Question about GE Profile Spectra JGBP90 Gas Kitchen Range
The front burner won't light.
I smell the gas but it won't fire up.
  • 166 Answers
I assume the other burners are lighting and the spark ignitor is working - if so try cleaning in and around the burner. a spill could have caused this problem. this should be a sealed burner model - if so make sure the burner top cap is on and seated correctly and or not gunked up with a spill. also check to make sure
Posted on May 25, 2010
4 Suggested Answers
  • 770 Answers
SOURCE: Occasional gas smell
If you have a burner lit and gas build up, strong smell etc., my advice would be to stop using the oven immediately! You no way gas should come out, build up, to the point you smell it, Especially while a burner is lit. Dangerous condition.
Posted on Jun 21, 2009
protek480
  • 1714 Answers
SOURCE: Igniter working, can smell gas, but gas not getting to burner
Gas valve is not working. Replace
Posted on Jul 23, 2009
meztang
  • 112 Answers
SOURCE: i have a magic chef oven model # 61S04PAW. the
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Posted on Jul 18, 2010
Laars lx won't ignite
hot surface igniter may not be hot enough to ignite the burners
Jan 09, 2013 | Teledyne Laars Laars Lx Pool Heater /...
When i turn on oven all i smell is gas i cleaned with a wire brush still nothing. also is the pilot light always have to be on and can you see it when oven is off
Most gas ovens that aren't electronic ignition usually have a pilot light.
Usually one in the oven area and one for each burner. (Sometimes shared between two burners.)
These pilot lights must lit at all times...otherwise it won't light up and you'll smell gas.
Usually the pilot light is in the very back of the oven and can be seen with the broiler drawer opened.
There is a small set screw located at the pilot light assembly in the oven and also at every burner.
This allows you to adjust pilot light up or down, thereby letting you set pilot light flame to a level that doesn't get blown out by a draft...or you can turn it off completely.
If you use that set screw to turn off the pilot light gas, you'd need to strike a match to light the oven or burners everytime you needed them.
Jul 17, 2011 | Ovens
I have a magic chef oven model # 61S04PAW. the
Jul 07, 2010 | Magic Chef 31000 Gas Kitchen Range
Front burners on gas range won't light.
My GE gas range is really sensitive about the gap between the igniter electrode and the metal disc that covers the burner. If the metal disc is slightly off-center, no spark will occur. Check to make sure that the gap between the igniter and the nearest metal is about the same as the back burner.
Jul 25, 2009 | Kitchen Ranges
Gas smell oven does not light
you may need new coupler on pilot system
Jun 23, 2009 | Magic Chef 9122 Gas Single Oven
Jun 21, 2009 | Viking VGIC305-4B Gas Kitchen Range
Bad odor from vent free gas logs.
it could be leaking when the fire place is on you said you checked for leaks was this to the burner as well ? it sounds like unbrunt gas check the burner , hope this helps , are you feeling sick or headaches as this would b e fumes ?
Jan 14, 2009 | Heating & Cooling
Oven Burner
try this,when you see the ignitor glow use a match and try to light the burner itself BE CAREFUL!! if the burner lights the problem is its clogged or low gas pressure.remove the burner and use brake cleaner to clean the burner AND pilot.if your using propane youll have to do this occasionally.let me know.
Jan 04, 2008 | Ovens
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
183 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
