Question about Kenmore Elite 45986 Front Load Washer
My machine starts to cycle and then it stops waits awhile then I get an error code F35. The machine will start and run without a load in it and cycles ok I can change to heavy duty cylce and it will run. It does not run on normal/casual with a full load. It will cycle with a small load. Any ideas??
  • 1,284 Answers
Hi, F35 has to do with the pressure switch which is located under the top panel on the back right. It will have a little black hose hooked to it. This happens when SUDS or detergent somehow gets up into it and usually locks unit out. Only solution is to replace pressure switch. You can find the tech sheet behind the bottom front panel usually tape to the back side of that panel or taped to the bottom right side inside unit.
Take care
Posted on May 25, 2010
What does F35 code mean and what to do?
  • Run an empty cycle without using any detergent. Often the fault code displays when too much detergent is used and the detergent sits in the drainage system. A cycle without any detergent is often enough to clear out the buildup.
  • 2 Pull the drain hose out of the standpipe mounted to the wall behind the washing machine. Complete a visual inspection of the hose for any clogs. If you see any, remove the screw that holds the hose clamp onto the discharge pump and then force water through the drain hose with pressurized water from a garden hose. Reattach the hose and then run an empty cycle to see if the code goes away.
  • Read more : http://www.ehow.com/how_11368049_fix-whirlpool-washer-f35-code-alert.html
    Oct 13, 2014 | Whirlpool Duet GHW9150P Front Load Washer
    What is error code f35
    Error Code F35 = Analog Pressure Sensor Failure
    If this failure is displayed, there is any malfunction of the steamer component detected by the Steamer Electronic Board.
    Possible Causes / Procedure:
    * Check if pressure hose is fixed correctly.
    * Check if the airtrap is not blocked.
    * Check if the hose is not blocked.
    If the washer does not accept inputs from the control panel, follow the Hard Reset steps below to reset the control:
    * Unplug or turn the circuit breaker off for 30 seconds.
    * Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
    * Press the Pause / Cancel / Stop button twice to clear the display.
    * Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
    Note:
    If the Hard Reset does not work, there may be an internal failure with the washer, that requires service.
    Hope this helps (remember to rate this answer).
    Apr 01, 2011 | Maytag EPIC MFW9700S Front Load Washer
    I START TO WASH AND A SUD APEARS AFTER 4 TO 6 MINUTES IT STARTS TO WASH THE WATER POURS INTO THE MACHINE AND IN A MINUTE AFTER IT STARTST IT STOPS ALL THE LIGHTS GO OUT AND A CODE F35 FLASHES CONSTANTLY...
    The SUD display could mean several things. A faulty drain pump, excessive detergent, excessive suds, or an extra heavy load.
    Open the front bottom panel and clean the drain pump filter of foreign objects. Also check the drain hose and make sure it is not clogged or kinked.
    If too much detergent was used, run the unit thru a rinse/spin cycle then a normal cycle without adding any detergent.
    Check the wire harness connections to the drain pump, pressure switch, and control board
    Feb 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    Kenmore Elite front load washer stops and blinks F35 and locks up
    f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
    Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
    F35 message, will not run through cycle. Starts to and then the F35 starts flashing and eventually shuts off.
    Check between door boot seal and drain hose in basket. If this is clogged with lint or sock, towel it will code f35 or sud
    Oct 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    I have a HE5t kenmore elite front loading washer. It has done great for about 15 months. We were away for about 3 weeks, and since we have returned, I put in a load of clothes, and it tries to start...
    F35 is a water level error.
    The water level switch (pressure switch) has malfunctioned.
    If you remove the top panel, three screws in the back, you will have access to the pressure switch.
    With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
    If the fault codes return after doing this, you will likely need to replace the pressure switch.
    Also - please be sure to use He soap.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*%^*
    Aug 27, 2009 | Kenmore HE2 Plus Front Load Washer
    SUD and F35 codes come up at beginning of cycle
    open front bottom cover their is drain pump open filter from drain pump be care full there is water in your drain pump (may be 1 or 2 gal water)
    clean filter put it back. run washer..if you get same error again then change your detergent and use less make sure you use he detergent. let me know it help or not please. thanks.
    Jun 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Error code F35
    May 18, 2009 | Kenmore HE2 Plus Front Load Washer
    Whirlpool front loader
    I've had this same problem and had a service man come in. The reason for the colde is an over-gunked up machine due to the directions for amount of soap to use on he bottles being incorrect.
    Run the washer empty several timres with just vinegar in place of the soap and then repeat with bleach. I've been told this will take care of the problem, but it may take many cycles before the codes will stop appearing.
    Also, from then on, only use 3 tablespoons, yes 3 tablespoons or 1 ounce of detergent per wash. The 1/4 cup that most he detergent bottles tell us to use is way too much.
    Nov 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Kenmore Elite 45986 Front Load Washer Logo
    100 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
