintain dryness and optimal temperatures during storage.
Dec 28, 2006 | JVC Cybercam GR-DVL520 Mini DV Digital...
Sony Xplod CD Player w/MP3 Playback CDX-GT50W Logo
54 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
