Sony stereo cassette deck
I have the above name.Deck A works but deck B does not eject when i applied the eject button.Can you pls advise me solve this problem.
  • jooequartey Apr 08, 2008
    Thanks for your solution.I tried it and it did not work.The decks has seperate belt,and it has a variable resistor that controls the eject so i adjusted it a little and it stated working.
  • 4,234 Answers
Both decks are run using belts. If the belt on deck B is slipping, the stop sequence will not complete and the door will remain closed. You can open up the top and watch the sequence for deck A and move the motors/gears by hand on deck B to release the door. Once this is done, have the unit serviced. The parts (belts) should cost around $3 each. Add the local labor rate for the complete repair cost.
Dan
Posted on Apr 07, 2008
How do I dub using the onyx double cassette deck?
There should be a button or switch that will select the recording deck and the dubbing deck. You put a blank tape into the recording deck and the pre-recorded one into the play deck. Pressing the record button on the dubbing deck, on some models should start the play deck running. If not press play on that deck.
Jun 05, 2014 | Sony TC WE435 Stereo Dual Cassette Deck...
Sony TC-WR690 doors will not open to remove the cassette.
If you remove the cover after unplugging the AC, you will see that when you push the eject button that on the back side the putton is held back by a white plastic piece. Push down the white plastic piece as you press the eject button. The door will open and the tape will release. I jsut did this today on my Sony TC WR 670 dual tape player. Both sides were blocked. I noticed that both fuses on the board were also blown. New fuses didn't solve the problem. May be that the transformer is out?
Apr 21, 2012 | Sony CASSETTE DECK Single Dual Cassette...
Sony TC-WR670 eject wont open deck
I had the same problem. You probably have to replace the rubber belts.
Dec 02, 2009 | Sony STR-DE405
Sony Dual-Deck Cassette Player/Recorder, doors won't close
Are both sides not staying shut? If it's only one side, look to see if the latch is broken. You should see an arm move when you press down the eject button - while the door is open, press the eject button and see where the arm moves. You should see a hook that catches the door and keeps it closed. It could be broken, or just jammed. Look at the other side of the deck and see it it looks like it's working the same. Unjam the latch arm if it's stuck, or replace it if it's broken.
Feb 23, 2009 | Sony Dual-Deck Cassette Player/Recorder...
I have a Sony stereo cassette deck TC-WR590. Deck A and Deck B will not open. Both have tapes in them.
I have been there before! Most cassettes door releases act by a motion of a locking hinge release system .If you can see the movement when you press the release button use something that will flex but be strudy to HELP trip that mechcanial lever! BE CAREFUL & BE PATIENCE!
Jan 30, 2009 | Sony (43132) Audio Cassette (Type 1)
Cassette Tape stuck
The problem here is that the unit is stuck in a partial position. The "reset" by unplugging and plugging back in usually causes the unit to reset to a known position. If there is no activity (no motor sound), it will need to be opened up and reset manually. If you hear the motor running for a short period, it is attempting to reset, but the belt is most likely worn or broken. These units are relatively simple, but a bit tricky to dis-assemble. This repair should not require anything other than a belt or 2. Figure on $3-$10 for parts plus the local labor rate for the repair.
Dan
Sep 30, 2008 | Audio Players & Recorders
Magnavox tape deck
APPLY A GOOD BRAND CONTACT CLEANER OVER THE BUTTON AND PRES IT MANY TIMES.
Jan 20, 2008 | Sony TC WE435 Stereo Dual Cassette Deck...
Cassette Tape stuck
Try pushing the eject button while pusshing the power button. Mine was doing the same and that is how I was able to eject the tape.
Good luck
sam
Jan 01, 2008 | Sony TC WE435 Stereo Dual Cassette Deck...
147 people viewed this question
 Grubhead
Grubhead
