Question about Whirlpool GEW9200L Electric Dryer
Replace heating element for Duet Dryer GEW9200LW1
How do I take the heating element out of the GEW9200LW1 Whirlpool Duet dryer?
  • 24 Answers
First disconnect the power to the dryer by unplugging it from the wall. Then remove the 3 screws on the lower panel of the dryer. This should expose the heating element in a metal housing on the right side of the dryer. Disconnect the 2 wires going to the heating element and slide it out of the housing. The heating element part number is 3387747.
Posted on May 25, 2010
  • pacificspec Oct 25, 2010
    There is a metal clip mid way inside holding the frame of the element also a 1/4 screw
    you need to also disconnect six electrical female spade connectors to the limiter and thermosensor. you also have two screw holding the element tube in place
    (It s not just a simple slide out after two screws and two wires)
    The whole element tube need to be removed before you can attempt to remove the heating coil.
Fault code 8 on a whirlpool duet front load electric dryer GEW9200LW1
Could be bad heating element, bad high limit thermostat or bad cycling thermostat. All of which can be ohmed out with a standard ohm meter. If you replace one I would replace all of them, if you don't you will be going back in there later and replacing another one of those parts
Jan 16, 2017 | Whirlpool Dryers
Whirlpool duet dryer GEW9200LW1 heats
If the element was replaced, and now verified that it is not presently shorted to ground, your next diagnostic would be to to test the timer connections per the schematic lookiong for a fused contact that energizes the heater, while set to air fluff setting.
Apr 08, 2014 | Whirlpool Dryers
User manual for Whirlpool Duet Dryer #GEW9200LW1
The users manual will not help you but there is a tech manual usually if you take out usually if you take out the bottom kick plate it will be taped to it
Aug 09, 2012 | Dryers
How do I replace heating element in a whirlpool duet dryer?
The following link explains step-by-step how to replace the heating element on a Whirlpool Duet series dryer:
http://www.fixya.com/support/r3677025-elite_duet_dryer_heating_element
This is not a difficult repair, but it can be tedious. Just follow the instructions I provided and let me know if you have any questions. I hope you find this helpful.
May 17, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet Dryer ( gew9200lw1): no heat
If your dryer runs, but does NOT heat, the following link explains how to troubleshoot an ELECTRIC dryer with a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
The Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts (if required) can be found at the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average cost of these components varies, so shop and compare. The first three websites I listed have helpful exploded view parts diagrams that can help you locate and properly identify the parts you need. The heating components are usually listed under the "Bulkhead" section.
NOTE: In many cases the problem is NOT the heating element. The heating element has protection devices that are designed to regulate the heat temperatures. If the dryer overheats the Thermal Cut-Out (TCO) typically will blow BEFORE the heating element. The replacement kit is much cheaper than purchasing a new heating element that may or may not be the problem.
Read through the information I provided and, if you have any questions, please post back and let me know. I hope you find this information is helpful.
Feb 25, 2010 | GE Dryers
MY DUET DRYER IS NOT HEATING UP. WHAT COULD BE THE
no heat at all probally element or the thermostat on the element.if heats but takes long time outside venting probally plugged up.make sure your getting 220 v to dryer before anything
Jan 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
WHIRLPOoL GEW9200LW1 RUNS BUT ONLY BLOWS COLD ON ANY SETTING.
if no heat , but all else is fine, means heating element needs replacing, most likely accesed from back panel of machine, about 25$ part
Aug 22, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool dryer GEW9200LW1
Hi.
To be sure the element is not faulty, you need to have it tested for continuity, and for an earth fault.
Nov 23, 2008 | Whirlpool LAB2700ML Pedestal Drawer for...
Whirlpool Duet Dryer - Working but no heat
i need help fixing my 5 year old dryer. whirlpool duet model GEW9200LW1. I have replaced the thermistor. I tested (with an ohm meter) the heating coil, thermal fuse, high limit thermostat, & heating element and they were all fine. I replaced the electronic control assembly and the user interface. THE DRYER STILL WONT HEAT.
Then it occurred to me that the sensor may not allow the dryer to heat if its not sensing wet. Could this be true? Have I been trouble shooting this wrong?
Help me.
Dec 16, 2007 | Whirlpool GEW9250 Electric Dryer
Whirlpool GEW9200L Electric Dryer Logo
3,170 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
