In flash (cs5), how do you make a symbol/movieclip become larger/smaller as the cursor moves closer/farther away to it? If that's unclear.. Picture a page with a two circles on it, one on the left and one on the right. If the cursor is in the middle, the circles are the same size. As the cursor moves to the right, the circle on the right gets bigger (and the one on the left gets smaller), and vice versa.
  • mooredrew May 25, 2010
    great, thanks. very helpful
    President:
  • 524 Answers
Hello Mooredrew,
Step1: Create an object by using an oval tool
Step2: Righ Click on your object and select Convert To Symbol
Step3: Select Movie Clip and press ok
Step4: Right click on any empty frame from time line and select insert KeyFrame
Step5: Click on your last keyframe and then click on your object, from properties pannel change the width and height
Step6: Right Click any where between your starting and ending frame and select Create Motion Tween
Step7: If you see an arrow line on your time line, You are done
Step8: Now test your movie by click on Control Menu and Test Movie
Step9: Now lets make Zoom out Effect, Right click on any empty frame after your last frame and select insert KeyFrame on time line
Step10: Click on your new last keyframe and then click on your object, from properties pannel change the width and height back to the orignal one
Step11: Right Click any where between your starting and ending frame and select Create Motion Tween
Step12: If you see an arrow line on your time line, You are done
Step13: Now test your movie by click on Control Menu and Test Movie
Step14: Give me a big smile now, because now you can do zoom in and zoom out.
Please let me know if you have any further questions or concerns
Thanks.
Posted on May 25, 2010
    okay, that helps, but what I really want to know is how to configure actionscript to make it interactive.. i want the ovals to zoom in and out relative to the position of the cursor.. so that the closer I move the mouse to one oval the larger it gets and the smaller the other one gets. Then, if I move the mouse toward the other oval, that one gets larger and the first gets smaller.
    Does that make sense?
  • CIROC TECH SUPPORT
    CIROC TECH SUPPORT May 25, 2010
    Hello Moordrew,
    i wont be able to describe the whole tutorial in this comment with pictures and codes because its really long .
    But i have it in my google docs (its published)
    CLICK HERE to view the tutorial
    THanks.
Tip
Explaining Camera Focus
Camera: Focus We've seen that a real image is formed by light moving through a convex lens. The nature of this real image varies depending on how the light travels through the lens. This light path depends on two major factors:
  • The angle of the light beam's entry into the lens
  • The structure of the lens
The angle of light entry changes when you move the object closer or farther away from the lens. You can see this in the diagram below. The light beams from the pencil point enter the lens at a sharper angle when the pencil is closer to the lens and a more obtuse angle when the pencil is farther away. But overall, the lens only bends the light beam to a certain total degree, no matter how it enters. Consequently, light beams that enter at a sharper angle will exit at a more obtuse angle, and vice versa. The total "bending angle" at any particular point on the lens remains constant. camera-diagram3.gif
As you can see, light beams from a closer point converge farther away from the lens than light beams from a point that's farther away. In other words, the real image of a closer object forms farther away from the lens than the real image from a more distant object. You can observe this phenomenon with a simple experiment. Light a candle in the dark, and hold a magnifying glass between it and the wall. You will see an upside down image of the candle on the wall. If the real image of the candle does not fall directly on the wall, it will appear somewhat blurry. The light beams from a particular point don't quite converge at this point. To focus the image, move the magnifying glass closer or farther away from the candle. camera-diagram2.gif
This is what you're doing when you turn the lens of a camera to focus it -- you're moving it closer or farther away from the film surface. As you move the lens, you can line up the focused real image of an object so it falls directly on the film surface. You now know that at any one point, a lens bends light beams to a certain total degree, no matter the light beam's angle of entry. This total "bending angle" is determined by the structure of the lens.
courtesy of HowStuffWorks.com
on Mar 21, 2008 | Canon PowerShot A520 Digital Camera
I have Model AW131 Grill Right wireless Thermometer. It shows no transmission signal no matter what I do. Any suggestions. It is brand new.
you are supposed to hit the RESET button within 1 minute of each other to sync the products together.
The reset buttons are inside where the batteries are on both units. Hit them withing a few seconds of each other and they will sync. Then you should see an antenna symbol on top left of the receiver's screen.
Feb 27, 2013 | Oregon Scientific BBQ Thermometer
Have 2001 Suzuki Volusia, was wondering what knob (with numbers) is in front of brake handle on right side (while sitting on it) when bought it had no manual.
That sounds like it is an adjustable lever to be adjusted by the numbers to fit your hand size. Large hands lever farther away from the handlebar. Smaller hands lever set closer to the bars.
May 18, 2011 | Suzuki VL 800 Volusia Motorcycles
Full screen
Press the F11 button to get full screen.
To return back to normal screen, press the F11 button again.
You can also hold down the CTRL key on the keyboard and Scroll down the scrolling button on the mouse.
To revert to normal , again hold the CTRL button on the keyboard and scroll upwards.
Cheer
Uttam
Jul 12, 2010 | Advent Netbook
Why does it tend to stop working for split seconds once in a while. It makes gameplay very hard. Every now and then the cursor just stays still like the mouse turned off for like 2 seconds. Can u tell me...
hi there, the problem with wireless is that the farther you get away from the computer, more data is lost in the air. It means that the mouse isn't close enough to the computer. Try moving the mouse closer to the receiver and see what happens.
Feb 18, 2010 | Ultra Max Gigaware Wireless Laser Mouse
ACTIONSCRIPT 3.0 BUILDING SIMPLE WEBSITE FLASH CS4
you can try this site http://www.xnynz.com/.
I built my own website from this site.
It provides best features.
Oct 12, 2009 | Adobe Flash Pro CS4 for PC
New response to night shots
Hey matty reps,
The numbers you are seeing represent the size of the aperture. The smaller the number you set the camera to the larger the opening in the lens that lets light thru, and the larger the number is the smaller the opening is. The closer you are to your subject the smaller aperture you can use (larger#'s) because you will need less light from the flash to reach the sensor, and the farther away you are from your subject the larger the aperture (smaller#'s) you will need to use. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 29, 2008 | Canon EOS Rebel K2 35mm SLR Camera
Uploading of a swf file into another swf file in a specific locoation
step-1: take rectangle shape
step-2: convert it to movieclip by pressing right mouse button the choose convert to symbol.
step-3: during convert choose the [Registration] as left corner.
step-4: place the movieclip where u need to place in scene and resize it as your requirement.
step-5: this open the movieclip.
step-6: Add new layer in timeline.
step-7: write this code.
this.loadMovie("file_name.swf", get);
step-8: Then test (Run) your movie.
Feb 13, 2008 | Macromedia Flash MX
User's Manual
For the manual ask at http://manualfox.com
They will find it.
Oct 19, 2007 | Office Equipment & Supplies
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
