Question about Canon CLC 1120 Color Copier
Paper jam and no paper to be found in the copier
  • 62 Answers
Possible misfeed, first replace or clean feed tires. The machine is not picking the paper up in time ,hence no paper in machine.
Posted on Jul 09, 2010
CANON PC760 COPIER PAPER JAM LIGHTS UP BUT NO PAPER JAM CAN BE FOUND
Hi, have the same problem as Repairman99. (Thanks for such a great description - enabled me to find the fault quickly). Found the spring lying loose and the broken hook piece. Tried re-attaching a spring as suggested but still has paper jam fault. I'm thinking I've got the tension in the spring wrong - how firm should it hold the metal bracken with the rollers? - John.
Jun 10, 2014 | Office Equipment & Supplies
Paper jam sign appears after first copy
if jam indicated but no paper is found. clean the roller that feeds paper out of the paper tray.also make sure paper guides are touching paper front rear and left side.
Feb 23, 2014 | Ricoh FT5832 Copier
Getting a constant "Paper Jam 071-100" error when printing from Tray 1 (no jam found).
You need to replace the paper pick up, feed rollers and separation sub-assebly.
Nov 27, 2012 | Dell 3115CN
Hp laserjet 1200 printer.. i have a paper jam.. i've looked all over to see where i access the roller to get the paper out and i can't find it!
Paper Jammed can be found inside the toner cartridge compartment.
It can also be found in the paper feeder.
It can also be found at the back of the printer (if it can be accessible or can be open).
It can also found in the toner cartridge itself.
Check this areas to find for a paper jammed.
Jun 08, 2011 | HP LaserJet 1220 Printer
I have a paper jam i cannot find on a kyrocea fs-1300d any suggestions how to find and correct this problem?
Hi
1. Paper jammed can be found in the paper tray. Just remove all the paper and inspect paper jammed from the feeder roller.
2. Paper jammed can be found in the toner cartridge compartment. Remove the toner cartridge and inspect for paper jammed.
3. Paper jammed can also be found in the rear door of the printer (back door of the print). Check if there is a back door and inspect for a paper jammed into the roller.
4. Paper jammed can be found in the toner cartridge itself. Check for teared paper inside the toner cartridge.
Please let me know if you need more help
Mar 05, 2011 | Kyocera Fs-1300d Printer
LexMark x3430 printer
Here is a guide of all possible paper jam locations on the X340 printer. http://bit.ly/cS4lpm
If still no paper is found on any of those places then the printer has a faulty sensor. Depending on the paper jam numeric error is the sensor that may be failing.
Feb 12, 2010 | Lexmark X340n All-In-One Laser Printer
Paper Jam but no papaer found Canon Image Class D860
Have you checked that the paper path is clean and free of paper fragments which sometimes get jammed in the sensors? Try blowing them with a compressed air bottle.
Aug 24, 2009 | Canon imageCLASS D860 All-In-One Laser...
Paper jam message where there's no paper jammed - canon imageclass mf7280 laser all-in-one
If a jam is detected and no paper is found, this normally means that the paper was not feed out of the paper tray. Keep in mind, a paper "jam" can mean paper is where is it NOT suppose to be... or paper is NOT where is is suppose to be.
Aug 10, 2009 | Office Equipment & Supplies
Paper jam
I would make sure you opened and closed EVERY section of the machine that was indicated on the op panel.... even if you found the paper already..
Apr 11, 2009 | Office Equipment & Supplies
Canon CLC 1120 Color Copier Logo
57 people viewed this question
old marine
old marine
