How do i input the ip address for printing in a bizhub 350
    President:
  • 676 Answers
Hello, my name is Israel. I will try to help you out. First be sure to connect the internet (patch) cable to the printer. ONce connected, you will need to go into the Administrator 2 screen. Once in the Administrator 2 screen, tap on the network settings button. You will need to go to the IP address section to get the IP address. Once you have it, you will need to go to the computer that you want to set up and go into the control panel, printers, add new, and follow the directions. If you do not have the CD for the printer, be sure to download the driver ahead of time. (You can use the following web site to down load driver: http://www.drivershq.com/Drivers/Devices/Konica-Minolta-Bizhub-350-Postscript-Driver/111855/133/Drivers.aspx) Once the computer installs driver and you are asked how computer is connected, you will click on network and it will then ask you for the IP address that you previously got from machine. Good Luck. Please rate.
Posted on May 25, 2010
Mac address for bizhub 161f
are the print driver installed properly was a ip address given to the machine
try this site
Self Help Product Support Konica Minolta Business Solutions Inc
Apr 07, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
How to use ip address for printing connection
First thing, you need the driver(you can download it). Copy the ip address of your copier match with the ip address of your computer.
Jan 17, 2012 | Minolta bizhub 350 Black and White Copier
I have Konica Minolta bizhub 350. My computer is already detected bizhub 350 but not print Thanks
When your computer has detected the photocopier machine, then the next step is to install the drivers, which you may find in CD-ROM or you can Google it.Drivers are easily available on the internet.Download the drivers, Install the printer and then execute print command.It will surely work. If you want to use it as a single pc printer then its ok, if you want to use it over network, as a network printer, then you have to assign IP address to machine.
Mar 26, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Bizhub C350, need to setup ip address
Utility / Administrator settings (pass:12345678) / Network settings / TCP/IP settings. Select auto IP, or enter it manually. You can check IP address by printing Configuration Page: Utility / User Settings / Printer setting / Print Report / Configuration Page. Press start.
Dec 09, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Have 3 cd's that came with it. Want to print from network PC. Seems like the Printer is not broadcasting IP address. How to find the IP of the printer. Bizhub 350.
if you are using for the first time as a network printer then you should first know how to assign the "IP ADDRESS" to machine/printer. to check the ip address of the printer, simply go to " Administrator" mode, and check ip there.
all the best...........
Jun 13, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
I install konica bizhub 350 to my network. scanning is going to SMB and very nice, but when i want to print from my PC, it did not print and also give no error.plz immediate help necessary. envoirment is...
Reinstall print driver to the PC using same ip address and print test print. next the same procedure go to web browser enter the ip address and choose administrator and the password 12345678. all your question will be in that area. scan, printing and network.
HH
Aug 08, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
I need to scan to email using the c353 konica Minolta. I used the same settings that the copier has that is working, but this one i set up won't scan to email.
This are the the information you need to setup scan to email and maybe you know how to access the web browser to setup the network. first you need to know the smtp host name or ip address, second you must create a valid email address for the copier. To access the web browser input the ip addrress and press enter click administrator and the password is 12345678 or 8 zeros. there are tab system info print, scan and network. click the the scan tab. choose scan to email first thing you will see enable scan to email smtp ip address or host name. enter the right smtp. witch this you can get to your mail server. do not change the port # and that is 25. Input administrator email address and the machine email address and turn on the authentication enter your user id and a password iof there is any.
Jun 12, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Printer not receiving information from computer
I guess you mean the c350 is not printing while Windows said the job has been sent? If so, it may have changed IP Address from the time you first install the Printer on Windows. Check the Ports setting of the c350 printer! e.g. d53b002.jpg
Network Pritners should have Static IP address or at least a reserved DHCP IP Address. Logon to your Router, check the MAC Address of the c350 and reserve/assign it a IP Address near the end of the DHCP range. Save the Router configuration and power cycle the c350. Confirm IP Address changed to the reserved IP.
Then you have to change all the PC's Printer Configuration of the c350's Port to update the reserved/assigned IP. Or remove the c350 from Printers and Faxes, then run the printer setup software again.
May 23, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub 350
use web browser, go your 350 ip address log in as admin, in network setting fill smtp server address and also you have to put email address for the printer and maybe its required to fill admin email also. and should work.
Feb 29, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
93 people viewed this question
jasbo
jasbo
